Accident repair garage + Insurance claim
Just curious, what exactly did you observe at Sha? Was it recently? When I got my jobs done, it was only a few months since they had setup shop and the men who worked there were pretty good. Back then, body repairs were headed by a guy (painter, tinkerer, panel beater) who had worked in the middle east for many years + who had German Tech certification. I don't remember his name now, but I can vouch for his work because I never set my eyes off my car during the month it was there and I was more than satisfied with how the job turned out. Maybe he has left. One of my neighbours also submitted their car to this place after it was badly rear ended. And they did so on my recommendation. I saw the car after the repair and they had done the job to perfection.
- Lancer Cs3 Double Din Conversion
Nissan B211 Restoration
WoW! Great work! Please share details about what you have done for the car besides the bodywork.
- Motoring Scams In Sri Lanka
Sorry to hear about the accident. Looks like you'll have to replace the tailgate, bumper and tail light + straighten out the inner panels behind the bumper. 2. Try "Sha Auto Park" Kaduwela. They're work is pretty good IMO. Got a full paint job done once and some other minor body repairs. I had SLIC and all I had to do was submit the car and collect it after the repair. Google for their website & directions. Note that this was during the 2011 - 2013 period, but I think they are still operational.
What is Best vehicle with the Best resale value ?
What's funny is the topic title saying "among these vehicles" while the 5th option in the list is "Other vehicle?" Sorry, couldn't help it.
- RPM goes down after long runs
Japanese Car News
The body style is different for Lancers some Asian countries. China, VietNam, Taiwan etc. Was the same for the CS Lancer.
- DIY steering wheel skin/cover
Modern airbag systems are smart enough not to deploy spontaneously. The G sensor on the car needs to receive a signal in order to set off the airbag(s). So, unless there is a fault in the system, airbags will not deploy. On the CS Lancer, the G sensor is behind the dashboard, towards the centre of the car.
Windows Task Scheduler Does not work
If there are rules against leaving equipment plugged in, surely there must be rules against downloading pirated content using the office network.
- Autolanka Rc Build Thread
Paint shop
Welcome. Please search the forum. So many discussions about bodywork and paint shops.
Ford Laser - Re-Condition Gear Box
What have you done so far on the transmission that didn't work and convinced you to go for a replacement? Have you done a proper ATF change at least? When oil seals inside the transmission harden due to age or if your transmission fluid is bad, these symptoms can happen. A proper automatic transmission expert should be able to overhaul yours for you.
Remote Key Replacement Toyota Hilux 2007
Welcome to the forum. If all you want is the key housing, you can try eBay.
Toyota Passo (kgc30) Transmission "D" blinks.
Welcome to the forum and sorry to hear that you were affected by the floods. When you said that the water level was up to the tyres, what exactly do you mean? Half of the wheels submerged? It's really difficult to say what's really wrong with a flood damaged car. Given that your ECU was fried, it might be an electrical fault or an issue with the transmission itself. Have you tried getting the ATF inspected to see if water has somehow reached inside the unit? Also, I advise cleaning all the connectors that lead up to the transmission (actually, all of them that were unedr water) with contact cleaner before even attempting to start the car.
Powe steering Oil Leak
There obviously is a leak in your power steering box which explains the oil being splattered all over the place. The oil probably leaks out when when the pressure inside the system exceeds a certain amount. So this may not happen when the engine is idling. You should turn the steering from lock to lock while revving the engine to see if there's actually a leak. It should be an oil seal as Dushyantha mentioned. The power steering pump and rack (in this case "box") should never run without oil. If done so, excessive heat and friction will damage them. So you should get this fixed before you use the car.
Acceleration - Lancer C12
That's not a catalytic converter. That's a flex pipe used to minimise engine vibration onto the exhaust system. The C12 doesn't have a cat according to my knowledge. At least not the ones we get in Sri Lanka. On the subject of exhaust blockage, if it were the issue, there would be a noticeable increase in your engine temperature and high fuel consumption. Also, according to the eco test report, the exhaust probe seems to have picked up readings that appear to be normal for this type of car. A blockage would have skewed the results.
Welcome to the Upgraded AL Forum 2016 !!
Yes! That seems to have fixed it.
