March 28, 20179 yr 1 minute ago, Sierra Charlie said: Well, you might be surprised at the rarity of the parts that some of these parts people carry. Managed to buy a pair of Super VR4 Headlights the other day from Taiyo. To put things in perspective, only about a 1000 Super VR4 were ever made. Hit me up if you want a contact there. I also managed to find an inner door handle for 1250. The last inner door handle I bought was from eBay Germany and paid around 5000 for that. Oh Yes, thanks charlie, I will send you a DM for the contact
April 26, 20179 yr 1 hour ago, PreseaLover said: Guys, to be in the safest side, how often should I change transmission oil? 40,000km
November 28, 20179 yr Guys small concern.. In cold start, when I shift the gear to D, and accelerate, it takes around 4-5 seconds for the car to move.. it started happenning for like 3 days now.. No matter how hard I accelerate, it stay still for like 5 seconds.. But after running, and shifting the gear to D from P, then the car moves as usual in less than a second.. what would be the reason? I changed gear oil 20,000km's back and its not a CVT gear box.
November 29, 20179 yr 10 hours ago, PreseaLover said: Guys small concern.. In cold start, when I shift the gear to D, and accelerate, it takes around 4-5 seconds for the car to move.. it started happenning for like 3 days now.. No matter how hard I accelerate, it stay still for like 5 seconds.. But after running, and shifting the gear to D from P, then the car moves as usual in less than a second.. what would be the reason? I changed gear oil 20,000km's back and its not a CVT gear box. This is a Common issue for Auto tranys . Show it to Nilwala motors. He might able to help you out. You will be able find the contact details in this Forum.
November 30, 20178 yr On 11/28/2017 at 11:12 PM, PreseaLover said: Guys small concern.. In cold start, when I shift the gear to D, and accelerate, it takes around 4-5 seconds for the car to move.. it started happenning for like 3 days now.. No matter how hard I accelerate, it stay still for like 5 seconds.. But after running, and shifting the gear to D from P, then the car moves as usual in less than a second.. what would be the reason? I changed gear oil 20,000km's back and its not a CVT gear box. Sounds like early signs that your gearbox is on it's way out. Best get it shown to someone who specialises in Autoboxes.
December 1, 20178 yr On 11/30/2017 at 10:39 AM, Supra_Natural said: Sounds like early signs that your gearbox is on it's way out. Best get it shown to someone who specialises in Autoboxes. OMG OK... will check it out :/
December 1, 20178 yr so I went to Nilwala and they said I need a gear box overhaul.. quoted 30k for the job..
December 19, 20178 yr Hi Guys, just wanna know if the gear box comes with the engine itself? I mean if i buy an engine for presea, will the gear box also be included?
December 19, 20178 yr 7 minutes ago, PreseaLover said: Hi Guys, just wanna know if the gear box comes with the engine itself? I mean if i buy an engine for presea, will the gear box also be included? Err... no it will not, unless you specifically ask for and buy the gearbox as well. The engine and Gearbox are two separate mechanisms.
December 19, 20178 yr 3 minutes ago, Supra_Natural said: Err... no it will not, unless you specifically ask for and buy the gearbox as well. The engine and Gearbox are two separate mechanisms. ohh ok... lets say i drop a SR20DET engine to the presea... in that case could you let me know what are the other parts I need to replace to make it compatible with the engine? Like gear box, computer box, and what else apart from the engine?
December 19, 20178 yr 15 hours ago, PreseaLover said: ohh ok... lets say i drop a SR20DET engine to the presea... in that case could you let me know what are the other parts I need to replace to make it compatible with the engine? Like gear box, computer box, and what else apart from the engine? Replacing the engine with a different one than original is a totally different story than just putting an identical replacement (GA15DE) engine. The SR20DET is a bit of a drastic example due to the fact that it's a turbocharged engine with a lot more power than your original GA15DE. This means you might need to change your engine mounting, relocate some of the electronics/components to make room for the larger engine, install better cooling (i.e radiator) and even change the drive shafts to accommodate for the changes in length of the engine/gearbox. Plus, if the SR20DET doesn't come with the ECU and stuff, you'd have to buy it separately and wire them up to the existing harnesses. Also, you'd need to make room for the intercooler behind the front bumper. With an upgrade like that, it's only advisable to upgrade brakes as well. If you replace the existing engine with a similar GA15DE, you don't have to worry about whether the engine comes with an ECU and harnesses or not (they usually do) because you can use your existing ones. You can also use your existing drive shafts, and wouldn't have to make any suspension, mounts, cooling or other structural changes to the car. It should technically be "plug and play". Why would you want to replace the engine though? Wasn't the issue with your transmission? Edited December 19, 20178 yr by Davy It's GA15DE. Not QG15DE. Thanks for pointing out @NRX.
December 19, 20178 yr 29 minutes ago, Davy said: Replacing the engine with a different one than original is a totally different story than just putting an identical replacement (QG15DE) engine. The SR20DET is a bit of a drastic example due to the fact that it's a turbocharged engine with a lot more power than your original QG15DE. This means you might need to change your engine mounting, relocate some of the electronics/components to make room for the larger engine, install better cooling (i.e radiator) and even change the drive shafts to accommodate for the changes in length of the engine/gearbox. Plus, if the SR20DET doesn't come with the ECU and stuff, you'd have to buy it separately and wire them up to the existing harnesses. Also, you'd need to make room for the intercooler behind the front bumper. With an upgrade like that, it's only advisable to upgrade brakes as well. If you replace the existing engine with a similar QG15DE, you don't have to worry about whether the engine comes with an ECU and harnesses or not (they usually do) because you can use your existing ones. You can also use your existing drive shafts, and wouldn't have to make any suspension, mounts, cooling or other structural changes to the car. It should technically be "plug and play". Why would you want to replace the engine though? Wasn't the issue with your transmission? Ah right now I get it... Yes the problem was with the transmission.... But I was wondering, if i go for the existing engine's transmission - one day if I want to drop a bigger engine, then i will have to again change the transmission box as well... so that's why was wondering if it was an easy process to drop an engine now itself... seem's like Im better off leaving the engine be and changing only the transmission for now... thanks for the advice davy
December 19, 20178 yr 5 hours ago, Davy said: Replacing the engine with a different one than original is a totally different story than just putting an identical replacement (QG15DE) engine. The SR20DET is a bit of a drastic example due to the fact that it's a turbocharged engine with a lot more power than your original QG15DE. This means you might need to change your engine mounting, relocate some of the electronics/components to make room for the larger engine, install better cooling (i.e radiator) and even change the drive shafts to accommodate for the changes in length of the engine/gearbox. Plus, if the SR20DET doesn't come with the ECU and stuff, you'd have to buy it separately and wire them up to the existing harnesses. Also, you'd need to make room for the intercooler behind the front bumper. With an upgrade like that, it's only advisable to upgrade brakes as well. If you replace the existing engine with a similar QG15DE, you don't have to worry about whether the engine comes with an ECU and harnesses or not (they usually do) because you can use your existing ones. You can also use your existing drive shafts, and wouldn't have to make any suspension, mounts, cooling or other structural changes to the car. It should technically be "plug and play". Why would you want to replace the engine though? Wasn't the issue with your transmission? It's the GA15DE Davy. PreseaLover !! You should have seen this ?
December 19, 20178 yr 4 hours ago, NRX said: It's the GA15DE Davy. PreseaLover !! You should have seen this ? I saw I saw...
December 19, 20178 yr 9 hours ago, NRX said: It's the GA15DE Davy. PreseaLover !! You should have seen this ? Oh of course! Thanks for that NRX. Post corrected.
December 20, 20178 yr 23 hours ago, PreseaLover said: ohh ok... lets say i drop a SR20DET engine to the presea... in that case could you let me know what are the other parts I need to replace to make it compatible with the engine? Like gear box, computer box, and what else apart from the engine? Davy is right. Consider an SR16 variant if you are interested in a SR motor. DE or VE.
December 21, 20178 yr On 12/19/2017 at 10:28 AM, PreseaLover said: ohh ok... lets say i drop a SR20DET engine to the presea... in that case could you let me know what are the other parts I need to replace to make it compatible with the engine? Like gear box, computer box, and what else apart from the engine? On 12/19/2017 at 11:50 AM, Davy said: Replacing the engine with a different one than original is a totally different story than just putting an identical replacement (GA15DE) engine. The SR20DET is a bit of a drastic example due to the fact that it's a turbocharged engine with a lot more power than your original GA15DE. This means you might need to change your engine mounting, relocate some of the electronics/components to make room for the larger engine, install better cooling (i.e radiator) and even change the drive shafts to accommodate for the changes in length of the engine/gearbox. Plus, if the SR20DET doesn't come with the ECU and stuff, you'd have to buy it separately and wire them up to the existing harnesses. Also, you'd need to make room for the intercooler behind the front bumper. With an upgrade like that, it's only advisable to upgrade brakes as well. If you replace the existing engine with a similar GA15DE, you don't have to worry about whether the engine comes with an ECU and harnesses or not (they usually do) because you can use your existing ones. You can also use your existing drive shafts, and wouldn't have to make any suspension, mounts, cooling or other structural changes to the car. It should technically be "plug and play". Why would you want to replace the engine though? Wasn't the issue with your transmission? Davy has hit the nail right on the head, the SR20DET would probably be too much engine for the car and you'd end up having to strengthen so many things that it will be a never ending project. The wiser choice for now would be to just swap out the gearbox if your engine is fine. If you're hell bent on an engine swap then I think a standard SR20DE would be enough of an upgrade with a useful bump in power, that won't need the level of beefing up that the turbo version will need. You could also look at the SR16VE as found in the Pulsar VZRs like @Pericles mentioned. Worthwhile to keep in mind that the legal standing of higher capacity engine swaps is a bit of a grey area at the moment.
December 27, 20178 yr So this thing was there ever since I bought the car 2 years back... after running a good 10km's when I accelerate in 2nd and 3rd I hear a rattling noise from the engine.. like a whispering 'gada gada gada gada' noise, and when the gear reaches 4th, it goes away... this noise, ever since i bought the car has NOT increased whatsoever.. the same level for the 20,000km's I drove for the past 2 years... just wondering what this sound may mean if I would ask? Edited December 27, 20178 yr by PreseaLover
December 28, 20178 yr 26 minutes ago, PreseaLover said: The Gearbox overhaul is happening right now.. Here are some pics! Where is this ? Did you get a quotation for the repair ?
December 28, 20178 yr 1 minute ago, NRX said: Where is this ? Did you get a quotation for the repair ? Nilwala Motors Madiwela... yes, 30k... it will be done within the day, but they are giving the car tomorrow morning as they have to test it in cold start after the overhaul..
December 28, 20178 yr 1 minute ago, PreseaLover said: Nilwala Motors Madiwela... yes, 30k... it will be done within the day, but they are giving the car tomorrow morning as they have to test it in cold start after the overhaul.. Are they using Japanese parts ? What are the parts being replaced ? That's if they have told you that ?
