Fit GP1 Oil Level Drops
On 5/31/2018 at 12:40 PM, G_Man said:
Well I have a GP1 2013, now I have clocked exactly 60K, about couple of months back I noticed the oil level drop. And then I refilled oil and ran for more than a month.ย
Last week I had the check engine light lit up and vehicle went Limp Mode. Immediately I checked with a scanner and it said Cylinder 3 was failing. The local mechanic suggested to replace plugs and do an engine tune up. Then I took it to Stafford Motors Raththanapitiya.ย
The service advisor immediately suggested that this is a know issue. And they need to replace pistons, rings and some other stuff. The estimate was 160K. Luckily they had stocks with them. I asked them to proceed with the repair. It was a three day work.
Finally I got the vehicle and I feel it's reborn, drive is extremely smooth.
They advised me to use 10w 30 oil and not to rev the engine much during initial 1000KMs.
I hope I have done what's required.
For those who consider buying a GP1. I would say.
  • It's a great car to drive, you can enjoy every bit of it.
  • Not very economical in city my one did 10Km/L, but out side the city it easily does 25Km/L
  • Until this repair came up I have only done a ย gear oil change as a costly maintenance.
  • Suspension is bit to the stiff side but generally a comfortable vehicle.
Good luck.
Hi All,
I owned Honda Fit Gp1(Manufacture year - 2013). Now My ODO meter reading - 78000km. My driving pattern is short distance (40 km daily) and some long distance trips regularly (Kandy-Colomb-Kandy).
I also got similar problem that @G_Manย faced. when my ODO meter clocked to 63000k I got engine check light with VSA Warningย and had to transport vehicle in tor truck to local garage ( because there was no agentsย near that areaย ). after inspection they said that there is a misfire in three pistons. ย after they suggest to to engine tuneup and replace all 8 spark plugs.ย ( because I carry vehicle there was no other problemsย ) then I did as they suggest.ย
But engine oil burning issue did not resolved. last week I got same problem and at that time ODO Meter reading was 78100km. this time I carry vehicle to Stafford Ratthanapitiya. and spark plug looks like this.
On 4/3/2017 at 7:41 PM, Sam B said:
Took the car to Stafford. And this is the state of one of the plugs.
They say that the rings have shrunk (ringย เถถเถฏเถฝเท ) making a gap between the rings and liner. Apparently they've come across a few similar cases.
@Rumesh88ย What's your opinion regarding this?ย
They said that this is a common problem that GP1 has and need to replace pistons set and do engine overhaul to resolve issue. cost said to be around 180k.ย ย @G_Manย after repair can you give me your status about vehicle please and it will be really helpful for me.. :)
1. What is the best solution for this and how about Stafford in Raththanapitiya.. ? is there someone specialized about this problem.. ?ย
2. Is this solution is permanent. ( If anyone did that repair have you faced same problem again..?ย )
3. What about cost ( 180k ) is this the actual price.?
4. Is it worth to do this repair and keep GP1. will it face same problem or related engine problem again. because I can not afford more repairs like this.
any information related this is very helpful..ย ย
  • 2 months later...
  • Replies 137
  • Views 45.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Guys, Problem identified and rectified. After ย dismantle the engine we found that there is no bit of sludge deposited. Metal looked glistering shine. I"ll upload a photo later. However, the
  • If it is mineral oil you need not worry but make sure to change it every 6 months even if the mileage is low.
  • Well I have a GP1 2013, now I have clocked exactly 60K, about couple of months back I noticed the oil level drop. And then I refilled oil and ran for more than a month.ย  Last week I had the check
Posted Images
On 4/2/2018 at 10:55 PM, hondaclub said:
I am another victim of this issue, these were the symptoms;
  • Oil level started to drop
  • A/c gradually reduced during running
  • tappet nice when slowing down to 20kmp/h
  • high vibration during cold startup
  • oil spill around spark plug rings.
  • engine warning
  • scanner show misfire on the first cylinder
I went through extensive research and spoke to stafford and as usual no help since i did not buy the car from the company. but they actually know the issue and the initial suggestion was to do the piston ring clean up (cost is around 60k) and they are still not sure if thats the right option as the supervisor says it works for some car and doesn't work for some and for those they recommendย to change the rings and piston (cost is around 180k) since the new rings wont fit the existing piston. went back to my usual garageย (he has been maintaining all my cars for the last 10 years) and he is aware of the issue and some cars they have done the injector clean up and gone as it was enough for them. I decided to do the big repair by changing the piston and rings as i never wanted to take a chance by cleaning up. Got 4 pistons and the ring sets fromย Tech Motors (who bring down honda genuine parts but you should go with someone who knows to validate just to make sure you are not given A grade Thailandย manufactures). the entire kit including gasket cost me 81k with a discount since my garageย guy knows them well. its a three day process (quite complicated than we think since you have to remove)ย as you need to remove the head uni and do the clean up and then fix the piston rings to the new piston and attach to the existing rod. My mechanic suggested to do the machine push for connecting the rod to piston as it is will give the perfect finishing, you have to take the old piston and the new one (without rings) to D*MO lanka at bluemendal road and they will use the machine and press the new piston to the existing rode which was a perfect job and the cost for that is Rs. 2400. So after three days i got the car back with new piston installed and suggested to use 0w20 oil since the piston is still new and it should have more silkness. The mechanic charged me 40k for the entire work including oil and the total cost was (81+2400+37=120400). engine is very smooth now and a/c is much better and i could feel no vibration when reaching beyond 2000 RPM. I will keep updating and if you guys have plans to fix the issue i would suggest to do it once without taking chances as Staffordย is not always sure about their recommendations. below is the picture of existing piston.
@hondaclubย How many kilometres have you done so far following the cylinder replacement? Does the oil level remain in tact between services now?
well I had a GP1 and sold it two weeks ago the oil buning issue came 54K but as agents adviceย i did a ring clean up costed 60K from staffords but two years after that the oil burn up came again spoke to the agents they said that some times it comes again.
So sold the car that had 8 plugs with great acceleration. and bought two kie cars alto and a wagon r - end of the japanese car reliability.
  • Author
Indeed, it comes back. For mine also 80,000km after cleaning rings it has come back again. Actually, when I did the repair the actual cause was not found (I am the one who started this thread), if so I would have opted for piston replacement.ย
I think, after piston replacement it will not come. I am thinking of doing the major repair and either use it or sell.ย
Edited by vitz
On 12/22/2018 at 10:32 AM, PR_CAR said:
Hi All,
It has been 20000km so far since I have done the full repair which is suggested as the permanent fix. Rings clean up temporary only and it will get clotted again dude to the size is the hole been made different. I suggest to beย generous and do the full repair and then sell it. Otherwise the buyer will have to go through the same nightmare ย ย
  • Author
Knowing the Cleaning of rings is a temporary fix, I am really wondering why the company suggest the cleaning option!!!
Itโ€™s up to you if you want to rely on the company. Many of us know what stafford does in srilanka. Personally I have had my go.ย
  • Author
11 hours ago, Hyaenidae said:
Service charge x times cleaned > Service charge x permanentย fix
Customer point of view
(Damage to engine, plugs,oppertunity cost)ย x times ofย cleaned>service charge x permanent fix
How many customers are knowledgeable to take a decision considering above....
Indeed we know the level of customer care in SL :)
Out of the thread, I got a Panasonic FZ-G1 purchased in Sri Lanka from the agent (SxxxLxxx). Suddenly, it gave a pop up message that machine is in the recall list and immediate replacement of battery is required, of course free of charge. So, contacted the sales guy three time no reply.
Just couple of weeks ago I had to travel to Canada. Just one email to Panasonic, within one week "the replacement battery arrived at myย apartment"
Edited by vitz
On 3/10/2019 at 9:34 AM, hondaclub said:
It has been 20000km so far since I have done the full repair which is suggested as the permanent fix. Rings clean up temporary only and it will get clotted again dude to the size is the hole been made different. I suggest to beย generous and do the full repair and then sell it. Otherwise the buyer will have to go through the same nightmare๏ปฟ ย ย
After some research and finally I also did permanent fix andย up to now I ran 4000km. I checkedย oil level like every 500km and oil level remaining same.. :) At first I thoughtย ย to sell this but felt guilty like @hondaclubย said and I like this car. so I fixed it and I hope that fix will last at least 100000 km.. :) please share current status of car @hondaclubย and anyone did permanent fix. In my experience I also suggest to do permanent fixย
Glad to hear that PR_CAR. It has been approx 20000 since I have done the major repair. All good so far and during last service did a scan from stafford and looks perfectly healthy. Big time Honda fan ?
Happy to hear the fix is sort of common now and people get it done. There has been a bit of bad rep for the car of late hope it get's the true recognition for being a very rugged and exciting little car - probably the last modelย  to retain the genes from the original fit of the early 2000's .ย
with the issue fixed - it's a wonderful car very nippy and perfect for our traffic and narrow roads : I sometimes miss [i sold mine last year] the fits nimbleness specially when driving in narrow roads in rush hours. It was my wife's favorite and she still complains she misses it's city driving dynamics.ย
Edited by matroska
  • Author
From where you got this done?
