I have a Toyota AE110 with Automatic gear box.The engine is starting and running smoothly when the engine is in cold state, the RPM is normal (No RPM meter because it is a XE Saloon. I am telling according to the engine sound) and no vibrations (Recently replaced mounts but the issue was there previously) or knocking sounds. But when it is getting the normal engine running temperature , the RPM is getting lower and start vibrating while idling on gear "D" &"R" but "P" & "N" is smoothly having the normal RPM in any of the engine temperature. While ON/Off the A/C in idling, the RPM is slightly changing but not up to standard. Any help guys ?
pasindups
I have a Toyota AE110 with Automatic gear box. The engine is starting and running smoothly when the engine is in cold state, the RPM is normal (No RPM meter because it is a XE Saloon. I am telling according to the engine sound) and no vibrations (Recently replaced mounts but the issue was there previously) or knocking sounds. But when it is getting the normal engine running temperature , the RPM is getting lower and start vibrating while idling on gear "D" &"R" but "P" & "N" is smoothly having the normal RPM in any of the engine temperature. While ON/Off the A/C in idling, the RPM is slightly changing but not up to standard. Any help guys ?
5 answers to this question
