My vehicle is supposed to use Honda All Season Antifreeze/Coolant Type 2 (Blue), but given that it's not readily available or rather expensive, I was interested in more affordable alternatives. When I ask around, everyone and their mothers tell me to just match the color of what's already in there and be on my way!
But I have enough sense to not listen to what most locals have to say, even so called engineers employed by the official agent! and that's why we are here!
When I asked my trusted local supplier what alternatives were available, he offered me Berner. So I did some reading without going in blind and learnt that Berner, which is a German brand, is largely formulated for European vehicles using coolant technology called Si-OAT. Honda Type 2 coolant is supposed to use a technology called P-HOAT. While both these coolants are varieties of HOAT, my reading tells me that they are not the exact same and should NOT be combined.
Most people have been matching color and probably don't have any problems at all, but this is most likely because they got lucky since most of the alternatives available are compatible with Japanese vehicles and that's what we have most running on our roads. As for those few who are not lucky they may not notice any problems for years, but then end up with engine damage and a host of other problems they might never even realize was caused by the coolant...
So please be thoroughly informed of what alternative you are using in your vehicle.
TLDR: All coolants are NOT the same, even if they are the same color! If you don't have the time or the skills to figure out which alternatives are compatible, please don't take the risk and just use the factory recommended genuine coolant!
Edited by Monkey King Stu
sentence structure
Great topic @iRage
I have been told some of them have the chemical components to work as an anticorrosive for some of the aluminium components. Correct me if I am wrong on that
Well....Si would mean it has Silicone as the Hybrid component and P suggests Phosphate.
Both do provide anti-corrosive properties for aluminium, but the nature of the chemical compound means one does it slightly faster and differently than the other (which, depending on the engine, would make one better than the other). If memory serves me right Phosphate based OATs add a slight protective layer while Silicone based ones don't.
Now, if you swap Si with P, it may not necessarily affect the rust build-up, but it will most definitely start affecting things like water pump seals and all other rubber and plastic-related components that are within the cooling system (which in modern cars is quite a lot). Yes...you should not mix the two (which a lot of people do because the color is the same). Mixing can cause layering (I don't know how to explain it), where the chemical compounds separate and then form small molecular blobs (sludge) that can be abrasive and wear out water lines, etc.
The easiest is to go with the manufacturer labeled recommended coolant. If not you will need to check the chemical composition (don't forget even a P-HOAT can be different between manufacturers...so sometimes it might work, sometimes not).
The color-based system Lankans go by is a misguided and detrimental carry-over from the days of the past. Back in the day coolants were IAs (Inorganic additives). These typically came with different additives based on ambient/environmental temp conditions (high,moderate and cold temp zones..). To make it easily identifiable, there were color additives as well. Sadly when IA coolants changes to HOAs people simply did not learn about the H component. In fact most believe that the H in HOAT coolants means that it is specifically for Hybrid engines. So..go figure....
Then the next question is can HOATs be used on old cars that were specifically designed to run on IA coolants...yes..but also no.
If the old car's cooling system is in decent shape (i.e. no/minimal rust) and properly flushed...then yes. Putting HOAT will not be the end of the world. The seals and old copper radiators might react to the P or Si but then being old, these cars would need new seals and a new radiator anyway. If the water lines are rusty, etc...then the modern coolant might break that rust off creating water line blocks, etc...so you really need to be careful (also don't try to put old school IA coolant in to modern cars because the anti-corrosion might not work well with modern aluminum blocks and such)
Any reasoning behind recommended coolant flush intervals of 3yrs/50,000kms when the recommended coolant itself is rated for 5yrs/100,000kms?
Is it perhaps a safety precaution in case of alternate after-market coolants that might not be up to standard?
Without any official anser, I guess it's just safer to stick to the more conservative estimate...
THIS! This was the exact reason for my post! For someone knowledgeable to make an informed reply/comment about the facts of the matter!
The local makabass fellows don't know anything about this stuff, neither do most of the staff at the agents!
1) Valvoline Zerex Asian Blue is supposed to be an acceptable alternative to Honda Type 2, any comments?
2) AI says so is Seiken (Bear Brand) Hype Long Life Coolant Blue, but can't find any articles, comments?
3) How many people actually fully flush their coolant in the maintenance recommended 3yrs or coolant life 5yrs, if at all!?!
Sorry...cannot speak to the other two points. However...about this....our Corolla reached its three-year mark (from new) last December. Manufacturer recommendation (for Japan) follows the shaken requirements. First flush three years from new and subsequently every two or four years (coinciding with shaken inspections) depending on the age of the vehicle...but it is so cheap in Japan (what costs more is the labor) the shaken service by default has a coolant flush and refill. So...took it to Toy#ta L#nka and asked them to do all these fluid changes and they very nicely told me it is not needed in Sri Lanka....and if I was sure I want all that done. So..I believe I can safely say that probably just 1 or 2 % of vehicle owners actually do a proper flush. Also goes to show that claims of "Agent Maintained", etc... mean nothing unless you check what exactly has been done. .
Well this is where it gets even more confusing... because at times, the agents are even more conservative and recommend certain services even earlier than the manufacturer's intervals, and at other times it's the complete opposite! 😞
And the average end-user is completely at their mercy! No matter how badly we really want to take of our vehicle, for the most part we are unable to make any kind of educated decision by ourselves. I doubt that even 99% of people would do  as much reading as I did on so many topics regarding vehicle maintenance... and I don't blame them.
And still, despite all the reading and knowledge, we still have to double guess ourself when an allegedly qualified engineer refutes whatever we read up on... 😩
  • Haha 1
Nope..things are never that simple are they ? Take CVT fluid and Toyota....they started by saying CVTs are lifetime non-serviceable components. Check fluid and replace only if needed at 100,000..then 80,000 and now 40-50k...Now as the 50,000km service has a CVT fluid check and replace if required service item, the car came with a maintenance plan catalog which recommends CVT fluid replacement at around 20,000km...so...uhh...what are we suppose to follow ?
This is where the workshop manual comes handy. Take a look at my Lancer's workshop manual:
Zero ambiguities, short and to the point.
Explicitly outlines the coolant's specs regardless if it's OEM or not.
Maintenance intervals are not in doubt as an export market schedule was provided with the car.
No agent / mechanic / engineer can dispute the workshop manual either, you just go "How do you know better than the people who made the car?" 😁
Edited by Hyaenidae
  • 3 weeks later...
I just learnt that my vehicle's (when brand new) coolant service interval (using genuine Honda coolant) is at 200,000 kms or 10 yrs, but thereafter it's every 100,000 kms or 5 yrs.
Goes to show how important the owner's manual is! I wonder how many people in LK know this stuff! I used my first vehicle for 15 yrs and didn't know any of this stuff because I trusted other drivers, makabass, agents, etc., to know better... 😩
Local makabass are honestly one of the biggest curses for vehicles in SL. 😅
Dad went to replace all the diff and transfer case oils the other week since they hadn’t been changed in about 5 - 6 years, and Bas's reaction was like, “This is a waste of money.” 😂
19 hours ago, Monkey King Stu said:
Is this the same as Owner's Manual or different document?
Different, this is a manual meant for Mitsubishi authorized workshops
Like haynes manuals
Edited by Hyaenidae
