Tools for DIY of Vehicles
vitz
Guys... I am thinking of collaborative effort to assemble a list of DIY tools for day to day vehicle maintenance.....Many thanks for your contribution.....
1. 1/2 in socket set -and ratchet
          Concerns: SAE or Metric? or both, what is the range of socket sizes, whether 3/8 socket set and the ratchet will be more useful?
2. Torque wrench (depending on the choice of 1)
3. Vehicle stands and a Jack
4. Breaker bar
list to be completed....
Voltmeter + 12V Tester
Long Screw Drivers Flat/Philips
Short Screw Drivers Fat Philips
Spark plug sockets
Set of wrenches, open end, + ring spanners
Torx Screw driver set
Hose Crimp Pliers
Hose Clamp Pliers
Wire Stripper, wire crimper
Hydraulic 2tonne - trolley jack
Drill with Dremel , Extension Cord, bits, hole saws
Angle Grinder
Universal Filter Removal Tool. or to suit your car(s)
Metric Socket set with ratchet and angle
Vice
Small Compressor with paint gun, with tyre attachment
Plastic trim removal tools
12v light to hang into car
Plastic funnel
PLastic oil tray,
Jerry Can
Like to add following to  @tiv's list.
  1. Hammer(s)
  2. Set of Hex key (Allen Keys)
  3. Chisel
  4. A soldering iron - 60W or 100W
  5. Working table with metal top
  6. Old engine block or a piece thick H iron bar
Gasket removing scraper
Set of feeler gauges
Vernier calipers
Valve spring compressor
Set of copper bristle wire brushes
Paint brushes (1/4")
Spill free funnel
Metal file
Piston ring expander
Pliers - nose, circlip compressing,
Gear puller/harmonic balancer
(OBD Scanner, dwell angle monitor, compression gauge, timing light. Not diy tools per se)
Measuring ruler, marker, ziplock bags, paper and pen, sticker, a camera come in handy for any DIY job.
Edited by varotone
Added content
1. SAE or metric depending on your vehicle. Isn't it? 1/2 would be the best in my opinion.
2. Doesn't it depend on the torque range you need? There are digital torque meters with a range from 8-500Nm. Looks versatile. I don't have one to test the accuracy. Also, is there any place that hires torque wrench? I'm planning to invest on one. A set of quality torque wrench costs a fortune.
Thanks. 1/2 socket set would be more useful it seems.
Yeah, digital torque wrench like https://www.amazon.ca/ACDelco-ARM602-4-Measurement-Adapter-4-147-6-Feet/dp/B004VYURT0/ref=sr_1_1?crid=17XI02TO6A5MU&keywords=digital+torque+adapter&qid=1558321468&s=gateway&sprefix=digital+torque+%2Caps%2C193&sr=8-1 would be a good pick. I am not sure it is available in Amazon Asia
IMHO it's very hard to lock it down to a particular set. As you grow in capability and skill, more and more tools will be required and it is a never ending process :)
Spoken by someone who literally taught the words DIY to this forum,
nice to see you back mate!
When you do DIY safety is 1st as I haven't noticed anything related to safety above list.
- Disposable rubber gloves
- Safety glasses
- Some plasters or FirstAid box
- fire extinguisher (Better be prepared)
My favorites:
- Cordless impact wrench (love it)
- Mini cordless drill
- Laptop or a IPAD with internet (without youtube video to explain how we all lost) especially when I removed the 4JG2 alternator sure I looked at the same video 15 times.
Most important, "beer"
Hope you like my list or at least the last on the list :-)
  • 1 month later...
Guys, are following items needed for a break/caliper related DIY is available in Sri Lanka, if where I can buy them:
1. Silicone paste (Si Based lubricant) for lubricating guide pins. I know our mechanics use grease called "Rubber Grease - Seiken", is it a sort of Si based product?
2. Copper-based anti-sieze lubricant ( for break pad guiding sleeves and shims)
3. Thread locker
  • 1 year later...
- Safety glasses
My favorites:
Hope you like my list or at least the last on the list 🙂
Cool list you got there, mate. I agree with the most important part of the list, a cold beer is definitely refreshing. It will surely keep me up and running. By the way, I'm planning to buy a cordless drill, what do you recommend worth buying?
