Dear all last week my mazda 3 car came up with a strange overheating problem...
This is what happen...sorry for the long story
Last week i went to this garage to get my radiator expansion tank replaced due to a small leak,it was leaking near one of the upper small hose that connecting to the expansion tank...so after removing the hose found that the expansion tank plastic line was corroded a bit and cracked...and they also found some plastic pieces like sand inside the hose they cleaned it...the lost plastic part was around 2mm..they replaced the tank with a oem one..
I came home with no problems...then the other day i went on a trip around 200km..anyway i kept looking at the gauge the whole time because of the new tank.had no issues but on the way back when i was near my hometown i noticed my fans were noisy than normal then i checked the gauge it was around 3/4 of the gauge...I suddenly turned off the car and let it cool and opened the bonnet..I didn't feel that much abnormal physical heat and there were no leaks..so again started the car it was back to normal temp then i drove home without any issues....then the other day i went to the garage(gauge was normal) they couldn't identify the problem anyway they replaced the thermostat and bleed the system for any air...they said they checked for 2 hours it didn't heat up...
again when i was coming home the gauge gradually began rising than normal so i revved the engine a bit hard.. to my surprise gauge came back to normal...then i drove around 2 hours without any issue...the issue came again today then i revved the engine and it was fine after that....
Fans working fine,they kick in and working,heater works fine...I have this anxiety could be this due to that small plastic chip getting clogged somewhere randomly...how can i sort this out...will a coolant flush work?tanx
I have an empty parking slot at home previously occupied for 6 years by the starlet and 3 months by an AD wagon -what would be a bang-for-the-buck fun shitbox? Preferably auto as I live in a crowded suburb that has sapped the joy of stick shift out of my system.
GayanR
24 answers to this question
