Ruslan
Everything posted by Ruslan
  1. Try Agents? (KIA is Hyundai Owned brand, so Hyundai Lanka should help you with that, i suppose!)
  2. Thanks Ripper For the valuable Info, but with the Emergency law, anybody can arrest you without a arrest warrant. am i right?
  3. You Mean That needs to be done by Female Officer?? even for guys??
  4. If im the new guy, im gonna remove the 1000CC Motor and replace it with a 1300CC Engine..
  5. Ruslan replied to ash's topic in General Automotive
    Yeah I saw That on Rupavahini News Session. Justifying the price hike, "Look the Oil Prices has gone up, so we got no choice"
  6. Ruslan replied to ash's topic in General Automotive
    Have you guys heard about the Waters Edge Deal? High Court has ordered to handover the Land to the UDA (Used as a Low Land) and ask CBK and Ronnie Pieris to pay some money to the Government. Good lesson for a Business tycoons getting along with crooked politicos. but this money (3Mil for CBK and 2Mil For Ronnie) is nothing.
  7. I guess my car is not included since it's 1798CC what's the CC margin for this Semi luxuary Tax??
  8. Well i have the same model car, recommended tire size is 185/70/R14. but if your changing into 15 inch wheels the required tire size is 195/60/R15. this i came across with the repair manual for aussie model corollas (Same as our ones) which is found on the web. Check the thumbnail for more info
  9. If i can remember there was a car at AL (AE111 - 1.6 Model) 99 manufactured.
  10. Ruslan replied to prad's topic in General Automotive
    Yep! even Some Service Adviser who works at Toyota told me that they are getting Toyota T IV (Tranny Oil) oil from Mobil.. guess it's Toyota Branded Mobil Oil After all
  11. Ruslan replied to prad's topic in General Automotive
    Nilantha, any huge price difference between Toyota Engine oil and Mobil? herd from Western automotive forum, that Toyota Re-branded Mobil oil and sell it.. i don't know whether it's true or not. but herd that they (Toyota Lubes) got all the Viscosity Levels that Modern Vehicle requires in here, like Most of the VVT-i Engines require SAE 30 type Oils (that's what the manufacturer recommended). i couldnt find those Viscosity levels with Mobil lubes.
  12. Couple of things about CE110s. its bit harder to find CE110 Manual ones. most of the Manual ones were AWD cars (CE114). it's bit costly to maintain those complex gearboxes.
  13. So i guess according to this report.. The Original LPG RAV4 is a good Eco friendly vehicle. i think i remember couple years back Toyota lanka or someone Advertised about LPG Rav4. is it a original Factory fitted LPG unit or 3rd Party System?
  14. As long as those are for General passenger usage.. might not affect!! but who knows, what if some idiot comes up with some stupid law! Well myself ran into same kinda situation, do you guys know that Importing a Nokia N82 to Sri Lanka is banned now?? this has happened to me couple of days ago. i used to send Reports for Nokia blog called "S60 Ambassador program" by Nokia. as a compliment those fellas sending gifts and Loaner Mobile Devices (Just for use/Evaluate for couple of months) so i got myself a Nokia N82 for two month usage. sent by Nokia USA. it came through DHL, and finally got detained under Customs saying importation Nokia N82s is banned in Sri Lanka. i was like what the !@#$%#@#$%^@. prime reason is it contain a inbuilt GPS!!. Custom officer told that i required to get License from TRC (Telecommunication Regulation commission) and from Import Export control board. right away i advise the courier people to re-send it back. so much for the stupid Laws!
  15. So Much for the Ministerial pundits in Sri Lanka.. goons always got the luxury of using vehicles with higher engine capacity well of course with our tax money. i wonder what will happen to those Humvees.
  16. I'm sure some environment adviser bugger has advise this to limit vehicles with higher capacity engines. they might think that running a SUV with a 800CC engine is an eco friendly thing! what an ar*** Ho***s!!
  17. What the !@#%$@+#!.. do they expect to fit a smaller engine than 2000CC for a Rexton like SUV? this is ridiculous!!
  18. You can get the price guides from hardwarezone.com it contains all the prices from Sim Lim square mall Singapore
  19. Now the Core 2 Quad is in the market right?
  20. Damn! that's bad. i think you better get a used ECU than repaired one. cos even if it's older 10 15 years doesn't mean that they've been used for that much years. (Some ECUs might've being removed from wrecks) even if you repaired the ECU, the Original firmware has to be re flashed to the ECU back AFAIK. it even differs from Manual tranny ECU and Auto tranny ECU. why don't u ask from Zaki?
  21. Just had a small miss in my Corolla. Check the plugs and it was pretty bad! it came with NGK Iridiums originally. normally iridium s lasts around 75,000-80,000 Kms. bought Denso Iridium s from Toyota Lanka it's around 1200/- a Piece if i can remember correct (First i look for the NGK Iridiums as it came with the engine). when fitting plugs i think you should use a torque wrench and follow the specific torques to tighten plugs. specially with Aluminum Alloy Engine blocks.
  22. Ruslan replied to shanX's topic in HONDA SRI LANKA
    VTEC - Variable valve Timing and lift Electronic Control. At low RPM, a VTEC engine uses a normal cam profile to retain a smooth idle, good fuel economy, and good low-end power delivery. The VTEC mechanism engages a high-lift, long-duration "race" cam profile at a set RPM value (i.e., ~5500RPM on the B16A) to increase high-end power delivery. VTEC-E - Variable valve Timing and lift Electronic Control for Efficiency. This system isn't really VTEC as we know it. At low RPM, the VTEC-E mechanism effectively forces the engine to operate as a 12-valve engine - one of the intake valves does not open fully, thus decreasing fuel consumption. At a set RPM value (i.e., ~2500RPM in the D16Y5), the VTEC-E mechanism engages the 2nd intake valve, effectively resuming operation as a normal 16-valve engine. Note: in a VTEC-E engine, there are no high-RPM performance cam profiles; this engine is supposed to be tuned for fuel economy, right? VTC - Variable Timing Control. This is a mechanism attached to the end of the intake camshaft only which acts as a continuously variable cam gear - it automatically adjusts the overlap between the intake and exhaust cams, effectively allowing the engine to have the most ideal amount of valve overlap in all RPM ranges. VTC is active at all RPMs. i-VTEC - intelligent Variable valve Timing and lift Electronic Control. This is a combination of both the VTEC and the VTC technologies - in other words, i-VTEC = VTEC + VTC. Currently, the only engines that use the i-VTEC system are the DOHC K-series engines. Now this is where things get tricky - Honda uses the term "DOHC i-VTEC" for two different systems: The first system is used in the K20A2 engine of the RSX Type-S. The second system is used in the K20A3 engine of the Civic Si Source: I guess you have to depend on what VIN plate says about engine plus the engine cover. but better wait for a Honda expert
  23. I guess something to do with Compressor clutch or too much tight belt. could be a Gas leak as well. best advise is to take it to where you get it serviced. further it's advisable not to use the AC with this fault. this could further damaged to the pulleys and even Compressor.
  24. Happy Birthday Ripper! Hope you had a good one!
  25. Ruslan replied to Kim's topic in General
    I guess it only affects on long trips. not much in driving around Cities i suppose. herd someone in the forum say that 95 is got more impurities than 90 can anybody confirm this report. if it's true, it's scary!
