nalinda55 Posted March 20, 2018 Share Posted March 20, 2018 (edited) Hi all, I got toyota vitz 2007 (1.3cc) car.recently i have got changed its transmission oil (gear oil) with caltex Texamatic oil( picture of the canattached). Since its not recomended by the company i got a quection ... 1.is it okey to runwith the oil i used or do i have to change it to toyota cvt oil as soon as possible? Regars. nalinda Edited March 20, 2018 by nalinda55 Quote Link to comment Share on other sites More sharing options...
1 hrm Posted March 20, 2018 Share Posted March 20, 2018 You should immediately replace gear oil with Toyota CVT-TC. (Assuming you have CVT transmission and it's sensitive to the oil). Btw what makes you put this? Did someone recommend it? 1 Quote Link to comment Share on other sites More sharing options...
0 PerfMad Posted March 20, 2018 Share Posted March 20, 2018 On 3/20/2018 at 8:18 AM, nalinda55 said: Hi all, I got toyota vitz 2007 (1.3cc) car.recently i have got changed its transmission oil (gear oil) with caltex Texamatic oil( picture of the canattached). Since its not recomended by the company i got a quection ... 1.is it okey to runwith the oil i used or do i have to change it to toyota cvt oil as soon as possible? Regars. nalinda Expand If your car is having a CVT gearbox, then yes, u should use the correct CVT oil recommended by the agent. normal ATF gearbox oil is thicker than CVT oil, which may result it premature issues in your CVT gearbox. 1 Quote Link to comment Share on other sites More sharing options...
0 nalinda55 Posted March 20, 2018 Author Share Posted March 20, 2018 Thanks.yes im new to this and thats the first time i got changed the gear oil.a known spare part seller has recomended it and he re confirmed it when i phoned back to him when the service centre people quectioned .wont it be a problem if i replace the oil with toyota cvt now ,like mixing the oil ? Quote Link to comment Share on other sites More sharing options...
0 PerfMad Posted March 20, 2018 Share Posted March 20, 2018 On 3/20/2018 at 9:09 AM, nalinda55 said: Thanks.yes im new to this and thats the first time i got changed the gear oil.a known spare part seller has recomended it and he re confirmed it when i phoned back to him when the service centre people quectioned .wont it be a problem if i replace the oil with toyota cvt now ,like mixing the oil ? Expand best solution is to flush the existing gear oil and refill with recommended one. Otherwise there could be residue which might create issues in the long run. CVT gearbox and its internals are really sensitive. Therefore, you need to maintain it properly to get the highest benefit out of it. Quote Link to comment Share on other sites More sharing options...
0 BuBi Posted March 22, 2018 Share Posted March 22, 2018 On 3/20/2018 at 8:18 AM, nalinda55 said: Hi all, I got toyota vitz 2007 (1.3cc) car.recently i have got changed its transmission oil (gear oil) with caltex Texamatic oil( picture of the canattached). Since its not recomended by the company i got a quection ... 1.is it okey to runwith the oil i used or do i have to change it to toyota cvt oil as soon as possible? Regars. nalinda Expand One of my friends has bought a BJ5P with a bad tranny because of this Gear Oil. The idiotic previous owner had use this oil instead of the Mazda recommended one which costs around 10-12k. Now he has to replace the entire gear box. So, I advice you people proceed with caution. 1 Quote Link to comment Share on other sites More sharing options...
0 M. Khan Posted May 1, 2023 Share Posted May 1, 2023 I have Toyota Vitz 2010, recently I change Transmission oil, Car engine os 1300 cc, I put ATF oil in. Some friends says it wrong some says it's fine. Nothing will happen, but one thing I observed on Moterway. My car not going 120km per hour.. its should touch 150km. I bit confused, what to do now.. should I change Gearbox or just oil.. gearbox will cost me 350 dollars. Quote Link to comment Share on other sites More sharing options...
0 iRage Posted May 2, 2023 Share Posted May 2, 2023 Uhhh...2010 Vitz...hmm...doesn't it have a CVT and require CVT fluid ? AT oil is not the same as CVT fluid. Quote Link to comment Share on other sites More sharing options...
nalinda55
Hi all,
Regars.
nalinda
7 answers to this question
