ruwansunk Posted September 3, 2020 Posted September 3, 2020 (edited) nissan fb14 delco repair Edited September 4, 2020 by Davy Edited Topic Title. Added Search Tags. Quote
ruwansunk Posted September 3, 2020 Author Posted September 3, 2020 What is different 22100 0M300 & 22100 0M301 nissan fb 14 distributor Quote
kusumsiri Posted September 4, 2020 Posted September 4, 2020 Hi and welcome to the forum @ruwansunk, It seems that no any capable member seen this to answer you yet. So please wait some time without opening multiple threads. P.S. @Davy or any @Admin may merge these threads. 1 1 Quote
Davy Posted September 4, 2020 Posted September 4, 2020 Threads merged. Thanks for flagging @kusumsiri! 1 Quote
Davy Posted September 4, 2020 Posted September 4, 2020 8 hours ago, ruwansunk said: What is different 22100 0M300 & 22100 0M301 nissan fb 14 distributor A quick Google search reveals that the two part numbers are interchangeable. The 301 is probably a revision of 300. So you can use either. What's the issue with your distributor? I f the cap is cracked or something, you can just purchase the cap instead of the whole unit. 1 Quote
ruwansunk Posted September 5, 2020 Author Posted September 5, 2020 Not cracked ..less ignition ..not properly burn fuel ..when change other distributor problem was solved .. Quote
nayanarlk Posted January 5, 2021 Posted January 5, 2021 @ruwansunk Where did you buy the distributor? I have a FB13 Power Package and I also need a distributor. My car is misfiring randomly and a carburetor was done, all 4 plugs and the wires that run from the distributor to the plugs were replaced, but it's still misfiring. Although it is random, it happens all the time, specially when I slow down because the vehicle in front of me slowed down and accelerating again. Quote
