KDH <3 Posted December 10, 2017 Posted December 10, 2017 I heard that trh model doesnt require dpf cleaning and some other maintenance that should perform on kdh. What are those maintenance differences between kdh and trh.. Also need to know about fuel consumption of both vehicles Im mentioning about 2007 models(both) Quote
1 Magnum Posted December 11, 2017 Posted December 11, 2017 Please search the forum. I remember there was a similar thread like this also there's a thread that's dedicated specifically for Hiace 1 Quote
0 Supra_Natural Posted December 12, 2017 Posted December 12, 2017 On 12/10/2017 at 6:32 PM, KDH <3 said: I heard that trh model doesnt require dpf cleaning and some other maintenance that should perform on kdh. What are those maintenance differences between kdh and trh.. Also need to know about fuel consumption of both vehicles Im mentioning about 2007 models(both) A DPF is a Diesel Particulate Filter. Which is something that serves no purpose on a petrol vehicle (which the TRH is). That's the key difference. The TRH has a fairly low tech petrol engine that if taken care of will go on basically for ever. All KDHs have common rail diesel engines (2.5 liter 2KD or 3.0 liter 1KD) which require good oil and ideally super diesel if you want them to last. Even if they are taken care of, you're looking at a rebuild by around 200,000 KM and rebuilds are NOT cheap (easilly 500k plus if done properly with the right parts). The 2.5 liter 2KD is a bit less complex than the 3.0l 1KD although less powerful so probably will be better durability wise. Fuel consumption on a manual 2KD van from personal experience (with dual AC) has been around 9-10 KM/L in the city and 12-14 outstation. Petrol will probably be in the 5-6 range (basically similar to a petrol prado). 1 Quote
0 KDH <3 Posted December 12, 2017 Author Posted December 12, 2017 Great,valuable informations...thanks Supra... Hmm,that means kdh will be easy with fuel & trh with maintainence. How much it will cost for dpf cleaning? Did you mean that TRH dosent require full engine rebuild? In which mileage do we need to clean that dpf? Is that TRH model will be good for hiring(tourism) pourposes? Quote
0 iRage Posted December 21, 2023 Posted December 21, 2023 On 12/19/2023 at 11:37 PM, ravindu perara said: What is the meaning of kdh First part of the model code for a HiAce... KD means it has a KD series diesel engine...H200 <usually there is a number> identifies it is a H200 series Hiace (i.e. 5th generation Hiace). In some markets diesel HiAces also have the codes GDH, LH, KZH (because they had GD, L and KZ type engines) and petrol TRH HiAces. Quote
KDH <3
6 answers to this question
