ChamaraW Posted May 17, 2018 Posted May 17, 2018 Appreciate your expert advice on Audi A4 2011 2.0 TDI and 1.8T models. Whether these engines and transmissions are reliable? What would be the maintenance cost? Quote
vag2 Posted May 17, 2018 Posted May 17, 2018 the diesel will give you 15 kms per litre,but with age it is more likely to develop issues like oil leaks,oil consumption,DPF,Turbo leaks like any other Jap vehicle.Control arms in the suspension need to be replaced every 3-5 years of normal use for both versions, but they save the shock absorbers. it all depends on how the previous owner has maintained and used it. 1 Quote
Crosswind Posted May 17, 2018 Posted May 17, 2018 6 minutes ago, vag2 said: the diesel will give you 15 kms per litre,but with age it is more likely to develop issues like oil leaks,oil consumption,DPF,Turbo leaks like any other Jap vehicle.Control arms in the suspension need to be replaced every 3-5 years of normal use for both versions, but they save the shock absorbers. it all depends on how the previous owner has maintained and used it. Any other jap vehicle??? 1 Quote
Twin Turbo Posted May 18, 2018 Posted May 18, 2018 (edited) If you are getting one, get one with a good maintenance history. as tbelt replacements and atf changes are vital . The diesel gives you power and efficiency . Edited May 18, 2018 by Twin Turbo Quote
peugeot407 Posted May 18, 2018 Posted May 18, 2018 Good vehicle. no issues, my brother is using a 1.8T and it has clocked 130K without any major repairs. Quote
