Mokip Posted December 18, 2017 Share Posted December 18, 2017 Has anybody using the suzuki rs 2017 model e experience the above issue please share your thoughts and how to fix it or advice. Any recommendations please ? Quote Link to comment Share on other sites More sharing options...
3 TheFlyingFox Posted November 7, 2018 Share Posted November 7, 2018 (edited) Update Sorry for bumping an old thread just wanted to give a update for this problem. This is caused because the bushes in the steering rack doesn't support the road conditions in SL. The agents can repair it , the take the rack apart and replace 3 bushes on it (two on the edges and one on the steering motor area. They also check the steering angles with some specialized equipment. Once the rack is fitted back to the car they reset the steering position. 6 months warranty is given and they also say the new bushes are suited for SL.The problem can occur on miledges as low as 2000kms. i got the symptoms at 4500kms. Edited November 7, 2018 by TheFlyingFox 1 1 Quote Link to comment Share on other sites More sharing options...
0 Davy Posted December 19, 2017 Share Posted December 19, 2017 The lifetime and wear of suspension and steering components highly depend on where and how you drive your car. A car that's been driven on rough terrain will have worn out suspension/steering components when compared to a car with the same mileage, but driven on smooth tarmac. It can also be due to aftermarket wheels, over-inflated tyres and so on as well. This is of course not denying that some cars have inherent suspension/steering issues that cause them to wear faster than others, but the above reasons are likely causes for your issue. Especially on such a new car. If you have noise coming from the steering rack, it needs to be inspected first. If the damage is external to the rack (i.e. tie rod ends, rack ends etc.), they need to be replaced. If the rack itself is worn out and depending on the extent of the damage, it might be able to machine it and repair it. If not, a replacement steering rack will have to be installed. Quote Link to comment Share on other sites More sharing options...
0 ajm Posted December 23, 2017 Share Posted December 23, 2017 (edited) double post Edited December 23, 2017 by ajm Quote Link to comment Share on other sites More sharing options...
0 ajm Posted December 23, 2017 Share Posted December 23, 2017 On 12/19/2017 at 1:08 AM, Davy said: If you have noise coming from the steering rack, it needs to be inspected first. Expand hi, recently noticed a small low pitch groaning noise inside cabin passenger side ,accompanied by a small increase of tightness. It comes only when turning from left end position to centre position. What could be the reason,pump,rack,tie rods,steering column or anything else? This A4 has a full hydraulic steering system, no electric. Quote Link to comment Share on other sites More sharing options...
0 iRage Posted December 23, 2017 Share Posted December 23, 2017 On 12/23/2017 at 5:43 AM, ajm said: hi, recently noticed a small low pitch groaning noise inside cabin passenger side ,accompanied by a small increase of tightness. It comes only when turning from left end position to centre position. What could be the reason,pump,rack,tie rods,steering column or anything else? This A4 has a full hydraulic steering system, no electric. Expand Ohh....that line....if only Komi and VVT were around 4 Quote Link to comment Share on other sites More sharing options...
0 MV-5 Posted December 23, 2017 Share Posted December 23, 2017 On 12/23/2017 at 5:43 AM, ajm said: hi, recently noticed a small low pitch groaning noise inside cabin passenger side ,accompanied by a small increase of tightness. It comes only when turning from left end position to centre position. What could be the reason,pump,rack,tie rods,steering column or anything else? This A4 has a full hydraulic steering system, no electric. Expand So the problem is only there when you turn it from left end to center, when it reaches to center problem disappear even though you continue to turn it to right. Quote Link to comment Share on other sites More sharing options...
0 ajm Posted December 23, 2017 Share Posted December 23, 2017 On 12/23/2017 at 1:40 PM, MV-5 said: problem disappear even though you continue to turn it to right. Expand yes,only during the first half of turning from left to right. Quote Link to comment Share on other sites More sharing options...
0 Davy Posted December 24, 2017 Share Posted December 24, 2017 On 12/23/2017 at 5:43 AM, ajm said: hi, recently noticed a small low pitch groaning noise inside cabin passenger side ,accompanied by a small increase of tightness. It comes only when turning from left end position to centre position. What could be the reason,pump,rack,tie rods,steering column or anything else? This A4 has a full hydraulic steering system, no electric. Expand The tightness can be anything in the front steering/suspension assembly. It can be from a worn out ball joint in the tie rod end to a bent rack end that is causing the piston to move inside the rack at an angle, causing friction. However, since you say that there is a noise associated with it, my first guess is a clogged spool valve inside the steering rack. In any case, your car needs to be put up on a hoist, and the rack ends separated from the tie rod ends to manually check for differences in tightness, and worn/bent components. If all that is good, then I suggest flushing out the power steering fluid to clear out the system from debris and blocks. If the issue was due to a clogged spool valve, there's a good chance that this will clear it out. Note that what I've mentioned above is assuming your power steering pump is OK. If the groaning noise you hear is only at idle/low RPM, it might be that the pump is on its way out. Race the engine and steer to either side and observe if the noise disappears. If it does, it's likely that your power steering pump is not operating at full pressure at idle/low RPM. 1 Quote Link to comment Share on other sites More sharing options...
0 The Stig Posted December 24, 2017 Share Posted December 24, 2017 On 12/24/2017 at 12:20 AM, Davy said: The tightness can be anything in the front steering/suspension assembly. It can be from a worn out ball joint in the tie rod end to a bent rack end that is causing the piston to move inside the rack at an angle, causing friction. However, since you say that there is a noise associated with it, my first guess is a clogged spool valve inside the steering rack. In any case, your car needs to be put up on a hoist, and the rack ends separated from the tie rod ends to manually check for differences in tightness, and worn/bent components. If all that is good, then I suggest flushing out the power steering fluid to clear out the system from debris and blocks. If the issue was due to a clogged spool valve, there's a good chance that this will clear it out. Note that what I've mentioned above is assuming your power steering pump is OK. If the groaning noise you hear is only at idle/low RPM, it might be that the pump is on its way out. Race the engine and steer to either side and observe if the noise disappears. If it does, it's likely that your power steering pump is not operating at full pressure at idle/low RPM.I think the 2017 swift has eps and not a hydrolic pump. Quote Link to comment Share on other sites More sharing options...
0 ajm Posted December 24, 2017 Share Posted December 24, 2017 On 12/24/2017 at 12:20 AM, Davy said: If the groaning noise you hear is only at idle/low RPM, it might be that the pump is on its way out Expand hi,the pump was already making screeching noises at low rpm,was going to change it and do the flush. But this additional groaning noise inside cabin came recently,that's why the question if any other parts need to be checked. hi Stig,this is 15year old A4. Quote Link to comment Share on other sites More sharing options...
0 The Stig Posted December 24, 2017 Share Posted December 24, 2017 On 12/24/2017 at 2:57 AM, ajm said: hi,the pump was already making screeching noises at low rpm,was going to change it and do the flush. But this additional groaning noise inside cabin came recently,that's why the question if any other parts need to be checked. hi Stig,this is 15year old A4.I got confused because it was posted in the swift thread Quote Link to comment Share on other sites More sharing options...
0 Davy Posted December 25, 2017 Share Posted December 25, 2017 On 12/24/2017 at 2:57 AM, ajm said: hi,the pump was already making screeching noises at low rpm,was going to change it and do the flush. But this additional groaning noise inside cabin came recently,that's why the question if any other parts need to be checked. hi Stig,this is 15year old A4. Expand If the pump is faulty, you should replace it as soon as possible to prevent damage to the rack. A faulty pump usually fails to pump fluid maintaining the required pressure, and that will "starve" the rack and cause damage. Delay it more and be prepared to replace the rack as well. Quote Link to comment Share on other sites More sharing options...
0 hasisoft Posted January 29, 2018 Share Posted January 29, 2018 On 12/18/2017 at 7:17 AM, Mokip said: Has anybody using the suzuki rs 2017 model e experience the above issue please share your thoughts and how to fix it or advice. Any recommendations please ? Expand I m owning one !.. I also have the same problem but does not come all the time. some times after long drive on trafic it comes. 2 Quote Link to comment Share on other sites More sharing options...
0 shanjeevanm Posted March 14, 2018 Share Posted March 14, 2018 i bought one recently... im also experiencing similar problem. anyone found the root cause and the solution for this? Quote Link to comment Share on other sites More sharing options...
0 shanjeevanm Posted March 14, 2018 Share Posted March 14, 2018 On 1/29/2018 at 10:33 AM, hasisoft said: I m owning one !.. I also have the same problem but does not come all the time. some times after long drive on trafic it comes. Expand i bought one recently... im also experiencing similar problem. found the root cause and the solution for this? Quote Link to comment Share on other sites More sharing options...
0 VWvortex Posted March 14, 2018 Share Posted March 14, 2018 Mine makes a noise from the front right side . Car was bought at zero mileage and noise appeared after 200km. Not a big noise just an irritation over bad roads. Showed it to A*W and they could not detect a fault. Quote Link to comment Share on other sites More sharing options...
0 NeroX Posted March 14, 2018 Share Posted March 14, 2018 Anything related. Hope they haven't started sharing components with Japan https://www.motorbeam.com/2017-maruti-dzire-steering-assembly-replaced/ Btw did you try taking it to a good alignment joint. Maybe you could jack it up & look for any play on the wheels or noises coming when turning the steering. Could be anything from your steering rack, track rod, tie-rod ends, lower arms, anti roll bar joints etc. Very peculiar given its a brand new car. Quote Link to comment Share on other sites More sharing options...
0 shanjeevanm Posted March 14, 2018 Share Posted March 14, 2018 On 12/18/2017 at 7:17 AM, Mokip said: Has anybody using the suzuki rs 2017 model e experience the above issue please share your thoughts and how to fix it or advice. Any recommendations please ? Expand i bought one recently... im also experiencing similar problem. found the root cause and the solution for this? Quote Link to comment Share on other sites More sharing options...
0 Clark'sson Posted March 15, 2018 Share Posted March 15, 2018 On 12/23/2017 at 5:43 AM, ajm said: hi, recently noticed a small low pitch groaning noise inside cabin passenger side ,accompanied by a small increase of tightness. Expand If there is increased tightness you may need lubrication. The groaning may be due to the increased tightness. 1 Quote Link to comment Share on other sites More sharing options...
0 thirtyone Posted March 28, 2018 Share Posted March 28, 2018 Hi, I also have started experiencing the same problem. The noise started at around 4600+ Kms. Was anybody able to find what causes this and what the repair is like? Quote Link to comment Share on other sites More sharing options...
0 VWvortex Posted March 28, 2018 Share Posted March 28, 2018 took it to A*W...They seem to think its the design of the 'quicker' rack present on the RS. no solution so far. Quote Link to comment Share on other sites More sharing options...
0 MV-5 Posted March 28, 2018 Share Posted March 28, 2018 (edited) --deleted-- Edited March 28, 2018 by MV-5 Quote Link to comment Share on other sites More sharing options...
0 shanjeevanm Posted March 28, 2018 Share Posted March 28, 2018 On 3/28/2018 at 4:57 AM, MV-5 said: That's so strange. It sounds pretty much like grinding. I'm hoping to get this checked out, will reply on this thread if i have an update. Thanks for your reply! Expand i got it checked. im going to explain in layman terms since i dont know the technical jargons for these. the issue was this section which i have attached herewith. This section is what connects the rack and the steering column (as i was told), once the gap between the sections connect both ends is tightened i didnt get that noise. however i was asked to monitor if im getting the noise again. Quote Link to comment Share on other sites More sharing options...
0 shanjeevanm Posted March 28, 2018 Share Posted March 28, 2018 On 3/28/2018 at 4:08 AM, thirtyone said: Hi, I also have started experiencing the same problem. The noise started at around 4600+ Kms. Was anybody able to find what causes this and what the repair is like? Expand pls chk my response below Quote Link to comment Share on other sites More sharing options...
0 MV-5 Posted March 28, 2018 Share Posted March 28, 2018 (edited) -- deleted-- Edited March 28, 2018 by MV-5 Quote Link to comment Share on other sites More sharing options...
Mokip
Top Posters For This Question
8
5
Popular Days
Mar 28
8
Nov 8
7
May 15
7
Mar 14
5
shanjeevanm 8 posts
PrasadDHL 5 posts
ajm 4 posts
fcnarator 4 posts
Popular Days
Mar 28 2018
Nov 8 2018
May 15 2018
Mar 14 2018
Popular Posts
iRage
gonzagnr
Hello everybody. My name is Gonzalo and i am from Uruguay, in south america. I own a 2016 zc32s swift sport with 11.900km. In that time i had 3 steering racks replaced and one steering
hasisoft
Posted Images
54 answers to this question
