  • 1
Transmission oil toyota aqua
Which transmission oil should be used and how much quantity is required in toyota aqua and oil specifications. And after how many kilometers oil must be change.
Edited by Wasif2283
7 answers to this question
Had an in-depth discussion on your sub, pls check past threads.
TT.
P.s, it's good that you are thinking of changing the gear oil BEFORE you end up repairing/changing the gearbox,..;)
Edited by Twin Turbo
Also..there is the Aqua/Prius C FB group. Most posts are simply the ela-kiri type with pics of their odo-meter and doing some wierd turns and stupid discussions of which number plate size fits better...but there are a few guys who make sensible and technically educational posts.
  • Change int: 40 000 km
    oil: Only "Toyota CVT Fluid TC" (Made in Japan)
    quantity: most probably 3L out of 4L can.
Edited by Uditha88
Just for curiosity....the user manual says to use Toyota <something> Auto Fluid WS <or something of the sort...> is this a CVT transmission oil ?
WS = World Standard.  it's red and comatible with all Aisin units.
Take your car to the dealer, they stock it
