It was found over heating issue since 2,3 months of my Kia Rio 2003 wagon. Some times even in long run it goes only 25% of heat meter. Some times heat up even with short run. Checked Radiator but no issue found. Changed the radiator cap.
After that i found cooling fan does not work at a time. Then i switch off and start again. So fan start to work. Also when heat goes up coolant filled to back up tank. No issue with the Gasket. Verified by a technician.
Please give me your valuable technical ideas on this and the price of this type of fan or what are vehicals which having same type of fan.
Restoring a 90's Diesel.
Xtreme Auto
6 answers to this question
