June 3, 20188 yr Hi,ย Is there a place that would repair an ageing Bonnet Insualtion or a place that might have a replacement for a Toyota Hilux (2001). ย
June 3, 20188 yr ย Hi and welcome to AL. For longer life of said insulation, dont wash or even get itย wet. The pic don't look too bad if you ask me.โบ๏ธย There is no factory equipment replacement.ย Therfore, keep the originality of the car by doing nothing,.. or risk making your car look like it got submerged in a flood.? Cheers, TT. ย Edited June 3, 20188 yr by Twin Turbo
June 3, 20188 yr Yeah, that doesn't look bad at all for a 17 year old vehicle. I think I see the bottom clip mounting holes are torn off. If you can just address that by reinforcing it with a bit of plastic sheet on the reverse side of the insulation, that would do the trick. Finding one of these will be extremely difficult. One of my cars had a replacement bonnet and was missing this. For the most part of my ownership, I was trying to find an insulation, but couldn't. Ended up using McFoil to make one myself. Lookedย hideous but did it's job.ย
June 3, 20188 yr Author Thanks Guys. Yeah the issue is 3 of the clip mounting holes are broken now. I will try whatย you have suggested to get it fixed. Thanks again.ย
