Dear All
My FB 15 car dose not pick up in  the morning in Gear " D " but  starting with 1st and change after running about 200 meters and once change to "D"
Its running  normal and changes the gears with speed ,as normal
Check with few leading garages arround in Kandy ,but there is no proper advise  other than go for a recondition auto gear box
1 what will be the possible course
2. Can this be repair or need to replace  the gear box
3 if so what would be the approximate cost ?
Please advise
Dhammika
You will have no idea what the condition of the reconditioned gearbox will be. Most of these reconditioned gear boxes you find at parts shops are not reconditioned. They are just stripped off of cars and sold here. The reconditioning part will have to be done by you or just put it in your car and just use is as it is. If you are lucky it will be good if not your reconditioned gearbox itself will need re-reconditioning.
What I would say is take your current gearbox and recondition that one. That way you will know what the initial condition of the gear box is and what you have done to it,
