June 5, 20242 yr Author Update on 5th June 2024: I visited earlier today and got the following updates: Ordered parts from abroad have arrived. They should be able to complete the assembly of the engine today and will work on fitting the engine and the components on the car tomorrow. Massive carbon build-up was identified on the Valves and was cleaned out (not replaced). The pistons did not require replacing and were cleaned up due toย excessive sludge and carbon build-up after being told there was no sludge.
June 6, 20242 yr Heyย @tiv, On 6/5/2024 at 5:06 AM, tiv said: Take pics of the Bore, Pistons, old rings and the big end bearings. Get them to inspect the head (Visual or via testing gear) By meaning overhaul - clarify with them which path they intend to take 1. Replace rings, refit (No pitting on pistons, perfect Bore) - This is the shortest path one could take 2. Replace Rings Pistons Refit (Perfect Bore) 3. Replace Rings, Re Sleeve Refit Standardย ( Scored bore) 4. Replace Rings Re-Bore, Big Pistons Refit (+1 size) ( What I would do) Just for my knowledge, what is the reason you would go for re-bore and larger pistons (even if a re-bore is not needed)? To gain additional power? Edited June 6, 20242 yr by Izza grammar
June 6, 20242 yr Author 22 minutes ago, Izza said: Heyย @tiv, Just for my knowledge, what is the reason you would go for re-bore and larger pistons (even if a re-bore is not needed)? To gain additional power? I'm curious to know the same too, and I wonder if the companies here would even be able to do it properly. I'd shit my pants if my engine required re-boring lol
June 7, 20242 yr Author Update on 7th June 2024: I visited Hybrid Hub and the engine here are the updates: The engineย is fully assembled. All the parts have been put back together in the car. @tivย I had a chat with the mechanics, and they took the "1.ย Replace rings, refit (Noย pitting on pistons,ย perfectย Bore)" path. They also replaced the CVT oil. All sealsย were replaced with the head gasket, the water pump is getting replaced, and new coolant is being added (was running on water or something for testing),ย Forgot to specify specifically about alternator bearings, AC compressor bearings, radiator, and starter motor. They've promised to do their "30-point" inspection on top of going through a detailed review of all components that might need work - The mount looks like it needs to be replaced and there's an issue on the shock mount as well it seems, which I recently replaced, weird, but they promised to give me more context tomorrow (8th June).
June 8, 20242 yr Author Update on 8th June 2024: I got my baby back today and seems to run fine. The total damage was 361,000 LKR (50k VAT, ugh!!!). What was done: Rings were replaced. The engine was fully cleaned up. The general overhaul kit. Spark plugs were replaced. CVT oil was replaced. Post-overhaul maintenance schedule: 1000 km after overhaul:ย Engine oil change, filter change. Apart from the above, the brakes seem to have an issue which requires it to be repaired. Engine Coolant is recommended to be replaced after the 1,000 km since it was not changed during the overhaul. Shock mounts need replacing. ๐ฅฒ 2000 km after overhaul:ย Car check-up will decide if anything needs to be done. Overall, the experience wasn't too bad, apart from the typical Sri Lankan stuff where you keep visiting the workshop to ensure the work is being done. If I had not visited today, I wouldn't have been able to collect the car today (the car was fully done, their testing was complete and they only had their 30-point inspection checklist to be performed). ย
June 8, 20242 yr Author Thank you @iRage,ย @tiv, and everyone here for the advice! Much appreciated! I will keep updating the progress on the post-overhaul maintenance, etc. Edited June 8, 20242 yr by Noobdriver
June 9, 20242 yr I hope everything starts looking up for the car.ย Does the general overhaul kit include all the gaskets and oil seals ? As a general rule of thumb, when ever the engine or transmission is out, try to replace those hard-to-get-to oil seals and stuff. Especially in old cars. Because when those parts need replacing they usually end up being a case of spending/paying-for a day of two worth of labor just to replace a 1000LKR part.
June 9, 20242 yr Author 1 hour ago, iRage said: I hope everything starts looking up for the car.ย Does the general overhaul kit include all the gaskets and oil seals ? As a general rule of thumb, when ever the engine or transmission is out, try to replace those hard-to-get-to oil seals and stuff. Especially in old cars. Because when those parts need replacing they usually end up being a case of spending/paying-for a day of two worth of labor just to replace a 1000LKR part. Yes, all the seals were replaced and the gasket too. I've driven about 60 km since I got the car back (they drove about 70 before handing me the car), and so far, it's smooth. I'm maintaining around 50 km/h at very low RPMs. Edited June 9, 20242 yr by Noobdriver
June 10, 20242 yr 11 hours ago, Noobdriver said: I'm maintaining around 50 km/h at very low RPMs. Usual break-in would require you to gently increase speed and let the engine build up revs over time. So keep doing what you are doing for now but also start building these up with time. Now..don't get on the expressway and drive 100+km at 100kmph+ for hours. When you do want to drive fast...first make sure they are small short low stress trips. This also means it can't be quick accelerations to 100 and then slow down for traffic after a minute sort of drive. I would suggest you take an early morning drive to somewhere close (e.g., Wallawatte to Moratuwa/Kalutara kind of thing) when the roads are empty, and you can bring the car up to speed gradually and then back to low speed...gradually.
June 10, 20242 yr On 6/6/2024 at 12:34 PM, Izza said: Heyย @tiv, Just for my knowledge, what is the reason you would go for re-bore and larger pistons (even if a re-bore is not needed)? To gain additional power? If proper scoring, or a "step" sorta defect at the top end of the sleeve is felt, or at the worst, a play Options would be to replace refit new rings, put a larger ring, Or bore to a larger size. Why would I go to size higher? The reason being none of the machine shops in Sri Lanka can actually cut and position new sleeves to manufacturer level. Also the Quality of sleeves are not to the standard that came from the company. Many rebuilds on the average manage about 100,000km and then start to burn oil and, with that symptom they manage another 100,000km (200,000km in total)ย Whereas a well maintained factory unopened engine can do approx. 300,000km + (Doesn't apply to 660cc engines and there are variables) So though costly, the best possible outcome in a rebuild from my experience would be to rebore, one size higher pistons, rings, the whole kit. This way everything is new. I built my first engine with my uncle who owned a workshop in 2005, he's no longer in the country. Have had got mechanics rebuild over 20-30 engines to date and this method has always worked better than sleeves. With this rebuild - Power gains not so much to a stock engine, just that the engine will run like a new one and you will feel the difference.ย
June 10, 20242 yr You need to cause variations in RPM to bed the rings, Stop and Go traffic is ideal from my experience but don't floor between the lights and let it idle about 10 min before stopping. (Applies to the first 1000km). On an interesting point, most of the new cars say that they are factory Run-in / Seasoned. But I was always OCD and made sure first 1000km was very careful between 1000-2000RPM and then the next 1000km was a bit more,ย Lastly the oil change.ย The newer corvettes have an electronic rev limiter and until you cover 2000miles it does not release the full range. Apparently a similar fad was there in the Land Cruisers in the 80s-90s where a tamper proof seal was placed on the injector pump, and was asked to bring in after 2000km where they will change the oil and release the seal, allowing more fueling once the engine has been broken in / seasoned. The best part is this, I've seen a Land Cruiser 1HZ engine in Sri Lanka with this seal intact, meaning its very very very low mileage and the bugger is asking 2mil for it
June 10, 20242 yr Author Thanks for the valuable advice @tivย @iRage. @tivย If my engine can run without issues for 100,000 kilometers, more than enough for me. I don't go out much, I would at most drive 10,000 km a year and a significant chunk of it would be road trips/traveling during breaks. I only drive about 300-500 km a month for my actual chores since work is not that far from my house and I work from home and go to the office twice a week (hybrid). I don't mind another overhaul after a decade, lmao. I plan to keep the car for as long as possible (at least 5 years) and never want to sell it if I upgrade the car in the future and be able to keep my current as well (first car love). I've driven roughly 200 kilometers now and went to Bentota last night. Here is how I went, please correct me if I'm doing something that could be improved or wrong: Gently touch the throttle and bring it up to 50 km/h, maintain for 2-3 minutes. Release the throttle entirely till it brakes automatically to about 30 km/h (a good 15ย seconds). Slowly throttle back up to 50 km/h and maintain for 2-3 minutes. Release the throttle entirely till it brakes automatically to about 30 km/h Slightly throttle a little more to 50 km/h and repeat. Also, when there were signal lights ahead, I just left the throttle to let it come to a stop on its own andย brake towards the end. Also, I was surprised to see that over the 200 km, I drove yesterday, my fuel economy was 22 kmpl for the trip, I've never seen this number before. The most I have ever gotten was 15 kmpl on the highway at 80-90 kmphย
June 23, 20242 yr Author Update time! Hit the 1,000 km mark on Friday, 21st of June, 2024 since the overhaul. I took my car for service yesterday, 22nd June 2024 and they did the following: Engine oil change - Toyota 5w30 Oil filter change There was an issue with the front brake pistons, so they cleaned them up and changed the brake oil (since cleaning the brake piston drains the old brake oil). I informed Hybrid Hubย about the "shock mounts" requiring to be replaced as suggested by Hybrid Hubย during the vehicle check-up after the overhaul. I confirmed this from a trusted wheel alignment center employee before I dropped the car in for service. Hybrid Hubย suggested that this repair doesn't need to be done and I could do this repair at the next service (after 2,500 km). However, the moment I took it down to the road, there was a series of explosive "tak-tak" sounds every time I went through not very smooth roads as explained byย the wheel alignment guy, who told me that the shock mounts were completely gone and needed immediate attention. I still drove to the wheel alignment place and asked him to re-check and see if what they were telling was the truth and he re-checked (they raised the car) and re-confirmed that this needs immediate attention or could result in camber damage. I will drop the car again tomorrow (Monday, 24th June) at Hybrid Hub to get them to sort this for once. Another problem I have is that when I'm driving during rain, there is a water leak or something near my accelerator/brake pedal that leaks a couple of drops of water. Curious to know what the problem is as I've told Hybrid Hub multiple times to check this issue and report back. ย
June 24, 20242 yr 13 hours ago, Noobdriver said: Update time! Hit the 1,000 km mark on Friday, 21st of June, 2024 since the overhaul. I took my car for service yesterday, 22nd June 2024 and they did the following: Engine oil change - Toyota 5w30 Oil filter change There was an issue with the front brake pistons, so they cleaned them up and changed the brake oil (since cleaning the brake piston drains the old brake oil). I informed Hybrid Hubย about the "shock mounts" requiring to be replaced as suggested by Hybrid Hubย during the vehicle check-up after the overhaul. I confirmed this from a trusted wheel alignment center employee before I dropped the car in for service. Hybrid Hubย suggested that this repair doesn't need to be done and I could do this repair at the next service (after 2,500 km). However, the moment I took it down to the road, there was a series of explosive "tak-tak" sounds every time I went through not very smooth roads as explained byย the wheel alignment guy, who told me that the shock mounts were completely gone and needed immediate attention. I still drove to the wheel alignment place and asked him to re-check and see if what they were telling was the truth and he re-checked (they raised the car) and re-confirmed that this needs immediate attention or could result in camber damage. I will drop the car again tomorrow (Monday, 24th June) at Hybrid Hub to get them to sort this for once. Another problem I have is that when I'm driving during rain, there is a water leak or something near my accelerator/brake pedal that leaks a couple of drops of water. Curious to know what the problem is as I've told Hybrid Hub multiple timesย Regarding the water leak, check if any AC lines are blocked as well (drain hose I think it's called). I know you have mentioned it's only during rain but better to check. Also did you do any windscreen related repairs recently? That's also a common problem for water leaks. In the meantime, check your boot for any collected water, that's another common issue, where hatchback tail light clusters leaking water and that water gets under the carpets (not related to your water droplets leaking but safe to check) ย ย
June 24, 20242 yr Author 1 minute ago, RusT said: Regarding the water leak, check if any AC lines are blocked as well (drain hose I think it's called). I know you have mentioned it's only during rain but better to check. Also did you do any windscreen related repairs recently? That's also a common problem for water leaks. In the meantime, check your boot for any collected water, that's another common issue, where hatchback tail light clusters leaking water and that water gets under the carpets (not related to your water droplets leaking but safe to check) ย ย Hi, thank you for this. I have not done any windscreen-related repairs except for a polish. Either way, I dropped the car in today for a few things: Update - 24/June/2024. Dropped the car in to check the water leak (they too suspect an AC line block). There is also a very loud noise audible when going through a rough damaged road as previously mentioned and the technicians believe it might be a steering rack issue and not the shock mount but they're going to investigate this.
July 25, 20242 yr Author Forgot to update this, @RusTย The water leak was some piece/cover that had come off and, that fixed it. They tried explaining and I couldn't understand honestly. But the issue is 100% sorted now, been over a month. Also, they did a rack-end overhaul to fix the 'tak-tak' sounds. It is much better now, still, the steering mounts need to be replaced, and they suggested deferring it (I don't understand why).ย
January 29, 20251 yr Author So a big update... Last December, I completed the first 5,000 km run without an oil change as recommended (After oil changes at 1,000 km and 2,500 km intervals) on 5w30 Toyota Oil (SN). On the 1,000 km and 2,500 km runs, there was no oil burn. However, on the 5,000 km run the oil level had dropped by about a third between the minimum and maximum points on the dip stick. Hybrid Hub adviced me to change from 5w30 to 10w30. Running it now, almost 3,000 km done! @iRageย If you were in my shoes and noticed oil burn exactly 8,500km after an overhaul with 5w30, would you be concerned? I'm going to run out of the overhaul warranty in like 3 months, so I'm pushing the car to run 5,000 km ASAP to evaluate. Edited January 29, 20251 yr by Noobdriver
January 30, 20251 yr 8 hours ago, Noobdriver said: would you be concerned? A little bit. It could be signs of things like piston seals not seating properly or valve stems issues or even something simple as a faulty PCV valve.ย How is the engine fairing in general? Compression is okay? Did the previous oil changes show any signs of excessive metal shaving? Does the car smoke (cold and warm...sometimes you might not even see it but get very soft smell)? I don't see the point in changing from 5W-30 to 10W-30 because the cold component does not affect you in Sri Lanka; but I would do exactly what they say (if things have gone bad and you want it fixed under warranty you don't want to create a scenario where they can tell you it is because you did something without following their advice). Observe, keep testing. Make sure everything is recorded with them well in advance of the warranty running out.ย
January 30, 20251 yr Author 18 minutes ago, iRage said: A little bit. It could be signs of things like piston seals not seating properly or valve stems issues or even something simple as a faulty PCV valve.ย How is the engine fairing in general? Compression is okay? Did the previous oil changes show any signs of excessive metal shaving? Does the car smoke (cold and warm...sometimes you might not even see it but get very soft smell)? I don't see the point in changing from 5W-30 to 10W-30 because the cold component does not affect you in Sri Lanka; but I would do exactly what they say (if things have gone bad and you want it fixed under warranty you don't want to create a scenario where they can tell you it is because you did something without following their advice). Observe, keep testing. Make sure everything is recorded with them well in advance of the warranty running out.ย Yes, there was a day with excessive smoking for like 3 seconds on a cold start, but to be fair it was fairly cold that day (around November). I'm not sure what you mean by compression, do you mean I should do a compression test? Metal shaving, I pointed this out, they said that is not a problem apparently. Wonder if there is a lab I could send samples to? Exactly, I was like how does 5w30 to 10w30 help lol. The warm engine and never had smoking issues. Cold start, I can smell some smoke, but nothing visible.
January 30, 20251 yr 28 minutes ago, Noobdriver said: Yes, there was a day with excessive smoking for like 3 seconds on a cold start, but to be fair it was fairly cold that day (around November). Depends on what the smoke was. Was it the usual exhaust condensation or was it actual oil burning smoke? 29 minutes ago, Noobdriver said: do you mean I should do a compression test? Yes...have you done a compression test after the run in period ? Are there any weird noises (e.g. piston slap, valve knocks, etc...) 30 minutes ago, Noobdriver said: Metal shaving, I pointed this out, they said that is not a problem apparently. Wonder if there is a lab I could send samples to? It is normal to have excessive metal shaving soon after a rebuild. But it is supposed to reduce. Has it reduced ? So does it have lesser or more metal shavings than before ? I would have thought 8500-9000km would have been sufficient for the metal shavings to subside. 31 minutes ago, Noobdriver said: Exactly, I was like how does 5w30 to 10w30 help lol. Maybe it is because at cold start up the oil would have a higher viscocity? Don't question at this stage. Just do it. You need to follow there exact steps so you have a greater chance of resolving any issues that might be there under warranty. 35 minutes ago, Noobdriver said: The warm engine and never had smoking issues. Cold start, I can smell some smoke, but nothing visible. Well...what do you mean by smelling smoke ? Smoke can smell like unburnt fuel, burnt charcoal, over boiling water, burning oil...etc... Assuming you are smelling burning oil when cold...it could be a valve seal issue (valves not sealing properly),ย ย could be a clogged PCV...or it could be a small valve cover or some oil seal seeping a bit of oil and that getting burnt off of a now-heating-up engine.
January 30, 20251 yr Author 48 minutes ago, iRage said: Depends on what the smoke was. Was it the usual exhaust condensation or was it actual oil burning smoke? Yes...have you done a compression test after the run in period ? Are there any weird noises (e.g. piston slap, valve knocks, etc...) It is normal to have excessive metal shaving soon after a rebuild. But it is supposed to reduce. Has it reduced ? So does it have lesser or more metal shavings than before ? I would have thought 8500-9000km would have been sufficient for the metal shavings to subside. Maybe it is because at cold start up the oil would have a higher viscocity? Don't question at this stage. Just do it. You need to follow there exact steps so you have a greater chance of resolving any issues that might be there under warranty. Well...what do you mean by smelling smoke ? Smoke can smell like unburnt fuel, burnt charcoal, over boiling water, burning oil...etc... Assuming you are smelling burning oil when cold...it could be a valve seal issue (valves not sealing properly),ย ย could be a clogged PCV...or it could be a small valve cover or some oil seal seeping a bit of oil and that getting burnt off of a now-heating-up engine. I think the first one was just condensation, when I started the car, nothing wrong, I placed the car on reverse gear and hit the gas pedal a little bit, and it started smoking crazy for a second or two and it stopped. Compression test not yet, I pointed them it out and they were like its not necessary, but I was thinking its needed to do but wonder what a proper place would be to get one so if there's any issue I have something to back myself up after getting it from the other place and getting them to do one. No, metal shaving was a little bit in the first service, the third service I just asked them whether it was a thing still and the mechanic was like it looks clean. -- About smelling smoke, I don't know how to describe the smell, it smells like literally smoke from the car exhaust, idk how to describe, I'm not good with smells. -- Hmm, that's insane. Hopefully nothing serious. I don't want to crash another 360k.
April 26, 20251 yr @Noobdriverย How's the car coming along? We haven't heard from you in about 3 months. Everything shipshape?
April 26, 20251 yr Author 11 minutes ago, Hyaenidae said: @Noobdriverย How's the car coming along? We haven't heard from you in about 3 months. Everything shipshape? Hey, I did an oil change after another 5,000 km, like 3 weeks ago, had an oil leak in the crank pulley, the seal had worn off and I was nearly at the 5,000 km mark. Just a quick 3,000 rupee repair with labour and the car was totally good, ran a good 1,000 km. However, I sold it last Tuesday and got myself an FK6 for a change lol. At first I thought the car buyers would shit their pants when I mention the engine overhaul, but the guy who bought it was really happy to see that I put in the money to repair it properly from a reputed agent and the warranty still exists till June this year. I told him all the issues transparently and he was very happy to purchase the car given the absolute mint condition I had the car in. I'm glad I was able to sell the car at a very good competitive price in the market with all honesty and no bs. Gives me a clear conscience and peace. Edited April 26, 20251 yr by Noobdriver
April 26, 20251 yr 33 minutes ago, Noobdriver said: Hey, I did an oil change after another 5,000 km, like 3 weeks ago, had an oil leak in the crank pulley, the seal had worn off and I was nearly at the 5,000 km mark. Just a quick 3,000 rupee repair with labour and the car was totally good, ran a good 1,000 km. However, I sold it last Tuesday and got myself an FK6 for a change lol. At first I thought the car buyers would shit their pants when I mention the engine overhaul, but the guy who bought it was really happy to see that I put in the money to repair it properly from a reputed agent and the warranty still exists till June this year. I told him all the issues transparently and he was very happy to purchase the car given the absolute mint condition I had the car in. I'm glad I was able to sell the car at a very good competitive price in the market with all honesty and no bs. Gives me a clear conscience and peace. Did you say FK6? That's quite the upgrade from the Vitz! Congratulations! And a fitting end to the Vitz saga too, all's well that ends well ๐
April 26, 20251 yr Author 15 minutes ago, Hyaenidae said: Did you say FK6? That's quite the upgrade from the Vitz! Congratulations! And a fitting end to the Vitz saga too, all's well that ends well ๐ Thank you, brother! Vitz was more than just a car for me, it was my first car. I had too many memories with it, and it was very hard to let go, but my bank account just couldn't foot the continuous repair bills, lol.
