January 25, 20251 yr Author Solution On 1/23/2025 at 11:36 AM, Hyaenidae said: Where are you from? If you're around Kandy I hear the recently opened "Knight Auto Works" has the latest equipment and expertise for tuneups. Thank you so much. Any place in Colombo?ย I urgently need to get the following done: - Correct pulley misalignment (crankshaft, power steering) and replace belts. - a proper tuneup. Examine sensors, clean, check, replace as needed. ย ย On 1/23/2025 at 12:27 PM, iRage said: Congratulations ! Thank you so much. Appreciate your help which made it possible. On 1/23/2025 at 12:42 PM, matroska said: Congrats! Like to see a little follow up and a few pics if that's not too much to ask !ย Totes. I created a blog so I can post in detail. Hope it will help someone. On 1/23/2025 at 1:10 PM, fiat fan said: Personally I think the best vehicle workshop in Kandy is Nandana Motors aka SL Chop Shop. Almost all the tuned and modified rides in Kandy and even other areas go to them for mechanical and restoration work. Everything from the post office delicas to the Kandy big shots and the GTRs go to them.ย ย Pricey, long waiting list. But worth it. Warranty is also given on some repairs.ย ย Cant beat them for restorations in kandy or even the whole island tbh. this is through my personal experience and customer feedback Iv got. They also got a YouTube if you want to see their work before going(what I did) Kandy has a lot of crook mechanics. Beware. Thanks so much. Know any places in CMB?
February 5, 20251 yr Author On 1/25/2025 at 10:42 AM, Nate said: Any place in Colombo? Following up, so I was able to get the crank pulley replaced as well as the belts and other stuff. I will write up about thatย The main problems I have now are: - engine idle up doesnt work properly, for AC, engaging a gear, the vehicle starts to rattle. I increased the idle a bit to compensate but something is wrong. - there's a fuel smell when the car is running. I suspect this could be connected to the idle issue. Is there any garage that can do a careful check or the ECU and sensors and clean or replace as needed, and also do a proper tuneup? The two garages I went to, they gave it a try but don't seem to know what they are doing. Does anyone have suggestions ๐๐ฟ๐
February 10, 20251 yr On 2/6/2025 at 4:26 AM, Nate said: Following up, so I was able to get the crank pulley replaced as well as the belts and other stuff. I will write up about thatย The main problems I have now are: - engine idle up doesnt work properly, for AC, engaging a gear, the vehicle starts to rattle. I increased the idle a bit to compensate but something is wrong. - there's a fuel smell when the car is running. I suspect this could be connected to the idle issue. Is there any garage that can do a careful check or the ECU and sensors and clean or replace as needed, and also do a proper tuneup? The two garages I went to, they gave it a try but don't seem to know what they are doing. Does anyone have suggestions ๐๐ฟ๐ Try under this, a few have been listed
February 12, 20251 yr Author On 2/11/2025 at 4:51 AM, john cooper said: Try under this, a few have been listed Thank you JC. I'm a little reluctant to follow recommendations as that thread is over a decade old.ย A related example: when I got the car, my first trip was to my favourite garage for Toyotas - when I got there I found out that the owner had passed away. I let them do some of the work - the staff are OK with suspension work but not engine work alas. Right now, I'm a bit stuck as there's a significant performance issue with overtaking and climbing hills - the engine seems to lug and the car vibrates but doesn't go*.. even in a lower gear. I am not certain if it's the auto gearbox or engine or both even, I suspect it's the engine. I'm thinking about taking the car to that repair place created as a subsidiary of the agent - pit and something. Has anyone tried them? ย Edit: car vibrates but doesn't speed up. It seems to struggle and i have to crawl up the hill.ย Edited February 12, 20251 yr by Nate
February 13, 20251 yr On 2/6/2025 at 12:26 AM, Nate said: - there's a fuel smell when the car is running. I suspect this could be connected to the idle issue. Just so you know fuel smell can also be because of the EVAC system going bad (particularly if the charcoal canister is bad). It is quite common in SL because Lankans have a habit of over filling the the fuel tank. So fuel just floods the EVAC lines (more than it should) and eventually the canister goes bad and doesn't remove the fuel odor. Sri Lanka bein Sri Lanka, it never gets fixed. Even if you want to fix it Toyota does not make the part for it anymore. So your only option is to find a used one. OR find a compatible unit from a newer car (easier said than done) Not saying your EVAN system is pooched...just saying so you know it is a possibility.
February 13, 20251 yr Author 4 hours ago, iRage said: Not saying your EVAN system is pooched...just saying so you know it is a possibility. Interesting! TIL
February 14, 20251 yr Author On 2/13/2025 at 12:46 PM, iRage said: Not saying your EVAN system is pooched Following up, the smell is from the front of the car, engine,as we drive (quite strong if we roll down the windows). ย I was reading some old threads which recommended a gent called Dhammika in Cotta Road borella, does anyone know if he is still around?
February 15, 20251 yr 10 hours ago, Nate said: Following up, the smell is from the front of the car, engine,as we drive (quite strong if we roll down the windows). ย I was reading some old threads which recommended a gent called Dhammika in Cotta Road borella, does anyone know if he is still around? you do realize that the charcoal canister is in the engine bay right ? The EVAC system has multiple parts that go all the way from the tank, to the fuel filling line to the engine When the charcoal canister is gone bad you will get a fuel smell when the engine is running and even after the engine has been shut off (soon after shutting off the engine or when there is a sudden change in the weather due to temprature changes). When you open the fuel lid when the tank is empty, how bad is the pressure release ? Check for fuel leaks. If there is no leak, and the engine is not running rich, your most likely culprit is going to be the EVAC system (most likely the charcoal canister). Edited February 15, 20251 yr by iRage
March 4, 20251 yr Author On 2/15/2025 at 9:15 AM, iRage said: you do realize that the charcoal canister is in the engine bay right ? The EVAC system has multiple parts that go all the way from the tank, to the fuel filling line to the engine When the charcoal canister is gone bad you will get a fuel smell when the engine is running and even after the engine has been shut off (soon after shutting off the engine or when there is a sudden change in the weather due to temprature changes). When you open the fuel lid when the tank is empty, how bad is the pressure release ? Check for fuel leaks. If there is no leak, and the engine is not running rich, your most likely culprit is going to be the EVAC system (most likely the charcoal canister). Makes sense thanks - there is a fuel smell when running and switched off. I have not emptied the tank yet to check pressure release, I will let you know when I try that.
March 4, 20251 yr On 3/4/2025 at 2:12 PM, Nate said: Makes sense thanks - there is a fuel smell when running and switched off. I have not emptied the tank yet to check pressure release, I will let you know when I try that. If there is no leak, and the fuel smell is there even after the engine has stopped. It probably is the charcoal canister .ย Occasionally it will also get in to the cabin as the aircon/blower/heater takes in air from outside. 99% of the time mechanics do not identify the issue (this includes Toyota Japan who kept my old Corolla wagon for 4 days to diagnose it just to say they couldn't find anything wrong). It is something that only experience will suggest. The pressure release from the tank, etc...those are things that may or may not happen. Also, unless you know exactly what the pressure release sounds like when the car was in good shape you will never realise there is something wrong. So even if you do run the tank low and open the tank you might not notice anything abnormal.ย Also...the part is no longer in production. So you won't be able to find the exact part but use one from a different Toyota. Edited March 6, 20251 yr by iRage
