Guys, I own a vios 2003 car and just want to know how much should I use when mixing a good coolant (hope you could recommend one too).
And its been few months since i got this car and all this time I was just using normal tap water..
Appreciate your valued comments...
4 answers to this question
Please note - when draining your old radiator coolant from your cooling system remember to get your vehicle properly washed specially the undercarriage because old radiator coolant may be acidic and can cause corrosion to the chassis and frame.... :action-smiley-028:
If you want your engine to live a long life I would recommend you to use only the best products on the market. Your engine needs to use a high-quality coolant. For example, I use only the coolant from ******. I never had any problems with it. I am very pleased with the quality and I have only positive feedback. One of my friends was using a poor quality one and he had to change the entire coolant system of his engine. Believe me that the repair was very expensive for him. Better is to avoid such cases.
Edited by iRage
