derickreaper Posted February 14, 2014 Share Posted February 14, 2014 Hi All Members, I was wondering if it is possible to convert a 1992 Honda Civic EG8 Single Carb to a Good Vtec engine ??? or any conversions possible to get a good fuel milage and power ?? if possible any recommended engines.....Please advice me with your thoughts and experiences,..... Quote Link to comment Share on other sites More sharing options...
Komisiripala Posted February 14, 2014 Share Posted February 14, 2014 (edited) Your car already has a good vtec engine You can't get mileage AND power. The cost of replacing will be over 200,000 and you can easily save that by taking the bus and leaving your car at home if mileage is your issue Edited February 14, 2014 by Komisiripala 2 Quote Link to comment Share on other sites More sharing options...
Rumesh88 Posted February 15, 2014 Share Posted February 15, 2014 Komi is correct........ but OP would not be getting both the expected economy and power of an EG8 because a local makabaas meddled up with the fuel delivery system (the carb and associated valves). Am I right? Quote Link to comment Share on other sites More sharing options...
derickreaper Posted February 15, 2014 Author Share Posted February 15, 2014 I'm Bit confused, My Engine doesn't say that it's v-tec (D15B-2070868) Quote Link to comment Share on other sites More sharing options...
derickreaper Posted February 15, 2014 Author Share Posted February 15, 2014 And what's an EFI Conversion?? Quote Link to comment Share on other sites More sharing options...
kelum_wj Posted February 15, 2014 Share Posted February 15, 2014 On 2/15/2014 at 5:32 AM, derickreaper said: I'm Bit confused, My Engine doesn't say that it's v-tec (D15B-2070868) Its Non Vtec buddy. Quote Link to comment Share on other sites More sharing options...
kelum_wj Posted February 15, 2014 Share Posted February 15, 2014 You could Swap Either a D15B, D16Z6 or if you are looking for power B16A (SIR engine). But for economy try to find a D15B2 with 3 stage VTEC. Quote Link to comment Share on other sites More sharing options...
Komisiripala Posted February 15, 2014 Share Posted February 15, 2014 There it is. You'd need 3 stage vtec for economy. 2 stage for power. I can't see whether the vtec solenoids are there or not in that photo. But Kelum knows best. But the question is would you benefit from a good tune-up/maintenance more than an engine swap is gas mileage is your only goal? It's like spending money to save money no? Quote Link to comment Share on other sites More sharing options...
H.C Posted February 15, 2014 Share Posted February 15, 2014 Like Rumesh said if someone has ruined the carb, it will drive like a tractor. Usually these D15B3 single carb motor gives 105BHP with 120 odd Nm of torque which is more than enough for daily running. Only issue is its a bit complicated carb with lot of vaccum lines and most makabases tends to block or bypass them. Its basically economy oriented setup . But you get a power valve which opens up an extra fuel passage in a sudden acceleration and it needs proper vaccum connection to work. So my advice is to check the condition of the existing carb and correct the simple ones like vaccum lines first. Im having similar setup in my car and most of the work including tuning done by myself at home thanks to the service manual and the great advices by Rumesh. So as Komi said rebuild the existing one properly and decide. Quote Link to comment Share on other sites More sharing options...
derickreaper Posted February 16, 2014 Author Share Posted February 16, 2014 On 2/15/2014 at 5:41 PM, H.C said: Like Rumesh said if someone has ruined the carb, it will drive like a tractor. Usually these D15B3 single carb motor gives 105BHP with 120 odd Nm of torque which is more than enough for daily running. Only issue is its a bit complicated carb with lot of vaccum lines and most makabases tends to block or bypass them. Its basically economy oriented setup . But you get a power valve which opens up an extra fuel passage in a sudden acceleration and it needs proper vaccum connection to work. So my advice is to check the condition of the existing carb and correct the simple ones like vaccum lines first. Im having similar setup in my car and most of the work including tuning done by myself at home thanks to the service manual and the great advices by Rumesh. So as Komi said rebuild the existing one properly and decide. will check my carb and get a full diagnostic, H.C whats that alloy you got in ur car??? whats the sizseand where did you bought it?? Quote Link to comment Share on other sites More sharing options...
derickreaper Posted February 16, 2014 Author Share Posted February 16, 2014 and guys whats this EFI conversion i hear and i've seen you tube clips about it, and one of my fried said that his friend does efi conversions and he can do for my car too.. but i dont wanna messup my original car setting so i said no... Quote Link to comment Share on other sites More sharing options...
H.C Posted February 17, 2014 Share Posted February 17, 2014 On 2/16/2014 at 4:14 AM, derickreaper said: will check my carb and get a full diagnostic, H.C whats that alloy you got in ur car??? whats the sizseand where did you bought it?? Its Advanti Racing ultra light monoblock alloys (refurbished) , , bought from Amila tyre , Dehiwala. They said its a Japanese one but not sure about it. It was originally silver and repainted with gun metal grey. They are 15 inch in size & running with Maxxis maz1 victra 195/50/15. Quote Link to comment Share on other sites More sharing options...
sammycajer Posted February 21, 2014 Share Posted February 21, 2014 On 2/15/2014 at 5:41 PM, H.C said: Like Rumesh said if someone has ruined the carb, it will drive like a tractor. Usually these D15B3 single carb motor gives 105BHP with 120 odd Nm of torque which is more than enough for daily running. Only issue is its a bit complicated carb with lot of vaccum lines and most makabases tends to block or bypass them. Its basically economy oriented setup . But you get a power valve which opens up an extra fuel passage in a sudden acceleration and it needs proper vaccum connection to work. So my advice is to check the condition of the existing carb and correct the simple ones like vaccum lines first. Im having similar setup in my car and most of the work including tuning done by myself at home thanks to the service manual and the great advices by Rumesh. So as Komi said rebuild the existing one properly and decide. What about dham*ika fern*do at kotta rd & carburetor Ban*a at grandpas?? are the good for repairing and tuning of eg8 carbs?? guys need your advice?? Quote Link to comment Share on other sites More sharing options...
sammycajer Posted February 22, 2014 Share Posted February 22, 2014 What about dham*ika fern*do at kotta rd & carburetor Ban*a at grandpas?? are the good for repairing and tuning of eg8 carbs?? guys need your advice?? Quote Link to comment Share on other sites More sharing options...
derickreaper Posted February 26, 2014 Author Share Posted February 26, 2014 I found a gr8 guy who lives in piliyandala called Mahesh (working @staffords)who works only on Honda and he does carbs I went there to get a quote for my cars engine tuneup and that place was like heaven.. Lots of eg's ek's..☺ drop me a pm I'll give the number.. Quote Link to comment Share on other sites More sharing options...
Hoonigan Posted February 27, 2014 Share Posted February 27, 2014 On 2/26/2014 at 3:00 PM, derickreaper said: I found a gr8 guy who lives in piliyandala called Mahesh (working @staffords)who works only on Honda and he does carbs I went there to get a quote for my cars engine tuneup and that place was like heaven.. Lots of eg's ek's..☺ drop me a pm I'll give the number.. Awesome! Do keep the forum posted on how you get on and the results. Quote Link to comment Share on other sites More sharing options...
The Don Posted February 27, 2014 Share Posted February 27, 2014 On 2/16/2014 at 4:16 AM, derickreaper said: and guys whats this EFI conversion i hear and i've seen you tube clips about it, and one of my fried said that his friend does efi conversions and he can do for my car too.. but i dont wanna messup my original car setting so i said no... EFI stands for electronic fuel injection. An EFI conversion in the context of your engine is to take the carburettor off and transplant a electronic fuel injection system probably from a compatible engine (as it is very expensive to do a complete custom system). Now whether you can do this easily or not depends on the way the EFI is integrated into your engine. If all you require is a new intake manifold, fuel rail, fuel pump, air intake, intake manifold, injectors, piping, wiring loom, ECU and associated electronics, you are doing pretty well. (thats more like a swap from an engine that has EFI). But its still quite a bit of work. It becomes more complicated if you also need a new head as well. Some simply switch to a new engine to save the hassle of conversion, but you would still need a new ECU, wiring loom and possibly air intake with a MAF sensor ..... Quote Link to comment Share on other sites More sharing options...
kmcsb Posted June 26, 2014 Share Posted June 26, 2014 <blockquote class='ipsBlockquote'data-author="derickreaper" data-cid="257766" data-time="1393426840"><p> I found a gr8 guy who lives in piliyandala called Mahesh (working @staffords)who works only on Honda and he does carbs I went there to get a quote for my cars engine tuneup and that place was like heaven.. Lots of eg's ek's..☺ drop me a pm I'll give the number..</p></blockquote> Hi bro, Can you pm mahesh nmuber ,adress and how much did it cost for tuneup??? I fedup of serching a good tuneup guy.. Still my eg8 does 7kmpl... Quote Link to comment Share on other sites More sharing options...
kmcsb Posted June 26, 2014 Share Posted June 26, 2014 Can anyone pls send mashesh (carb) pliyandala... Quote Link to comment Share on other sites More sharing options...
kmcsb Posted June 28, 2014 Share Posted June 28, 2014 Can anyone pls send mashesh (carb) pliyandala... Quote Link to comment Share on other sites More sharing options...
Muditha420 Posted June 28, 2014 Share Posted June 28, 2014 @kmcsb - I sent you a PM check that place out and get the carb issue sorted Quote Link to comment Share on other sites More sharing options...
kmcsb Posted June 30, 2014 Share Posted June 30, 2014 thanks bro Quote Link to comment Share on other sites More sharing options...
derickreaper Posted July 18, 2016 Author Share Posted July 18, 2016 HI guys, long time no see...... So finally my lease is 1 month away from done and after 3 1/2 years of driving a carb I decided to do a complete vtec conversion...starting with a full paint job (blue to gunmetal), total body alignment, new jdm heads, depo tails, new dash, disk break conversion and finally a vtec engine.... So I have 3 engine choices, 3 stage d15b vtec, b16a vtec, or stage 1 vtec.... Any comments and suggestions about the setup "???? Can someone recommend a place to buy an engine with the above specs I'm focusing on power than the mpg.. 1 Quote Link to comment Share on other sites More sharing options...
MrCat Posted July 19, 2016 Share Posted July 19, 2016 Hello, I am sorry I don’t know about sourcing an engine in SL. I am sure you`ve done your research, but I am just adding my 2 cents worth. Think a little bit about ‘torque’ when building a Honda engine, as this makes a massive difference in day-to-day drivability. A b18C for example, has got a longer stroke, therefore producing more lower end torque. A b18 vtec head on a b20 block on the other hand, can be built to produce 200hp reliably and with enough torque to make it an extremely enjoyable drive. The way I would approach is that I would do the research and list all the parts required, rather than just focusing sourcing an engine from somewhere. If you can find a complete kit that suits your requirements, that’s a bonus. But if you can`t find, you can always collect all the parts required over some time. It`s not too hard to put a Honda engine back together (i.e. rebuild), but the hard bit is to be patient and to source components that work well together. Even if it takes an year or two, if you can build that engine right (together with proper engine management, preferably an LSD diff with matching transmission, matching header and exhaust) it will be worth the wait. I know it all depends on the budget as well, but if you initially spend the money on the essentials (head, block, engine management) then other things can be added later on (exhaust, LSD, etc…) I`ve driven only one properly built Honda in my life (a Civic Ek9, 2 door) so far, and the way that thing delivers power, grip around corners and the way the car rotates around (at corner entry and exit) is truly exhilarating. I don’t see why the same cannot be achieved with an EG8, good luck..! Quote Link to comment Share on other sites More sharing options...
Twin Turbo Posted July 19, 2016 Share Posted July 19, 2016 Get a goo set of racing plugs+leads, and pop in a free flow air filter, Cheap and effective! Quote Link to comment Share on other sites More sharing options...
