I recently purchased Corolla 141, but i  notice that when door is open dashboard indicate Yellow Triangle symbol (Please see my image attached), but when all doors close its disappear and when its engine start also its never appear ,Is this normal? Please help
Edited by Sirimanna
You need to get a diagnostic scan to pinpoint the exact problem. The yellow triangle symbol has many meanings on different models. Some places do the scan for free during promotions, services, repairs or random events.
For peace of mind, do inspect the car a bit using your knowledge. Listen for any weird noises during start and see if all the buttons and functions are working properly, including lights and horn.
Does it come on when the trunk lid is open too? Then it’s probably just a warning so you don’t drive off with the door or trunk open. Nothing to worry about.
Thank you bro, I will check
Yes its appear with the trunk door too.. Yes now i feel probably its just a warning.. Thank you soo much for your reply :)
I have got a corolla fielder as one of my fleet car and a Jap import, if you look at the information panel below the RPM meter you will see something message pop up with the door icon next to it, since mine is a NZ new it's in indicates in english "Door open" as mentioned by ShintaroX
This is not something you take the car to diagnose, use the google translator, that should have explain a lot.
regards,
JC
regards,
JC
Thank you john, Appriciate your reply.. i will check :)
It's normal no need to diagnose.Yellow triangle means car is not ready to drive.In this case it came because doors are open and not ready to drive with open doors.And also it blinks and make "beep beep" noise if you drive while parking brake is applied.
Thank you soo much your valuable reply ???
