December 27, 20169 yr 4 hours ago, vpsupun85 said: Thank you Davy for the PM. And I've a quick question for ya and others. What would be the effect (specially, speedometer and economy meter ) on having a tire/rim set with a bigger diameter than stock ? As I've mentioned in the PM, the difference in diameter between your stock rims and the ones you're going to purchase is negligible. So the effect on the speed 'o meter will be too small to worry about. Your current rim has a taller sidewall, but the 18 inch rims have a shorter one (lower "profile"), so the overall diameter is almost the same. Also, since the new alloys are meant for the Lancer EX, they're the option with the least effect on the speed and economy meter. Bottom line is, don't worry about it. If you really want to know the effect, punch in the old and new tyre sizes in the website* below: https://tiresize.com/tyre-size-calculator/ *Go to the "tyre comparison" sectionย ย
