can anyone tell me if there is anyway to know whether your engine mounts are worn out.....my car vibrates a lot in high speed after 70kmph....is this because of worn engine mounts.but other speeds at below 60 is perfect...
check the tyers if its new no problem same thing happend to me when i checked the tyere had a buble cant be the prop shaft if it has a problem when u pickup it gives a clunk sound
guys i did a recent modification to the carb i made the secondary jet to open manually(originaly its vaacume operated) and remowed the chocke plate now when u sqeese the throttle its pickups like a turbo and rpm goes above 8000(meter shows only 8000)
Any update on the tail lights? If I were you, I'd lose a lot of sleep on that.
found original tail lights but its not in good condition so im thinking twice .today shit thing happend i wanted to change the oil plug when im tightning it, the housing splited fortunatly i m having a spare one tomorrow i have to replace it
machan with this config your would be drinking a lot of fuel right?
thats according the way u drive cos if u sqeese 3/4 of the padel then only the secondary part opens then the car drinks,if not if u drive with mild padel then car does the normal milage its all about controlling the accelarator
If you ask me to pick the best japanese saloon of that vintage it would be the datsun bluebird 510. all independent suspension, unlimited modifying possibilities, even with modern parts. But that's just my opinion.
Damn! I have seen a 510 in our office car park in great nick, a 6 Sri one :)
Pic pls... Could be the same one I saw at the motorshow.
Didn't see it for the past few weeks machan
Good heavens! Those tail lights have got to go... So this is "L light" right? I captured the photo below from the Panchikawatta scrap yard in 2010 when I was looking for a wire harness for my A72. There are many scrapped A72 cars out there and you can find a lot of used parts which are removed from them rather than do what you've done to your car. I bought my front disks, wire harness, steering box, servo, tailgate spring, front grill support brackets and many more parts from this place.
If you're lucky, you will find a good set of tail lights.
If you don't know the area to look for, let me know. I will PM you the details.
davy can you PM me the place please
  • 7 months later...
guys now i am going classic i retored my a72 to the original condition removing spoiler and rear skyline tail lights
Sounds great! Would love to see more photos.
