kalingabd Posted March 19, 2014 Share Posted March 19, 2014 (edited) Posting this on behalf of a friend of mine. This is regarding a perodua elite 2009 model. When the car slows down, the engine light on the dashboard gets switched on and the engine is turned off. This has happened only a couple of times and did come up when i was driving the car once as well. However, the car starts up normally again and seems to run smooth after that. Guys any idea what the issue can possibly be? Any idea of a place to go to? is the agent the best place? Anything more we can do to know the root cause of the issue? Searched around the forum..Could not find a similar post. Apologies if I missed an existing similar topic. Edited March 19, 2014 by kalingabd Quote Link to comment Share on other sites More sharing options...
MV-5 Posted March 19, 2014 Share Posted March 19, 2014 pls more info.... MT or AT? slow down means 0 throttle ? engine temp? last tune up or MAF,TB cleanup? plugs,air filter condition? Quote Link to comment Share on other sites More sharing options...
Dinukap4 Posted March 19, 2014 Share Posted March 19, 2014 Is there a lag or does it feel under powered while accelerating ? Quote Link to comment Share on other sites More sharing options...
Davy Posted March 19, 2014 Share Posted March 19, 2014 Go to a workshop where a diagnostic scan can be done. The actual error code that resulted in the check engine light to come on will still be stored in the ECU's history. The scanner will pick the error code up. You will then be able to address the actual issue. 1 Quote Link to comment Share on other sites More sharing options...
Sampath Gunasekera Posted March 19, 2014 Share Posted March 19, 2014 (edited) Check the car, may be Viva Elite Hybrid version. Since it is 2009 model, are you sure it is a Viva or Viva Elite? If Viva, it has 660cc, 800cc & 1000cc variants. Is it A/T or M/T? (If it is A/T, definitely 1000cc only.) What is the mileage? If you go to agents, go to Unit#d Mot#rs Orugodawatta and contact Mr.Randika (077-2663670) Did you check the battery wire terminals are properly tightened? I experienced somewhat similar situation with my previous Alto, due to poor battery terminal connection. Edited March 19, 2014 by Sampath Gunasekera Quote Link to comment Share on other sites More sharing options...
kmeeg Posted March 19, 2014 Share Posted March 19, 2014 (edited) On 3/19/2014 at 5:02 PM, Davy said: Go to a workshop where a diagnostic scan can be done. The actual error code that resulted in the check engine light to come on will still be stored in the ECU's history. The scanner will pick the error code up. You will then be able to address the actual issue. May be you have to go to Un*m@. B'cos Viva / Viva Elite data port is not OBD2. So most of the diagnostic places wont be able to check the issue. May be Un*m@ have diagnostic for Viva. (Not sure, thats what i think.) I had a OBD2 scanner but did not work for Viva. But that port exactly matched the OBD2 scanner but did not give any reading.. But as Sampath said it would be helpful to check the battery terminals. Kmeeg. Edited March 20, 2014 by kmeeg Quote Link to comment Share on other sites More sharing options...
udararaj Posted March 20, 2014 Share Posted March 20, 2014 Check with Unit#d Mot#rs at Orugodawatta.. That s the best place i guess Quote Link to comment Share on other sites More sharing options...
Ek3 Ferio Posted March 20, 2014 Share Posted March 20, 2014 Before going to anywhere, check the battery terminal as suggested in a earlier post. A few years back in my Ek3 had a same kind of issue due to the loose battery terminal. While car is on running, engine switched off and all indicators turned on, then it starts up normally and run. But in my case, it lighted up all the indicators like, check engine light, oil and break indicators. Quote Link to comment Share on other sites More sharing options...
kalingabd Posted March 21, 2014 Author Share Posted March 21, 2014 (edited) Its is an VIVA. Apologies for the blunder. Did not knw the difference. All of them look same to me And it is A/T. Mileage is 40K. Slows down and stops. period. I opened the bonnet the last time when it happened. Everything seems cool as normal. To think of it it happens only when the car is at a standstill in the traffic, not while its moving. So basically when the car is driven, this issue doesnt come up. In addition to this, the RPM is over 01 since a fortnight back. always. Need a tune up as well I believe. Edited March 21, 2014 by kalingabd Quote Link to comment Share on other sites More sharing options...
kalingabd Posted March 21, 2014 Author Share Posted March 21, 2014 @Ferio and @sampath. Will check the battery terminals. But the curious thing here is only the engine light comes up when this happens. Not the other indicators. @Dinuka No the car runs smooth. acceleration normal. Thanks for all the info regarding the agent. Will keep you guys updated. Quote Link to comment Share on other sites More sharing options...
Sampath Gunasekera Posted March 21, 2014 Share Posted March 21, 2014 On 3/21/2014 at 8:37 AM, kalingabd said: Its is an VIVA. Apologies for the blunder. Did not knw the difference. All of them look same to me And it is A/T. Mileage is 40K. Slows down and stops. period. I opened the bonnet the last time when it happened. Everything seems cool as normal. To think of it it happens only when the car is at a standstill in the traffic, not while its moving. So basically when the car is driven, this issue doesnt come up. In addition to this, the RPM is over 01 since a fortnight back. always. Need a tune up as well I believe. If the mileage is 40,000km, as per manufacturer, . (1) Need to change ATF. (ATF change at every 40,000km) (2) Need engine tune up (Engine tune up at every 20,000km) Quote Link to comment Share on other sites More sharing options...
kalingabd Posted March 22, 2014 Author Share Posted March 22, 2014 (edited) Thanks guys. @sampath..thanks for that info. I will convey this information. Best thing to go to orugodawatte and get the car checked up. will let u know how it goes. Edited March 22, 2014 by kalingabd Quote Link to comment Share on other sites More sharing options...
kalingabd Posted March 30, 2014 Author Share Posted March 30, 2014 hey guys.. thanks. problem solved. took the car to unimo and like @sampath said had a chat with ranjith, who advised doing exactly the same thing suggested here. 1/ Engine tuneup 2/ ATF change While doing that, during some checkup they identified that the sparker plugs were faulty and replaced them. No issue now. No idea what exactly resolved the issue. but the car runs fine now as per my frentho thanks a lot. One small query tho. The rpm with AC on is at 1000. Is this normal? Quote Link to comment Share on other sites More sharing options...
udararaj Posted April 5, 2014 Share Posted April 5, 2014 these are small engine cars 1000cc. So doing service on time , Tune up on time (every 20000km) and AT change (40000km) is must. Not like japanese car. the rpm with AC on is at 1000. Is this normal? i think this is normal. But the when you drive your car for better fuel consumption best rpm level is 2.5 Quote Link to comment Share on other sites More sharing options...
Supra_Natural Posted April 6, 2014 Share Posted April 6, 2014 (edited) On 4/5/2014 at 3:04 AM, udararaj said: these are small engine cars 1000cc. So doing service on time , Tune up on time (every 20000km) and AT change (40000km) is must. Not like japanese car.the rpm with AC on is at 1000. Is this normal? i think this is normal. But the when you drive your car for better fuel consumption best rpm level is 2.5 That's the dumbest thing I've heard in awhile.... How does the fact that they are 1000cc cars make doing the service on time "is must"? And how come Japanese cars are not like that? What about Japanese 1000cc cars, what happens then?Do elaborate, I'm sure everyone is curious to know.. Edited April 6, 2014 by Supra_Natural Quote Link to comment Share on other sites More sharing options...
Herman Jayatilleke Posted April 11, 2024 Share Posted April 11, 2024 My son's Viva Elite car have started to give trouble. It stops instantly while driving have done a thorough check up but no remedy for this problem. Please advise. Jayatilleke from Kelaniya. Quote Link to comment Share on other sites More sharing options...
