I recently bought a Japan Suzuki Swift 1.3 (YOM 2005). After I drive it for around 20kms, it indicates the check engine indicator and at the time engine will give a noticable miss. Usually this happens when I accelerate bit more after slowing down. After sometime, the indicator turns off and engine will come back to normal. Sometimes if i try to start the engine after i turned it off, it doesnt start at all. And this issue won't indicate when we scanned it.
Here's what I have done so far. I have changed spark plugs and the coils. Changed the fuses in the fuse box to all original japan fuses. Replaced the cam sensor.
So far nothing has worked. My elecrical guy's opinion is that we should replace the control box.
If any of you guys has come across this kind of issue or if you can think of something, please share.
maskventura
Hi Experts,
Thanks,
M
6 answers to this question
