Rat Problem, Advice On Next Steps
So guys,
I just found out a rat has been attacking my vehicle (toyota aqua) for a while. One of my rear seat is messed up, and few warning lights are always on. Here's a shot.
http://d.pr/i/17mtv+
This is my first time dealing with an animal attack and I have no clue what to do.
What's the best cause of action?
1. Tow it to nearest toyota service point and get if fixed?
2. Dealing with local garages is a bad idea? (because it's a hybrid)
Thanks for your advice.
Update
I took my car to Toyota Lanka. They immediately disassembled the whole rear section (hybrid unit).
The rat has screwed up few wires that are related to temperature sensing of hybrid system. Most of the sponge like material that are between vehicle frame and upholstery has been damaged. Got a damaged seat belt, some plastic covers has been damaged. Found 2 mice under gearbox compartment, and I think they found another in inside AC system. They pretty much disassembled the entire vehicle inside from dashboard. The cost came close to 150,000 and I got 50% of parts covered from SLIC.
By the way morning time one of SLIC agent is in Toyota lanka branch everyday, so if you're using SLIC there's a good chance of processing things quickly.
They said they are going to cover the fresh air went from outside.
Got it fixed within 2 days, I hate this rat.
Edited by sahanlak
Looks like the wiring is wrapped together only using insulation tape. You can minimise future damage to harnesses by wrapping them up with PVC flexible tubing. It's a DIY job actually.
