Waruna Lakshantha Posted August 9, 2021 Share Posted August 9, 2021 (edited) Hi, My gp5 (year 2015) front disc have lines (sets) as attached image. These lines can be seen in both side in both discs as same way. I want to know is this normal or damaged? Some technicians say this is a original and some are say damaged and want to be face. Edited August 11, 2021 by Waruna Lakshantha Quote Link to comment Share on other sites More sharing options...
mazdaspeed Posted August 10, 2021 Share Posted August 10, 2021 First, I don’t think that’s normal to have such deep lines on your disk – The technician who said it’s normal /Original should not be consulted again for sure. The depth of the marks are not visible due to the angle of the picture but you may be able to take it to a lathe and face off the groves till the whole disk is smooth. The pads seems to be the culprit – maybe some cheap stuff – What do you mean by “paste” are you referring to pasting the pads ? If yes ….. well …. I’m lost for words and will have to revert to sweet words to go further which is not allowed in this forum sadly. 1 Quote Link to comment Share on other sites More sharing options...
Waruna Lakshantha Posted August 11, 2021 Author Share Posted August 11, 2021 On 8/10/2021 at 5:16 PM, mazdaspeed said: First, I don’t think that’s normal to have such deep lines on your disk – The technician who said it’s normal /Original should not be consulted again for sure. The depth of the marks are not visible due to the angle of the picture but you may be able to take it to a lathe and face off the groves till the whole disk is smooth. The pads seems to be the culprit – maybe some cheap stuff – What do you mean by “paste” are you referring to pasting the pads ? If yes ….. well …. I’m lost for words and will have to revert to sweet words to go further which is not allowed in this forum sadly. Expand Thank you for your feedback with sharing your knowledge and experience. Sorry for the spelling mistake. it's not not "paste" it should be you called "face off the groves". Quote Link to comment Share on other sites More sharing options...
iRage Posted August 12, 2021 Share Posted August 12, 2021 Second what Mazdaspeed said.... When you look at a disk you may see circular patterns but definitely not grooves. Grooves are a in dication that the pads (or something else) is etching in to the disc. It could be bad pads or something that was stuck inbetween the disks and the pads created those grooves(but then it would be on just one side). Thank you for correcting what the mechanic said...because I got scared thinking that people actually resorted to filling up brake discs with putty and other other compounds..phew. You can get it lathered, but please take it to a proper, experienced place....I know many garages which just took a grinder and scrubbed it off...as the surface of the disc was not "straight" and the brakes started pulsating. 2 Quote Link to comment Share on other sites More sharing options...
