Oh well... the bulletproof toyota has been giving me a bit of a bad run lately...
firstly it was the ECU and the Delco/Distributor... then it was the AC cooler that developed a leak and needed replacement and now...it's my damn power steering rack
It all began after me going for my first set of wheels... the bulletproof toyota corolla, a sprinter...
Born 93 in Japan and junked to SL in 97...
I had a small leak in power steering fluid even when i bought the car 2 years ago but many told me just a top up would suffice and nothing bad would happen...
all was ok until recently the leak became a bit too much and top ups were way too frequent...
after noticing a torn rack end boot...thought of addressing the issue once and for all...
Last week i took it to a garage that's owned by a friends dad... and he said the busted boot has wasted my rack ends...
and also the rack was leaking so a rack repair kit was on the cards...
2 days and 25k later...got the car back... Ran good for few days and didn't bother to check the power steering fluid level expecting the problem was fixed
yesterday i found out it wasn't after noticing a tell tale oil patch on me garage floor...
with the aid of a four celled torch and some creative inspecting techniques... found out that the bloody rack is leaking oil yet again...
It has outdone itself and now leaking from both ends when previously it only leaked from the driver's side....
Now me garage fella is telling me to get a recon/used rack and come for a replacement
First few calls to used parts shops that i had numbers for didn't work since they didn't have it in stock... wanted to know rough pricings
In your opinion... what would be the best course of action?
should i try to fix the present rack? or go for a used one from delkanda area?
According to friends, used rack sellers will only take a return within a day or 2 if found to be faulty... and as far as i know...you really can't check the integrity of a rack from outside before fixing to the car and running it... and god knows when that things gonna go bust also
On repairing the present rack, i was told that the mechanic has bought a "rack repair kit" (HellRazor, i know what ya thinking but this aint that) and had done some lathe work...
so i dunno what more can be done to make the present one not leak... Now the mechanic is saying the main shafts must be worn and not the washers that he replaced...
Odd enough that except for the leak i didn't have any issues before... The oil was good in color without any metal flakes etc in it... So dunno how the shaft can go bad like that...
My guess is that either the "repair kit" was not the one for my model or the workmanship during assembly was bad...
Ripper
Either way i'm not a happy camper
help!
12 answers to this question
