March 11, 201313 yr Author Hi Guys Brought these stuff from pioneer motors Ignition coil with resister ignition condensor spark plug wireset spark plugs Contact point carburetor repair kit fuel filterReassembled the Starter Motor Cleaned the stator and armature and will be installing a new set of brush set soon,and found viper motor was in good condition i used it sparingly it used to stuck the moving arms alwaysand reassembled the carburetor with rebuild kit with factory specs jets.Had to put little putty on minor scratches found on the behind and behind doors together and wet sanded them to the smoothest possible,found that the filler primer was not enough thick to keep it strong enough when sanding and found my gun tip was smaller than paint manufactures specs ,no problem there will be another complete filler coat later on,so had to put a little oil primer on those areas to avoid them get rust by next week end i got pics but there is no way that i can upload them today i will see whether i can upload them later, No other way to show them here they are http://imageshack.us/photo/my-images/201/11608463.jpg/http://imageshack.us/photo/my-images/687/34537151.jpg/http://imageshack.us/photo/my-images/203/86937126.jpg/http://imageshack.us/photo/my-images/33/57048537.jpg/http://imageshack.us/photo/my-images/833/11650744.jpg/http://imageshack.us/photo/my-images/823/77828462.jpg/http://imageshack.us/photo/my-images/405/79517959.jpg/http://imageshack.us/photo/my-images/96/50220899.jpg/http://imageshack.us/photo/my-images/9/91925378.jpg/http://imageshack.us/photo/my-images/402/85540395.jpg/http://imageshack.us/photo/my-images/713/94722270.jpg/http://imageshack.us/photo/my-images/827/63334772.jpg/http://imageshack.us/photo/my-images/163/33251585.jpg/ thanksregardssumith Edited March 11, 201313 yr by Sumiya
April 1, 201313 yr Author Hi Guys Few updates on the last week end stuff http://imageshack.us/photo/my-images/203/13675309.jpg/ http://imageshack.us/photo/my-images/15/29315937.jpg/ http://imageshack.us/photo/my-images/32/47868724.jpg/ http://imageshack.us/photo/my-images/163/37430046.jpg/ http://imageshack.us/photo/my-images/90/70200800.jpg/ http://imageshack.us/photo/my-images/585/37095820.jpg/ http://imageshack.us/photo/my-images/521/91006345.jpg/ http://imageshack.us/photo/my-images/706/94654526.jpg/ http://imageshack.us/photo/my-images/834/26813120.jpg/ thanks regards sumith thanks regards sumith
April 1, 201313 yr Machan post the "direct URL" link in the photo box. That way the photo loads on the page as we open it. Great to see some progress tho. Was wondering why this was Silent for some time Edited April 1, 201313 yr by Komisiripala
April 1, 201313 yr Hi GuysFew updates on the last week end stuff http://imageshack.us/photo/my-images/203/13675309.jpg/ http://imageshack.us/photo/my-images/15/29315937.jpg/ http://imageshack.us/photo/my-images/32/47868724.jpg/ http://imageshack.us/photo/my-images/163/37430046.jpg/ http://imageshack.us/photo/my-images/90/70200800.jpg/ http://imageshack.us/photo/my-images/585/37095820.jpg/ http://imageshack.us/photo/my-images/521/91006345.jpg/ http://imageshack.us/photo/my-images/706/94654526.jpg/ http://imageshack.us/photo/my-images/834/26813120.jpg/ thanks regards sumith thanks regards sumith Machan try to straighten out the body lines a bit more. I can see some really awkward points around the body and around the boot specially where the number plate fits on. Hope all goes to plan and we can see a tidy car soon. Edited April 1, 201313 yr by NZer
April 22, 201313 yr Author Hi NZer Thanks for the ideas , yes i have noticed them already , i got to to do a lot since it has major fabrication on it , Just going on to those areas slowly with smoothing the pannels, this is just a basic filler code to identify minor imperctions and so ,Most pobebly i might finish alignment pannels and extra filler coat on this week end. Brought Few Littres of Base coat to match with Debear (Toyota 8L5) top coat plus debear clear coat, i cant linked photos direct to the forum as earlier it says " you are not allowed extension on this comunity" i don't know what it is and don't need to bother about even http://imageshack.us/photo/my-images/577/81411523.jpg/ http://imageshack.us/photo/my-images/545/26268167.jpg/ http://imageshack.us/photo/my-images/11/21589619.jpg/ http://imageshack.us/photo/my-images/20/90153493.jpg/ thanks regards sumith
April 23, 201313 yr For some reason i cant see any of the images. When you click on the link it takes you to an advert but there's a "continue to your image" link on the right side of the screen which will take you to the image. Frustrating, isn't it?
April 23, 201313 yr When you click on the link it takes you to an advert but there's a "continue to your image" link on the right side of the screen which will take you to the image. Frustrating, isn't it? Just login to imageshack to avoid having to do this.
April 23, 201313 yr When you click on the link it takes you to an advert but there's a "continue to your image" link on the right side of the screen which will take you to the image. Frustrating, isn't it? Jaliya thanks heaps machan. Was totally trying to work it out with no progress till you showed me how. Thanks heaps Macho
April 23, 201313 yr Hi NZerThanks for the ideas , yes i have noticed them already , i got to to do a lot since it has major fabrication on it , Just going on to those areas slowly with smoothing the pannels, this is just a basic filler code to identify minor imperctions and so ,Most pobebly i might finish alignment pannels and extra filler coat on this week end. Brought Few Littres of Base coat to match with Debear (Toyota 8L5) top coat plus debear clear coat, i cant linked photos direct to the forum as earlier it says " you are not allowed extension on this comunity" i don't know what it is and don't need to bother about even http://imageshack.us/photo/my-images/577/81411523.jpg/ http://imageshack.us/photo/my-images/545/26268167.jpg/ http://imageshack.us/photo/my-images/11/21589619.jpg/ http://imageshack.us/photo/my-images/20/90153493.jpg/ thanks regards sumith Machan are you doing the work yourself or getting someone to do it?
April 24, 201313 yr Author Hi Nzer I am doing them my self along with the help of my father as i am free on the week ends,My Father is sound with Mechanicle stuff and we both did fabrication together as none of us was very good on them , all the rest will be doing my self except Upholestory work thanks regards sumith
April 24, 201313 yr Nice thread! But the first few pics I could view but now I cant see them anymore! Good Luck! Here are a few pics for inspiration!
April 24, 201313 yr Machan take my advice and seek help from a professional. Otherwise the body will look like the sea. From what i see at the moment its needs huge work to come out right. I really like your project hence the advice. Good luck
April 24, 201313 yr Author Hi Nzer Thanks, So far have lot of dudes helping me from datsun community all arround the world since that i came so far good because this is ever my first rebilding project and this is not my job just a hobby , i will not be able to take it perfect to 100% but i will try to be somwhere 90% but from my next rebuild i will try to be 99% on because i have gathered so many expierienc have done lof of mistakes made and corrected ,probebly next will be my b310 or Morris 1100 MKii thanks regards sumith
April 26, 201313 yr Author Hi OctaneHead thanks dude , the car that you posted is already my desktop background i love it's color and it is little buffed out and modified a little to give it a sporty look here is the factory specs car enjoy it http://imageshack.us/photo/my-images/837/originsl.jpg/ thanks regards sumith Edited April 26, 201313 yr by Sumiya
April 26, 201313 yr Hi OctaneHeadthanks dude , the car that you posted is already my desktop background i love it's color and it is little buffed out and modified a little to give it a sporty look here is the factory specs car enjoy it http://imageshack.us/photo/my-images/837/originsl.jpg/ thanks regards sumith Looks lovely. I'd aim of this look personally! Off topic, but I have seen a beautifully restored pastel blue Sunny B310 with its original wheel caps around Bambalapitiya on a daily basis. I think it has a 12SRI number. Edited April 26, 201313 yr by Jaliya48
August 23, 201313 yr Author Hi GuysAfter a long time back on the project , Just had a color code on air cleaner and rocker cover an top grille, happy the way it came for the sunshine it is bright an when dark it looks gloomy,Planing for the first base coat on this week end http://imageshack.us/photo/my-images/577/cueq.jpg/ http://imageshack.us/photo/my-images/854/3gpb.jpg/ http://imageshack.us/photo/my-images/836/9hc2.jpg/ thanksregardssumith
August 23, 201313 yr good job man keep us posted,is blue the color of the car as well? Hi GuysAfter a long time back on the project , Just had a color code on air cleaner and rocker cover an top grille, happy the way it came for the sunshine it is bright an when dark it looks gloomy,Planing for the first base coat on this week endhttp://imageshack.us/photo/my-images/577/cueq.jpg/ http://imageshack.us/photo/my-images/854/3gpb.jpg/ http://imageshack.us/photo/my-images/836/9hc2.jpg/ thanksregardssumith
