I'm not sure whether this is an electrical issue or mechanical issue. I have a Mitsubishi C62A 1991 car (ASP Model). It has 4G15 powerful 1500cc Petrol Engine. There is a small water leak in the radiator and sometimes the heat goes up (not full but little more than the normal temp). I tried to close the leak but the guy who did make it worse. Now one water line is not working and not sure whether the others working fine too.
From a couple of days there is a huge problem. Car stops without indicating anything. But I feel few misses before it stops. I thought the carb was blocked and cleaned. But still the problem is there. Then another garage guy said the problem is with my plug wires (from the distributor to the plugs). Then I replaced them as well (plugs are not new but working). Nothing helped. There is no petrol block, no carb block. Another said my Gascut should have gone due to the heat. When the heat goes up the Radiator fan starts. True that the radiator core is bad now.
Another thing, After 30 minutes the car starts again. But sometimes not, then need to push to start the car. My battery also good.
Guys, please help me to identify this issue. I showed the car to electrical and mechanical guys. They asked me to do this and that and I did all but the problem is still there.
Iroshw
Irosh
21 answers to this question
