Twin Turbo
    51
  1. Check if the belt is tight enough, and not slipping. Next, get an auto electrician to check the alternator,..
  2. if you think the engine over heats,..that's the start to a lot of headaches,.. better get the cooling system checked,..
  3. Just take your car to an auto electrical specialist. a service might do the job,.
  4. Hi , and welcome to AL,.. K11, yes? While it will be difficult to find the exact part for your car,.. there are many shops who stock similar beadings that can be measured to the car's size in Darley Road. Good luck,. TT.
  5. Evap leaks are the most common,.. get the car checked by a pro,..parts will be removed and checked to detect un detected leaks,.. Start by checking the evaporator. Wishing you cool runnings,.. TT.
  6. HI, if you're continuously topping up your car's cooling system,.. you must get it checked,..
  7. Regular will do for non-turbo models.
  8. Your transmission,.. don't wait till it stops shifting,..service it . Get the brakes checked for binding,.. you can start by replacing the air filter,..
  9. Hi, and welcome to Auto Lanka, Congratz on the first car,.. if possible get a manual, it will be cheaper to buy, depending on where you are,..And A/c will be essential in the summer. Buy your car with purchase price+ insurance and other expenses like road tax taken into account. I won't led you to a small car as safety should be an important consideration in your shortlist. so go for a car with atleast driver's airbag, stability control+ ABS. Goodluck ! ?? TT.
  10. Hi, yes, most car makers have a two year replacement recommendation under standard usage conditions. What is your transmission/?
  11. What you mean by relay is not what is used to connect to the head unit,..
  12. Get a pro to do the installation, and no you don't need a relay.
  13. This was offered with a V6
  14. One is Petrol and the other is Diesel,.. Having maintenance history is very important, What mileages are the cars?
  15. The D8, nice looking car, best is 6km/l . but new imoports had cat deleted from factory, so can be safely driven with regular petrol.
  16. Congrats bro, yes. Dreams do come true if you believe in them and work towards getting them.
  17. http://eservices.motortraffic.gov.lk/VehicleInfo/home
  18. HI, Regular LED bulbs on turn signals will make them blink faster.
  19. Hi welcome to AL,. Your vehicle needs CVT fluid . Honda branded stuff can be got from them agent. the correct fluid is light green colored.
  20. GA13 Ring a bell?
  21. not the ex saloon - new import carburetor mdl i tuned. ? Basically it had a b13 engine.
  22. Interesting that your car , took two decae may we see this engine please? Because Nissan has been fitting belt driven timing gear since the B11 ?
  23. Keep the addition to a minimum, ie, aluminium rivet.
  24. How sure are you of the mileage? just top up and drive for now,.
