Honda Vezel Reverse Camera
killercruise
  On 9/17/2014 at 7:42 AM, AbeysinghE said:
I know for sure, many Honda Vezels come to Sri Lanka without DVD payer and reverse cam..It's all been fixed locally...why so worry about guide lines?...
yep plus i heard the JDM reverse cams dont work with the non-Japanese set ups
  On 9/17/2014 at 4:39 AM, Magnum said:
As far as I know all JDM vehicle's reverse camera shows guidelines but these most car salers bring down vehicles without DVD player/reverse camera and fix them here
Those have the lines with distance marked but it wont show you where the car will go depending on the steering wheel position on another red line.After market shows just the distance, the original one has two sensors in the front tyres so it will show where the car will turn to when its steered.
My Allion has the original R cam and the original setup, but it doesn't show guide lines. Im not used to watching the r. cam when revercing so it doesn't matter. The mirrors are just fine.
The Vezel much like all other cars come out of the factory with just a big hole covered by a plastic piece but most new cars come with the harness already in place for the cams, sensors, etc...The camera and the actual head unit are dealer options (in most cases) and the buyer has the option of selecting from several models, some with guidelines, some with just distance lines, etc...different quality cameras etc...If you wish you can get the Vezel or any other car for that matter without any of it and just the plastic cover :) I think most car imprters in SL go with this option as it is cheaper.
So do all Vezel reverse cam setups come with guidelines...I dunno...maybe...depends on what options Honda provides I guess. Toyota and Nissan have units without guidelines which are usually the cheaper option.
In original JDM units generally navigation does not work/ TV different system/ Radio only up to 90 Mhz / Sometimes clock cannot be adjusted and instructions are in Japanese.
Sometimes only thing that works is DVD/CD and the reverse camera and of cause half radio.
Generally these top end units cost more when factory fitted.
Best is to get the vehicle here and fix a good quality setup, depending on once budget sky is the limit.
From Chinese crap with all the bells and whistles to a good brand most probably with better sound than the original.
