July 31, 20179 yr 3 hours ago, The Stig said: Usually outer wear is related to underiflation. You sure that you maintained tyre pressure at recommended psi right?ย That's what i thought too. But I check it every 2 weeks. All tires had lost about 3psi on average when I check.
August 3, 20179 yr On 7/31/2017 at 7:52 PM, c1nder said: That's what i thought too. But I check it every 2 weeks. All tires had lost about 3psi on average when I check. Try replacing the tyre valves
August 3, 20179 yr 23 minutes ago, jerryda said: Try replacing the tyre valves Can you explain how that will solve the issue?
August 4, 20179 yr ย On 8/3/2017 at 0:00 PM, Davy said: Can you explain how that will solve the issue? Loss of about 10% loss or 3 PSI of air pressure every two weeks seems a lot. It may be from the tyre valve. ย http://tiresciencetechnology.org/doi/abs/10.2346/1.2150984?code=tire-site&journalCode=tist Edited August 4, 20179 yr by jerryda
August 4, 20179 yr 3 hours ago, jerryda said: ย Loss of about 10% loss or 3 PSI of air pressure every two weeks seems a lot. It may be from the tyre valve. ย http://tiresciencetechnology.org/doi/abs/10.2346/1.2150984?code=tire-site&journalCode=tist Valve Replacement Since rubber deteriorates over time and tire valves are not expected to resist deterioration for the life of two standard tires in normal service, tire valves should be inspected and replaced if any cracking appears. As a rule of thumb, the industry recommends replacing tire valves whenever new tires are installed. While Track & Competition DOT tires may only last several weekends on your track driven racecar, the metal clamp-in tire valves should be replaced every other year because the heat transmitted to the wheels from the brakes is significantly greater than that experienced in normal service.
August 4, 20179 yr 7 hours ago, jerryda said: ย Loss of about 10% loss or 3 PSI of air pressure every two weeks seems a lot. It may be from the tyre valve. ย http://tiresciencetechnology.org/doi/abs/10.2346/1.2150984?code=tire-site&journalCode=tist That isn't the main issue but I'd say that loss is normal. I've experienced that in all my past cars
August 4, 20179 yr 15 hours ago, jerryda said: ย Loss of about 10% loss or 3 PSI of air pressure every two weeks seems a lot. It may be from the tyre valve. ย http://tiresciencetechnology.org/doi/abs/10.2346/1.2150984?code=tire-site&journalCode=tist Loss of pressure isn't the issue here. It's chunking as seen in the photo above. And under-inflation usually causes even wear close to the sidewalls of the tyre. Also, the article in your link says 1.5 PSI loss is for 32C ambient temperature which applies to car that sits in a garage all day. An asphalt road can heat up to twice that much which is more likely what applies to a car that's driven daily in the hot Sri Lankan climate. As the article correctly says, ย this heat causes exponential air loss. The remedy is to check and maintain tyre pressure weekly.ย
