Recently I replaced my front tyres due to excessive side wear.
When I went to check alignment both the Pitstop and my usual place asked to replace front the tires as setting the alignment in that condition was not a good thing. Anyway the car was pulling to a side very badly.
So I changed the tires and set the alignment at Pitstop but the car is still pulling to a side. When I asked the pitstop guy told that my caster is a bit out on the left wheel and that's the reason for the pull and I believe he is right.
But my usual alignment place at panadura set alignment using a side slip measuring machine. When the car is driven over it, it shows how much the car is pulling to a side and then they adjust the car so that it's not pulling to a side.
And then I found this on a forum
Quote
When you send your car for wheel alignment, it is done at static. The mech will check toe angle, toe angle on turn, camber and caster angle. That is only for the front wheels. If you are doing 4 wheels there are more complicated checks to be carried out.
Unless you car has suffered undercariage damage or the rear suspensions are just replaced, then it is necssary to do a thorough 4 wheel alignement ( unless offcourse yr ride has 4 independent suspensions)
Car will still sometime pull to the left or right (side slip) even the wheels have just been adjusted using computerised alignment machine. This is because the whole adjustment excercise is been carried out at static without taking in consideration wheel bearing conditions, tie-rod conditions ,tyre wear conditions etc. The reading are perfect but in actual rolling the wheel sometimes still develop lateral pulling force.
So to detect and overcome these lateral pulling force, it is best to drive the car over a side slip tester (tester with moving plate(s))If the reading show either within -5m or +5m then yr wheel slip is not that bad. The mech can make minor adjsutment on the toe angles to offset the pulling and do a re-test. Most customers always insists on the side slip tester meter to read "0".
So I guess if I set the alignment using the side slip machine they'll be able to correct the pulling issue with it where as Pitstop's computerized machine only checks the static alignment.
So experts, what should I do ? btw the castor is not adjustable on my car (CE110) and this pulling is driving me nuts.
Amila G
25 answers to this question
