Chamara war Posted March 4, 2018 Posted March 4, 2018 I drive mazda demio2009. On carpeted roads it ok but when on normal roads it makes noise and not comfy. Is it suspension issue or what. Please help Quote
0 Twin Turbo Posted March 4, 2018 Posted March 4, 2018 upload a vid when you drive on bad roads,... hint.,.. stick to good surfaced roads,.. 1 Quote
0 MV-5 Posted March 4, 2018 Posted March 4, 2018 probably your Demio has no issue (it is as designed) . if you can test drive a another instance of this model then you can figure it out. if it is not possible, then get check the suspension system completely. (Tyre pressure also contributes considerably for "bumpy" ride ) Quote
0 Chamara war Posted March 4, 2018 Author Posted March 4, 2018 (edited) Im worried about gel mount issue. Its like no suspencion without shock absorbers while driving . Hmmm how to say it, feels like theres nothing beyween wheels and driving seats. Mileage is 48000 km as well. Edited March 4, 2018 by Chamara war Quote
0 Magnum Posted March 4, 2018 Posted March 4, 2018 If your shocks are worn out it's easy to notice it on cars as they make a noise when you go on bad roads. If you are car is being uncomfortable for small pot holes this could be due to bad/cheap tyres as well Quote
0 K.o.N.o.S Posted March 4, 2018 Posted March 4, 2018 (edited) Try changing your tire pressure. Mine Also a demio 2009 & I changed tire pressure -front 30 psi & back 29psi. Ride is far more smooth now. However demios tend to have steering rack issues.so better get this checked. Also be aware that demio is bit of a bumpy ride on hard roads by default. & that's the fun in that Edited March 4, 2018 by K.o.N.o.S Quote
Chamara war
5 answers to this question
