Chris28 Posted January 29, 2016 Share Posted January 29, 2016 There's a loud rattle noise for about 2-3 seconds when i start the engine in the morning or when it's a cold start. The rattle noise goes off after 2-3 seconds. Has anyone else come across a similar issue ? Regards Chris 1 Quote Link to comment Share on other sites More sharing options...
ferrarif50 Posted January 29, 2016 Share Posted January 29, 2016 Just asking, what's the mileage on your Vezel ? Quote Link to comment Share on other sites More sharing options...
tcfern1 Posted January 29, 2016 Share Posted January 29, 2016 This is a common issue in hybrids Nothing to worry Quote Link to comment Share on other sites More sharing options...
tiv Posted January 29, 2016 Share Posted January 29, 2016 On 1/29/2016 at 1:12 PM, tcfern1 said: This is a common issue in hybridsNothing to worry If so please do clarify why? would be beneficial to everyone 1 Quote Link to comment Share on other sites More sharing options...
Chris28 Posted February 2, 2016 Author Share Posted February 2, 2016 (edited) 15k and the noise started after the 1st service .....oil used is 0W20. Cant be normal cos i used another Vezel with 14k and it never had this noise at cold startup. Similar to the noise in this Edited February 2, 2016 by Chris28 Quote Link to comment Share on other sites More sharing options...
tcfern1 Posted February 2, 2016 Share Posted February 2, 2016 This rattle is occasional not on every cold start up if the situation is supposed to be normal Otherwise not Quote Link to comment Share on other sites More sharing options...
Chris28 Posted February 2, 2016 Author Share Posted February 2, 2016 On 2/2/2016 at 9:19 AM, tcfern1 said: This rattle is occasional not on every cold start up if the situation is supposed to be normalOtherwise not On my vehicle its every cold start !! Quote Link to comment Share on other sites More sharing options...
Davy Posted February 2, 2016 Share Posted February 2, 2016 I remember there being a lot of discussion about a cold start rattle for CR-V and Accord in Australia. Since the Vezel is basically as same as the CR-V, this might be the same issue. If it is, you should be able to find information about it on the web. It was an issue with the VVT system - a solenoid that fails prematurely I think. 1 Quote Link to comment Share on other sites More sharing options...
Rumesh88 Posted February 2, 2016 Share Posted February 2, 2016 On 2/2/2016 at 7:56 AM, Chris28 said: 15k and the noise started after the 1st service .....oil used is 0W20. Cant be normal cos i used another Vezel with 14k and it never had this noise at cold startup. Similar to the noise in this To me it sounds like a timing chain rattling before it catches up oil to lubricate itself. Could it be a bad tensioner? If it is a fault with Variable Timing Control then it should last much longer. Quote Link to comment Share on other sites More sharing options...
Davy Posted February 2, 2016 Share Posted February 2, 2016 (edited) Just read a bit about the common rattle issue and the VTC rattle only lasts for about 2 seconds according to most people who have complained about it, and according to Honda themselves.Honda has released a service/repair procedure for this.https://www.youtube.com/watch?v=QTnufuKpp6cService bulletin documentation here. Note that the documentation says that the VTC actuator issue is just a "probable cause". Could be the things Rumesh mentioned above as well. In any case, you should take your car to Stafford and have them diagnose the issue. They should be aware if this is a known issue. Edited February 2, 2016 by Davy 2 Quote Link to comment Share on other sites More sharing options...
Chris28 Posted February 3, 2016 Author Share Posted February 3, 2016 On 2/2/2016 at 12:18 PM, Davy said: Just read a bit about the common rattle issue and the VTC rattle only lasts for about 2 seconds according to most people who have complained about it, and according to Honda themselves.Honda has released a service/repair procedure for this. https://www.youtube.com/watch?v=QTnufuKpp6c Service bulletin documentation here. Note that the documentation says that the VTC actuator issue is just a "probable cause". Could be the things Rumesh mentioned above as well. In any case, you should take your car to Stafford and have them diagnose the issue. They should be aware if this is a known issue. Thanks for the information.... Stafford used to be excellent but lately looks like the increase of Honda vehicles in the country has contributed to the reduce in quality of service.... FYI.... This noise started after the first service at Stafford... and very recently after a small paint job on a door, i found that they have not even put the beading back in place and damaged the beading while taking it out before painting. Quote Link to comment Share on other sites More sharing options...
Chris28 Posted February 3, 2016 Author Share Posted February 3, 2016 On 2/2/2016 at 10:23 AM, Rumesh88 said: To me it sounds like a timing chain rattling before it catches up oil to lubricate itself. Could it be a bad tensioner? If it is a fault with Variable Timing Control then it should last much longer. if this was the case then keeping the vehicle on (without starting the engine.... just pressing the start button without breaks) for a few mins and then starting the engine should eliminate the noise isn't it ? Quote Link to comment Share on other sites More sharing options...
Rumesh88 Posted February 3, 2016 Share Posted February 3, 2016 On 2/3/2016 at 2:30 AM, Chris28 said: if this was the case then keeping the vehicle on (without starting the engine.... just pressing the start button without breaks) for a few mins and then starting the engine should eliminate the noise isn't it ? No. you need to run the engine to get the chain lubricated along its whole length. If the chain initially rattles along its longest free span (this can happen if its natural frequency of oscillation is equal,close, or a hamonic of the engine RPM) oil will dampen the rattle. However this is only another possibility in addition to what Davy mentioned above. Does it happen if you immediately switch off after a cold start and restart again for a second time? Quote Link to comment Share on other sites More sharing options...
Chris28 Posted February 3, 2016 Author Share Posted February 3, 2016 On 2/3/2016 at 3:29 AM, Rumesh88 said: No. you need to run the engine to get the chain lubricated along its whole length. If the chain initially rattles along its longest free span (this can happen if its natural frequency of oscillation is equal,close, or a hamonic of the engine RPM) oil will dampen the rattle. However this is only another possibility in addition to what Davy mentioned above. Does it happen if you immediately switch off after a cold start and restart again for a second time? nope...when i start the engine the second time it's gone.... but one thing i noticed is that the engine is louder than the previous vezel i used.. both same mileage btw (14-15k) Quote Link to comment Share on other sites More sharing options...
Rumesh88 Posted February 3, 2016 Share Posted February 3, 2016 On 2/3/2016 at 4:43 AM, Chris28 said: nope...when i start the engine the second time it's gone.... but one thing i noticed is that the engine is louder than the previous vezel i used.. both same mileage btw (14-15k) Could be due to a bad tensioner but still a bad VTC cannot be ruled out. The VTC should be in locked position when the oil pressure is zero (ie when the engine is stopped). As long as you have some oil left inside the VTC it would not rattle even if it is unlocked. Only way to check this is to open the cam cover and see if it is in locked position. I'm afraid you have to refer the matter to the agent as suggested by Davy above. Quote Link to comment Share on other sites More sharing options...
Chris28 Posted February 3, 2016 Author Share Posted February 3, 2016 On 2/3/2016 at 11:07 AM, Rumesh88 said: Could be due to a bad tensioner but still a bad VTC cannot be ruled out. The VTC should be in locked position when the oil pressure is zero (ie when the engine is stopped). As long as you have some oil left inside the VTC it would not rattle even if it is unlocked. Only way to check this is to open the cam cover and see if it is in locked position. I'm afraid you have to refer the matter to the agent as suggested by Davy above. Yeah.. gonna get it done on monday...driving to galle tomorrow... do u think that it's safe ? Quote Link to comment Share on other sites More sharing options...
Rumesh88 Posted February 5, 2016 Share Posted February 5, 2016 On 2/3/2016 at 12:28 PM, Chris28 said: Yeah.. gonna get it done on monday...driving to galle tomorrow... do u think that it's safe ? You should be absolutely safe as long as you are on the drive. However, assuming it is due to a faulty VTC, then each time you start the car this rattle will create an additional stress on the timing chain for just 2 seconds. So it will take many starting cycles (perhaps a few 100s) to have a significant impact on the parts. Quote Link to comment Share on other sites More sharing options...
Chris28 Posted February 8, 2016 Author Share Posted February 8, 2016 Thanks guys.. will keep you posted on the checkup today !! Quote Link to comment Share on other sites More sharing options...
Chris28 Posted February 8, 2016 Author Share Posted February 8, 2016 So basically....this was caused after stafford opened up the engine bay for a checkup at the last service.... i wasn't using the vehicle back then....from that day on-wards the issue just got louder and louder....... trying to get stafford to check it again and fix the bloody thing properly.... There was a time where stafford motors did excellent work and took care of vehicles.....gone are those days... everyone please keep in mind this whenever u wanna take your vehicle to them.... think twice. Quote Link to comment Share on other sites More sharing options...
gayanath Posted February 9, 2016 Share Posted February 9, 2016 On 2/8/2016 at 10:29 AM, Chris28 said: So basically....this was caused after stafford opened up the engine bay for a checkup at the last service.... This means what they did? Cleaning / tune-up or any other ????? Quote Link to comment Share on other sites More sharing options...
Chris28 Posted February 9, 2016 Author Share Posted February 9, 2016 (edited) On 2/9/2016 at 4:14 AM, gayanath said: This means what they did? Cleaning / tune-up or any other ????? After coming back from kandy (around 2000KM on the ODO) it started having a misfire and stopped... then refused to start... took it to Stafford.. they opened it up and cleaned the injectors, checked timing....etc... Edited February 9, 2016 by Chris28 Quote Link to comment Share on other sites More sharing options...
gayanath Posted February 9, 2016 Share Posted February 9, 2016 On 2/9/2016 at 9:11 AM, Chris28 said: After coming back from kandy (around 2000KM on the ODO) it started having a misfire and stopped... then refused to start... took it to Stafford.. they opened it up and cleaned the injectors, checked timing....etc... You observed the issue at 2000 km ODO. Now your vehicle is with 15K+ ODO. Which means you have run the car 13K with this issue. Is it same for all the time or with increasing trend?? Quote Link to comment Share on other sites More sharing options...
Chris28 Posted February 9, 2016 Author Share Posted February 9, 2016 On 2/9/2016 at 10:47 AM, gayanath said: You observed the issue at 2000 km ODO. Now your vehicle is with 15K+ ODO. Which means you have run the car 13K with this issue. Is it same for all the time or with increasing trend?? I got the vehicle like a month back.. 14+k .. (it's a rental from a guy i have been renting for years) .. according to him the noise started and kept increasing after that particular service. Guys any reliable place we can get this sorted out from... cos the owner is also reluctant to take it back to stafford. Quote Link to comment Share on other sites More sharing options...
Chris28 Posted February 18, 2016 Author Share Posted February 18, 2016 So got it finally fixed by Stafford....What they said was it's a manufacturing defect. Replaced the V-Tech actuator wheel & V-Tech actuator wheel inlet (34k damage) Thanks everyone for the feedback.... 2 Quote Link to comment Share on other sites More sharing options...
Davy Posted February 18, 2016 Share Posted February 18, 2016 On 2/18/2016 at 3:22 AM, Chris28 said: So got it finally fixed by Stafford....What they said was it's a manufacturing defect.Replaced the V-Tech actuator wheel & V-Tech actuator wheel inlet (34k damage) Thanks everyone for the feedback.... Thanks for reporting back. This could be useful for other Vezel owners. Quote Link to comment Share on other sites More sharing options...
