Madhurades Posted November 8, 2009 Posted November 8, 2009 Hi.there. I.bought.an.EK3.1999.multimatic.recently.but.it.is.very.bad.on.petrol.I.took.it. to.Stafford>Motors.and.got.an.Engine.tuneup.done....now.it.does.8kmpl....but.Ihear.people .saying.that.it.should.do.at.least.10kmpl....Should.I.do.an.injector.nossle.clean up.and.a.tapet.clearance.adjustment...Please.help.. Thanks Mds Quote
Az Posted November 8, 2009 Posted November 8, 2009 Hi.there. I.bought.an.EK3.1999.multimatic.recently.but.it.is.very.bad.on.petrol.I.took.it. to.Stafford>Motors.and.got.an.Engine.tuneup.done....now.it.does.8kmpl....but.Ihear.people .saying.that.it.should.do.at.least.10kmpl....Should.I.do.an.injector.nossle.clea n up.and.a.tapet.clearance.adjustment...Please.help.. Thanks Mds Is the space key on your machine broken? Quote
miniace Posted November 9, 2009 Posted November 9, 2009 (edited) Bad fuel consumption is a result of Bad car set up / bad driving or both.If you are sure of the driving part,need to re-do the tune up from another place and see.This is harsh- but the fact is ,I came a cross two cars Ill-Tuned by local agents recently. MINIACE Edited November 9, 2009 by miniace Quote
Chris0628 Posted November 9, 2009 Posted November 9, 2009 Hi Madhurades.... join the club ... mine ia 2000 Exi & does only abt 7.7 - 8.5 in colombo & abt 10.5 to 11 out station.... tried tuning @ agent... then from Upul & Rohan but no luck..... is your gearbox in good condition ?? Quote
VPJ Posted November 9, 2009 Posted November 9, 2009 Hi Madhurades.... join the club ... mine ia 2000 Exi & does only abt 7.7 - 8.5 in colombo & abt 10.5 to 11 out station.... tried tuning @ agent... then from Upul & Rohan but no luck..... is your gearbox in good condition ?? chris , you got your gearbox sorted out? Quote
Supra_Natural Posted November 9, 2009 Posted November 9, 2009 Hi Madhurades.... join the club ... mine ia 2000 Exi & does only abt 7.7 - 8.5 in colombo & abt 10.5 to 11 out station.... tried tuning @ agent... then from Upul & Rohan but no luck..... is your gearbox in good condition ?? dude, if its an AUTOMATIC, thats about the figure you can expect in real world city driving. Quote
Chris0628 Posted November 9, 2009 Posted November 9, 2009 Hi Madhurades.... join the club ... mine ia 2000 Exi & does only abt 7.7 - 8.5 in colombo & abt 10.5 to 11 out station.... tried tuning @ agent... then from Upul & Rohan but no luck..... is your gearbox in good condition ?? not yet machan.. Rohan said to run with it till it gets really bad... :-) then i will go with him & get another gearbox & replace it :-) Quote
Chris0628 Posted November 9, 2009 Posted November 9, 2009 dude, if its an AUTOMATIC, thats about the figure you can expect in real world city driving. Well.. lot of ppl said the Exi should do @ least 9.5 to 10 in colombo.. so does the Agent, Upul & Rohan as well.... when i did the computerized test @ the agent .. they said the issue is due to the Injectors been open for longer than usual.. in my case the injectors are open (In idle mode) 3.4ms instead of 2.7 to 2.9ms Quote
VPJ Posted November 9, 2009 Posted November 9, 2009 Well.. lot of ppl said the Exi should do @ least 9.5 to 10 in colombo.. so does the Agent, Upul & Rohan as well.... when i did the computerized test @ the agent .. they said the issue is due to the Injectors been open for longer than usual.. in my case the injectors are open (In idle mode) 3.4ms instead of 2.7 to 2.9ms so didnt they suggest you a solution? Quote
VPJ Posted November 9, 2009 Posted November 9, 2009 not yet machan.. Rohan said to run with it till it gets really bad... :-) then i will go with him & get another gearbox & replace it :-) you took the car to upul for gearbox issue? Quote
Chris0628 Posted November 9, 2009 Posted November 9, 2009 so didnt they suggest you a solution? agent said to replace the ECU :-) Quote
Chris0628 Posted November 9, 2009 Posted November 9, 2009 you took the car to upul for gearbox issue? no machan.... bit tired of taking the car for checks & tune-ups & not getting any results.... gonna run like this & when it get really bad, then i'll check again :-) Quote
MkX Posted November 9, 2009 Posted November 9, 2009 Well.. lot of ppl said the Exi should do @ least 9.5 to 10 in colombo.. so does the Agent, Upul & Rohan as well.... when i did the computerized test @ the agent .. they said the issue is due to the Injectors been open for longer than usual.. in my case the injectors are open (In idle mode) 3.4ms instead of 2.7 to 2.9ms Dint we had the same issue discussed there with ES5 or ES8 model, and agents also unable to solve it, any idea what happened to that case. Quote
Chris0628 Posted November 10, 2009 Posted November 10, 2009 Dint we had the same issue discussed there with ES5 or ES8 model, and agents also unable to solve it, any idea what happened to that case. No idea.... but these are the days where the fuel economy really matters.. with all these fuel strikes.... Quote
Madhurades Posted November 21, 2009 Author Posted November 21, 2009 Is the space key on your machine broken? That's 100% true machan, recently only I managed to fix my space bar.......... Quote
Chris0628 Posted November 22, 2009 Posted November 22, 2009 hey guys... did anyone manage to get the fuel issue fixed ???? Quote
prvnrox Posted November 23, 2011 Posted November 23, 2011 guys try changing the plugs and then do a tune up.hope it will help!! cheers! Quote
Edward Posted November 23, 2011 Posted November 23, 2011 Are we sure when we buy a liter of petrol, one liter is pumped in the tank? We always get cheated by the petrol sheds. Change the shed for one instance & check once more. I am speaking of my experiance. Quote
The Stig Posted November 24, 2011 Posted November 24, 2011 hey guys... did anyone manage to get the fuel issue fixed ???? :cough: :cough: uhem Mr ! you just replied to a 2 year old thread, dont you think the op would have found a solution by now ? Quote
sira Posted November 25, 2011 Posted November 25, 2011 Hi.there. I.bought.an.EK3.1999.multimatic.recently.but.it.is.very.bad.on.petrol.I.took.it. to.Stafford>Motors.and.got.an.Engine.tuneup.done....now.it.does.8kmpl....but.Ihear.people .saying.that.it.should.do.at.least.10kmpl....Should.I.do.an.injector.nossle.clean up.and.a.tapet.clearance.adjustment...Please.help.. Thanks Mds Please check the correct timing - it should be 12 _+ 2 also check the exust pipe colour - if its too black with carbon powder, looks fuel consumption is bad. Quote
Toyota1990 Posted December 15, 2011 Posted December 15, 2011 try not to exceed yo RPM over 2000. if it can do 13-14 outstation with AC, then I dont think there is a problem. but you cant expect 10-11 kmpl in city traffic bro Quote
Crosswind Posted December 15, 2011 Posted December 15, 2011 (edited) I heard that the guy who originally posted this thread has sold his car, gone to thailand, got hooked to a tranny, migrated to Lithuania and now living happily ever after in Limpopoland with his two kids and a puppy named Toyota. For heaven's sake this is an OLD thread! Stop trying to solve ancient problems. PS. No offense Madhurades Edited December 15, 2011 by Crosswind Quote
