The car is a an automatic Bluebird U13 Arx and it has driven 205k km's already, and I'm seeing signs of engine trouble like plugs getting impacted with oil and burns out, engine knocking even though the distributor is set to retard (max), and issues with idle stabling. However the pickup and speed hasnt reduced. So I'm guessing in another 15k to 20k km's im expected to have to do an engine overhaul or replace it. So I'm thinking, instead of doing the same SR18 engine again, to replace it with the SR20DE. But before prepping for this I need to know all the details as to what I should expect to do and keep in mind when I do the swap. Following are my questions:
1. Will the brackets/mounting fit the SR20DE engine without a problem or do I have to do new mounting adjustments also or is it just a direct fit? is it the same engine design?
2. Do I only have to change the ECU, Gearbox when I do the engine swap or are there any more items that needs to go in?
3. Should I be worried about suspension too? Like should I be upgrading the suspension too to fit the SR20?
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
PreseaLover
Hi Folks,
4. What are the CONS?
9 answers to this question
