​ Welcome Forum Guest! 👋 ​
Used / Brand New options for a 7 seater.
Hi everyone,
I am looking to buy a 7-seater vehicle with a budget of up to LKR 13 million.
After exploring the used vehicle market, I have shortlisted the following options:
  • Toyota Fortuner (2012–2013)
  • Mitsubishi Montero Sport (2012–2013)
  • Toyota Rush (2015–2020)
  • Suzuki Every
My preference is for the first three options. However, since the Fortuner and Montero Sport are relatively old and larger vehicles, I would appreciate some insights from owners or those who have experience with them, particularly regarding:
  • Maintenance costs
  • Fuel consumption
  • Common issues or known defects
  • Availability and cost of spare parts
  • Features and overall ownership experience
I am also considering migrating within the next two years, so resale value is an important factor. Ideally, I would like a vehicle that can be sold easily at a good price when the time comes. If there are any suitable brand new options within my budget, I would be grateful for your recommendations as well.
BTW @iRage & @amsandun thanks for your previous recommendation on my topic regarding Mazda Axela
Thank you in advance for your help.
I will comment on the montero sport as I have one since 2012
1. You will not get a good example for 13mil so be careful when searching, they have been rented as company cars are have clocked mileage etc. a good one will go near 15mil. I honestly don't care what the market is as I brought it for 5.7mil in 2012 and I don't intend to sell.
Do not buy anything off a govt. auction. do not buy a fixer-upper as parts are expensive you may need agent level repairs.
2. They are very reliable vehicles but keep in mind there are a few bits that need changing time to time such as the inhibitor switch, the suction control valve etc. Incase you buy one do not cut corners, manage with the agent as they are fairly competent with the montero sport.
3. Look for accident damage, plenty of wrecks around be sure investigate thoroughly.
4. Make sure the Timing belt replacement is done, if not done, expect a 250,000 cost to do it. Check the transmission for oil leaks as there is a periodic service where the transmission main shaft oil seal needs replacement. This is a 150,000 job.
5. They are not comfortable in stock form, but if you invest on good suspension and good tyres you can make it rather tolerable, remember this has a live axle in the back so there are limits. Less trouble but its not a sedan.
6. Fuel Efficiency, they are not fuel efficient, in an ideal context they need super diesel, but can run normal diesel with periodic injector cleaning. (City 2-4kmpl / Long Distance 10-15kmpl / Highway at 100 (11Kmpl)
7. The sweet spot will be a 1st to 3rd owner car under 200,000km. Run through the Super Select 4WD system, make sure all four modes work including center diff. Also make sure the manual shifter also works well. Engine overhauls to be expected near 500,000km (I have an L200 with the same engine and just wrapped up a rebuild)
8. Lastly if you are not into off roading, and mostly trotting around a city, you are better off with another car, but if you are into extending touring around the country, with family friends, sensible off roading etc. this would be the way to go.
They are heavy, strong, hardy, reliable cars and have a good road presence, very good grip and do wonders off road. One of the last body on frame suvs to touch the market.
If you have specific questions do ask, will help you out.
Edited by tiv
If it’s just a crossover that you are after and don’t really care about fuel consumption, considered a used DFSK Glory I-auto. 7 seats and you can get lightly used examples for under well under 10 mn that are in great shape and some of them still are under warranty. They have tons of space. They don’t have a lot of value in the second hand market so bargain hard. I had one and sold it off in within one month of advertising.
This is a great amount of information for someone wanted to buy Pajero Sport/ Montero Sport or L200 on the same platform.
AFAIK, I had no vehicle with the 4D56 CRD variant, but plenty with 4N and 4M, they all suffered the same EDG clogging.
@tiv Have you had to clean them on your's or have you blanked them?
@Night Fury , how about some alternatives?
Mitsubishi Outlander - Petrol version
Hyundai Santa Fe/ Kia Sorento - Diesel version with 7 Seats
Toyota Prado TRJ120 (A little off your range, but holds its value)
Bonus suggestion: Prius Alpha/ Toyota Estima (Only because you have mentioned Suzuki Every)
I believe all of the models I have mentioned are easy to sell in Sri Lanka, specifically the ones with the TOYOTA badge, but please ignore my suggestions if they are not within your criteria.
Toyota Fortuner:
My experience with the Toyota Fortuner is with a later-model version equipped with the 1GD diesel engine here in New Zealand (I believe it was a 2019 model).
With your budget, I think you'll most likely be looking at the petrol variant with the 2.7L engine in Sri Lanka.
The Fortuner still shares its platform and running gear with the Hilux, so the mechanical components are generally proven, durable, and parts should be relatively easy to source. I also believe the same 2.7L engine was used in the Hiace vans. Correct me if I am wrong.
I'm not entirely sure about fuel consumption, but I wouldn't expect it to be particularly economical. From memory, it may be around 5–6 km/L, but please don't quote me on that 😁.
Pros:
  • Solid build quality
  • Excellent commanding driving position
  • Very capable off-road
Cons:
  • Body panels and exterior parts may be harder to find, so it's worth checking parts availability before committing to a purchase.
  • The ride quality is on the firmer side.
  • The third-row seats are best suited for children, as legroom is quite limited for adults.
  • Not easy to sell here in NZ, I believe I have done an exchange for another vehicle at the end. 😂
On 6/5/2026 at 7:44 PM, Night Fury said:
Hi everyone,
  • Suzuki Every
  • Maintenance costs
  • Fuel consumption
I can comment on the 2012/2013 Fortuner. Had one in Vietnam. It was a gulf spec AWD  2.7L petrol with the 2TR engine and had the H and L range transfer case.
Trouble-free truck. Had it for four years, and the only thing that went wrong with it was that the ABS light came on because the relay was going bonkers. The relay went bonkers because the window switch got wet, causing a small short that in turn made the fuse box act weird. Go figure. Nothing had to be replaced....the Toyota dealer just cleaned everything, and that was it.
Didn't do anything other than regular maintenance like oil changes.
Fuel consumption...well got about 7kmpl...which was not too bad for its size.
Performance wise...it was not too bad for city driving and on the open road it managed to keep up at highway speeds. Gets a bit gutless after about 120kmph. Same engine is in the Prado 150 (and 250 aftr some updates) and it was a lot better than that. If you can..what you should get is the diesel. Feels very industrial but has tons of torque.
Comparatively the Montero sport (friend had it in Vietnam) the engine is a lot more potent (granted in VN it came with either a 3.0 petrol V6 pushing about 220hp or a 2.5L diesel with 170 or so hp).It literally left my Fortuner in the dust. I found the ride and the interior of the Fortuner more refined. The Montero sport felt a bit too jittery...and for that market the interior seats materials, etc felt a bit too synthetic. My Fortuner had cloth seats.
The Fortuner felt like it was made out of sardine cans...the Montero Sport felt like it was a tank. The doors, and bonnet and body panesl felt very think and solid compared to the Fortuner.
Features and specs....the Fortuner came in quite a few specs depending on the market. So you get full-time AWD variants, 2WD variannts, ones with lockers in the rear, ones with center lockers..the list goes on.
Thank you!
About 60k into buying my Montero Sport, the dreaded EGR clogged issue came, decided to blank it off ever since.
The same with my L200, no CELs, managing well
  • 2 months later...
  • 1 month later...
