virajn Posted April 4, 2021 Posted April 4, 2021 Hi, In my car I noticed rust in back door hinges. Back door ( dickey door ) recently replaced. What can I do to fix this ? Quote
Twin Turbo Posted April 4, 2021 Posted April 4, 2021 (edited) Spray WD40 on the rust. Check if the vehicle is a tsunami victim 🤫 TT. Edited April 8, 2021 by Twin Turbo Quote
Ruslan Posted April 4, 2021 Posted April 4, 2021 For proper fixing, remove the door.. scrape off the rust on the hinges and panel.. apply rust converter, sync spray.. antirust primer, spray paint again.. (you will have to find a proper body shop and make sure they follow the procedure.. ) unless rust will surface again after sometime.. this looks like half a** job of a body shop.. 2 Quote
iRage Posted April 5, 2021 Posted April 5, 2021 Yes...like @Ruslan said you should remove it and respray the area...but make sure you remove all traces of rust if not all that you will be doing ins spray pain on top of the rust and it will keep rusting underneath the paint surface again. This very well could have started because the paint might have gotten scratched during installation (or there was rust previously but they did not do a proper job cleaning it off and painting it. 1 Quote
virajn Posted April 6, 2021 Author Posted April 6, 2021 Thank you all for responses. Will the agent be able to good job here ? Or any recommendations I can look for ? Quote
Ruslan Posted April 6, 2021 Posted April 6, 2021 9 minutes ago, virajn said: Thank you all for responses. Will the agent be able to good job here ? Or any recommendations I can look for ? You can check with them. ask what is the procedure they're going to do and proceed with them if there method is satisfactory. above is the method to ged rid of surface rust. 1 Quote
