Iroshana Posted February 26, 2008 Posted February 26, 2008 Is there any difference in clutch plates of Nissan B13 petrol & diesel engines? Can anybody explain me the reason? Quote
0 gunat Posted February 26, 2008 Posted February 26, 2008 Definitely- load bearing specifically, since diesel has far more torque than a petrol engine. You'll find the clutch/pressure plate to be a whole lot more heftier than the petrol equivalent. Quote
0 Iroshana Posted February 26, 2008 Author Posted February 26, 2008 Definitely- load bearing specifically, since diesel has far more torque than a petrol engine. You'll find the clutch/pressure plate to be a whole lot more heftier than the petrol equivalent. Ah.. got it. Thanks dude. Quote
0 PKwilly Posted April 4, 2022 Posted April 4, 2022 On 2/26/2008 at 6:20 AM, gunat said: Definitely- load bearing specifically, since diesel has far more torque than a petrol engine. You'll find the clutch/pressure plate to be a whole lot more heftier than the petrol equivalent. Any consequences or limits if a diesel clutch disc is fitted into a petrol engine? Quote
0 iRage Posted April 4, 2022 Posted April 4, 2022 (edited) 19 hours ago, PKwilly said: Any consequences or limits if a diesel clutch disc is fitted into a petrol engine? Well..there technically isn't a thing called diesel engine clutches and petrol engine clutches. It is the same clutch, pressure plate, etc..difference is how much torque can be handled. A standard petrol engine would have a clutch that handles low amounts of torque and power whilst a diesel engine (lets say of the same model of car) would have a clutch that can handle higher torque. But then again, the same petrol car with a modified engine for high torque and power would have a clutch similar to the clutch the diesel engine car would have; one that can handle more torque. So..putting a clutch that can handle more torque (like in a diesel engine car) in a petrol car will not make that much of a difference except how it feels. You might feel that the clutch feels a bit heavy. If you do it the other way around you will have issues though. Putting a low torque handling clutch (like on a standard petrol engine car) and putting it on a high torque engine car, like a diesel, will actually lead to slipping and premature wear of the clutch. Edited April 5, 2022 by iRage 1 Quote
0 Twin Turbo Posted April 6, 2022 Posted April 6, 2022 The diesel is a 1.7 engine, therefore would make more torque. suitable upgrades would have been made by the manufacturer . TT. Quote
Iroshana
5 answers to this question
