Everything posted by PerfMad
IMA battery warning on GP1
If you are seeing this icon , then it says (as per translation) -> Lights when the 12V battery is not charged. What to do when it lights up -> Turn off air conditioners and etc to reduce electric consumption. Then , immediately contact your honda dealer for repair.
This could be mostly due to IMA blower fan malfunction or not functioning at all. What is the current millage? because these tend to give away when its closer to 100k km. Get a scan done and you'll get to know the exact issue. I would prefer a brandnew motor if that's the case cz it will be good for another 100k since you are not aware of the millage of a recon one. Note: Damn, just realized i was replaying to a 2 year old post (rofl)
මොවුන්ගෙන් Shock Absorbers මිළදී ගැනීමේදී ප්රවේසම් වන්න
Just to clarify something. So your car is an insight and they gave you shocks of GP1 FIT? Just curious because I also own a GP1 and I might face the same issue someday.
Oil
I don't think so. Because a friend of mine is using the car for like 5+ years and is being running on 10w-30 oil and have clocked 130k. Still running smooth. And I was advised the toyota 10W-30 oil is better for GP1
Oil
I'm having a GP1. I was using 0W-20 as this is what's been used by the previous owner. But stafford advised me to change to 10W-30 considering the environmental factors of SL.
Paint callipers and drums with TOA spray
Thanks @Davy 👌
Thanks for the complement.. well in that case its an easy job. Ya doing it with one jack is quite tiring .. had body aches for couple of days as well
agreed. For a moment i thought the same. But then thought if it goes wrong i might not have enough time to get it sorted since i did it during lock down period and the nearest garage was also closed
Actually I did it during a weekend. You can remove the calipers, but its a pain to reassemble if you don't have proper tools. Instead you can cover every aspect. I had alot of news papers laying around so i covered one side fully including inner covers before spray painting the calipers. Even the brake calipers and nuts, bolts and rubber parts were covered before applying the paint to make sure non of the unwanted areas were covered in paint. So if you prepare well, then less rework after paint job. You can watch couple of DIY youtube videos to get an idea about how to cover up things. Rest is your creativity I did some rendering before painting the wheel caps to see which would suit better and then applied the selected one. Painting the Honda LOGO was the difficult part (as you may have seen how much effort was put to mask it out and get it painted. + even after the masking is removed I had to take a small brush and do few touch ups here and there. If you have multiple jacks, its easier to apply paint at one go. But since i had only one jack, i had to attend one after another. So I had to cover one side per day (including wheels, hubs, calipers and all)
Nothing to be worried. But before you apply spray paint make sure to prepare the things you are going to apply. I would suggest to take probably 800 and 1000 sand papers to clean the dust and rust in brake calipers and drums. Then you can cover the other area and apply 2-3 paint coats (as much as you want until you are satisfied with the job). Make sure to read the instructions and keep 15-20 mins intervals after each spray turns. I haven't personally done the tappet. If its alloy, you might need to use some paint adhesion to make sure the paint stick to it. If its steel kinda material it would be pretty straight forward like the calipers and drums i guess. Even i tried mine for the first time and it came really well. But took good 2 days and another week with some body aches here and there. I would say still worth it Good luck with your DIY. Given below are few snaps of mine.. Please update the thread as well if time permit.
2 Million Budget car - 2021 ( Uber/Pickme )
Uber allows vehicles upto YOM 2000 to get registered now. I guess due to pandemic.
IF you prefer fuel saving and low maintenance cost, ALTO is ideal solution (indian alto) Panda is good in terms of safety, but vehicle is too low, not fuel efficient compared to alto and neither low on maintenance cost. So based on that you don't have much choice. Better go with an alto. Since you're planning on using it as a taxi thats the most viable choice.
- Nissan Presea
Honda gp1
that may have adverse affects in highspeed cornering. if ur a slow driver it would be ok i guess.
Honda gp1
depends on what you plan on doing to increase the height.. You can increase the tyre size diameter and see.. however there will be a significant reduction in fuel consumption
Honda fit shuttle change language from japanese to english
You're welcome
you can't unless it's an export model which has the option to change the language via menu. Im also having a GP1 domestic model so it doesn't have that option. Only thing you can do is, use the mobile translator app and translate it real time.
SAE 40
If the car belongs to oil burning chassis range, i dont see a point in increasing the velocity as it is a temporary solution. Better get it rectified asap. May i know the current millage of ur car if you don't mind? Also i believe you car is registered in 2014, cz GP1 series stopped after 2013. from 2014 GP5 manufacturing started.
First Service (CRV) - Mineral or Synthetic Oil
Could be true. I did my service today from agent for the 2nd time after purchasing the car and the filter price has almost doubled on my FIT. However, still using 0w-20 on the car as it still doesn't burn oil and same oil has been used since day one.
Recommended tyre brand for honda fit GP1
exactly . I think i run on the same too. Cant remember the exact code though. Bought 2 for around 35k 3 months ago
Dunlop jap
- Nissan Presea
- Nissan Presea
- Honda Civic FD1 Maintainance (DIY)
