Guys, Humming noise at high speed and slight movement to left when letting go of steering wheel (even after wheel alignment). Is this related to a wheel bearing issue? My other suspension components are in order.
Yes...if you are certain everything else is in order (including any abnormalities in the tire and you are positive that the brakes are not grinding or gripping). Lift it up and see if there is any play as well.
