Guys, I am looking at a particular 2008 L200 to purchase for 8.5m approx. 220km done. Price seems on the very high side compared to good Stradas about 10 years older. What do you think? I am worried about the repair costs etc, that I read about Suction valve, EGR...
Appreciate some food for thought!
7 answers to this question
Is it a UK model or a direct import from Thailand,
I wouldn't trust the mileage on anything for sale in this country.
They are very reliable motors but need some expensive say "running repairs" compared to another Pickup
Costs 2025-2026 - Original Parts approx
Assuming u are looking for the 4d56U engine (sportero / UK Triton), not the 4m40 non turbo that was sold in small numbers
T Belt change - full kit company- Approx 200,000
Crank oil seal - company cost - w labor 110,000 approx (AUTO c ATF change)
ATF Change - 50k
Oil change - 30K approx Valvoline
Suction Control Valve - Approx 50000 oem outside
HUB bearings - Approx 80K (expensive i know) per corner
Brake Servo / Pump approx 20k
ABS Pump - Common issue, parts very scarce esp A02 model 100,000/-
EGR approx 50,000 oem outside - repair and put a plate and you are sorted
Brake Liners and pads - 20-40k based on quality.
Turbo - 120,000 - not oem
Check the body condition also as most are not pampered,
Expect these repairs at some point of time.
If you are looking at a car with an engine rebuild, mind you they need engine work by approx
500,000km, These bores are made for 1-2 overhauls by the manufacturer, so target to bore and use oversized pistons, and rings and you are good to go for another 500,000km.
Will cost approx 600,000/-original parts, a bit more with agent
Sleeving and ring swaps won't last so don't expect that.
The previous gen trojan / strada models are smaller, cabin space is very less. So try for the KB4T (2008-2015)
We have been having one for ages as a hauler, happy to help
  • Like 3
unrelated but yes... Got to know of this  gentleman who recently sold his Honda Vezel he had for 12 years with almost 400,000 KM and in impeccable condition for a very low price. For the last month it has been going hand to hand with buyyas with the mileage dropping weekly and the price increasing by 200,000 😂
  • Haha 2
ATF Change - 50k
Thanks a million for the great info with detailed price breakdown. The KB4T I checked was a UK import.
I am now thinking about Navaras too. I know their record is not all that good. But there are ones that have got full engine overhauls. And if I get a Thailand import, that might not have hidden chassis corrosion too.
Btw, you say the Strada cabin is smaller than KB4T? Really? I felt the other way around.
Daylight robbery...
You are spot on tiv...I just searched and confirmed that KB4T has bigger cabin thanks to it's J line design... awesome
Yes the Strada cabin is smaller bu a few cm in each direction. The Strada interior feels larger because of the body shape. The Strada cabin shape is boxy, so its roofline doesn't taper down. The waistlines are low (comparatively) and stay at the same level, so the front and rear windows share the same waistline and let in a lot of light. The KB4T, on the other hand, has a curvy, balloon-like cabin shape. So the roof feels like it is tapering down, giving you a feeling of getting cocooned. Add to that the waistline that tapers up toward the rear, and you get rear windows that are smaller than the Strada. This lets in less light and gives less visibility through the rear window so it feels smaller.
Awesome analysis...
