Carina Gt At210 Color Codes
tuner88
Hi , I'm having a problem with finding a proper color code for my Carina GT AT210 - 1996.
there is no issue with the original body color code as i know it is Toyota - 199, and most likely i will change it to something newer like 1B9 - Quick Silver. my question is : I'm planing to keep the Matt Grey line in the bumper, no matter what Sliver color i go for. but having problem finding the correct color code for the same?
Original 199 color code , looking for that Matt Grey color code in the bumper and the Door Garnish. Thanks.
According to the parts catalog these are the colors the side moulding is available to purchase in:
(this is just the front fender....the rest of the mould has similar tables...)
75624A MOULDING, FRONT FENDER, OUTSIDE REAR LH
75624-20410-D0 DARK GRAY, 202
75624-20440-B0 BL.GRAY ME, 199 , 6P7 , 925
75624-20440-E0 DK. GRAY ME., 6P2 , 8L2
75624-20440-E1 GRAYISH BROWN ME., 040
I have no idea how to read the table..but I guess it means for body code 199 the part number is xxxxx-xxxxx-B0 which is Blue Grey Metallic ? The only Blue grey metallic I can think of is 183 or something...
EDIT:
or 182...there was a 1 and a 8 at least....
The thing is, sometimes the color visible is not what the color actually gets categorized as. I had a two tone Hilux Surf where the bottom looked like silver but the color was something lavender....go figure....
Edited by iRage
Damn it, thats the color i was searching for. The painter looked at the pictures and said its a Copper Brown and we looked up with the toyota charts and this was the closest color in the charts for copper brown...
  On 9/16/2015 at 1:45 PM, Magnum said:
Is that your car?
ah no She's not mine here's mine
she's bit different now , number plates and the tint, doesn't matter now everything has been removed again for the paint :)
  On 9/16/2015 at 2:09 PM, Muditha420 said:
I thought you sorted this out? i wasn't able to find the colour as well but did u try asking Toyota itself IF not why not match a colour to the trim?
yeah machan thanks to you, Doc , and Iragei i have the "body color" , now having doubts with this Grey line.
  On 9/16/2015 at 2:29 PM, Schiffer said:
That is a problem common with Carina and corona. i tried to find out the color code and had no luck too, and ended up with the wrong color on mine :/
hmm , and I'm thinking of applying something new for body color also, so don't wanna end up with a rice bucket :(
EDIT:
i think this will be much helpful , will do my research and come back , thanks a lot :)
btw if we take >> 75624-20440-B0 BL.GRAY ME, 199 , 6P7 , 925
if BL.GRAY ME is for that Matt line , and 199 for body color , what would be these numbers 6P7 , 925 ? :speechless-smiley-004::sad-smiley-034:
Edited by tuner88
6P7 and 925 are also Toyota Color codes...I guess those are other body colors the Carina came in. The trick would be to find what Blue Grey Metallic is....one is 183...no idea how many other shades are there..
called a guy Toyo***Lan**** will see , keep this posted as it seems , this maybe useful some others like me :)
