HI;
What is the most effective Fuel System Cleaner fluid available in the Sri lankan market ? Isn't "Chevron Techron fuel system cleaner" available in SL now ???
RG
Edited by Kasun2020
30 minutes ago, Kasun2020 said:
HI;
What is the most effective injector cleaning  fluid available in the Sri lankan market ? Isn't "Chevron Techron fuel system cleaner" available in SL now ???
RG
Most people I've seen use Wurth Injector Cleanor. It's good enough.
That's what they used for my recent tune-up as well
Thanks for the replies. I asked about "Fuel System Cleaner" which can be put directly into fuel tank. not the injector cleaning spray ...sorry for my misleading massage (I corrected it).
Edited by Kasun2020
I wouldn't trust those to be honest.
There are so many brands of them but it's better you get a professional tune up done. I used one such product (forgot the dumb brand) and once in a while suffered tiny misfires when downshifting (rare but happens) even though I used the right amount.
Heard someone who's diesel engine started having problems after using such a product too.
Get a tune up done and focus on your driving manners and concentration. Avoid driving during busy times unless necessary. That will help you get the best fuel economy and keep your car in good shape too :)
Reputable additives are okay if you want to chase away some water build up and break away some minor impurities in the filters and the injectors. It cannot replace a proper, hands-on cleanup of the fuel system. So it is okay for a occasional flush out. Anything excessive would require frequent/significant use of the additive and that might cause long term damage (filters getting worn out, etc...).
Again...reputable brand is key here....I would stay away from the STP cleaner as I have come across many people in many countries who had trouble with it (it used to be good but the new ones seem to be a bit harsh). So within a SL context I suppose that leaves Wurth and Liquimoly ?
It is important that you put an additive only before an oil change (especially if it is the first time you are using it) and most of these additives o recommend that.
Thanks for the valuable information you provided.
By the way, (I have heard it before) why it should  put an additive only before an oil change??
The additive will loosen up impurities that are stuck in the injectors, fuel filter, lines, etc...these (which are the size micro-particles after having broken up) will get injected in to the engine and eventually get cleaned/flushed-up by the oil. SO in essence the oil is dirty. Dirty oil is not good.
Thanks for the swift explanation !
I used Wurth one at once for my Vitz but nothing happened.
My personal impression is,  It's just a mind game. When you think it's working you will feel a difference, otherwise not. No measurable results.
And....  I have this question.
Petrol itself a good solvent and its going through the injectors having pressurized (and atomized at the end). Do adding 0.5% solvent to petrol will remove something which cannot be removed by pressurized (and atomized) petrol?
@iRage, any comments?
Edited by gayanath
