terrabytetango
  1. Would you happen to have a sample of the packaging your bulbs came in? Or an SKU code? I'm curious about these Koitos. Edit: For a price comparison, the H4 and H3 Nightbreakers cost me LKR 2651 and 3211 respectively (yes the H3s are more expensive). This includes all charges for them to arrive at my doorstep.
  2. Avoid Sylvania if you can, they're like B grade Osrams. Sylvania is mainly an American brand, they use the same nomenclature as Osram i.e. Nightbreaker, Silverstar etc, but if you browse the US forums, they're inferior to their Osram counterpart. That's why I specifically went after Osram on ebay UK.
  3. I too agree, buy a car you're going to keep. Just buy one you'd be comfortable driving. With your budget you have a good choice, and you needn't necessarily spend it all to find a good car.
  4. When you opened up the key, did you notice the switches? if they're micro switches you can try using contact cleaner to clean them. My car has a third party system and a few switches were behaving erratically, so I soldered on new switches (its a common type and they're freely available in SL, I just showed the guy a switch I had previously desoldered) and now it works perfectly.
  5. My former CEO's Harrier used to say greetings and the time when the vehicle was started up. we had to use google translate.
  6. Yellow is the best for fog lights IMO, they were actually required in Japan right up to the early 90s (which is why you see some of the older JDMs with yellow lenses i.e. isuzu trucks, 130 series Crowns etc).
  7. I can tell you how effective 55w Osram Nightbreaker H3s are once I fit them in this weekend.
  8. I recant my last post, I believe my inebriation plus whatever it is I'm smoking amplified my exteme bias against Alonso.
  9. No doubt Alonso would have placed podium, but the only reason he placed 1st was because Grosjean's car crapped out. Had it not, I believe he would have taken it all the way home. Recanted
  10. Worst race ever Both Vettel AND Hamilton non-finishers. I bet there will be some heavy drinking tonight by them. Maldonado needs to be penalized for that, he was still overtaking once he was off the track. And this is not the first time he has deliberately crashed into Hami either. Alonso had a ton of luck this race, considering how he didn't even make it to Q2. Schumacher was just in the right place at the right time.
  11. I actually pressed F5 twice :/
  12. It isn't very good. I had to take one to our plant in Agalawatta recently, tank was 3/4 empty by the time we returned to colombo. The driver said its awful on fuel. This was a high roof delivery van with a rear A/C conversion and 3 rows of seats.
  13. You won't find a sedan with the ground clearance AND the fuel economy of a Cruze/Swift.
  14. Ane manda, the kind of skewed information you spread around in this forum is amazing. You're an infection.
  15. Just to clarify things for @hatharasinghe, don't use 100W bulbs in your normal headlamps. Your car's headlight circuitry is not designed to provide that much power. In addition, its very likely you will damage the headlamp assembly through excess heat. The Rallye 2000 @Ripper refers to are after market driving lights designed for high wattage use when installed properly.
  16. I can't stress this point enough, and I'm sure I've stated it before: Your car's standard halogen headlight will not properly reflect the light from an HID bulb. This is because of the difference in shape of a Halogen bulb filament VS HID bulb arc. This is why your light output is funky. When I had my van, I had to position the lamps much lower than I would have with halogens. The other issue with aftermarket HID is that that there's very little difference between low and high beams (headlights), because the dipped beam is created by a solenoid mounted shroud which moves to partially obscure the light. In halogens there are two separate filaments taking care of this. @hatharasinghe if your headlights are focusing very high, its very likely your low beams are already creating glare on oncoming traffic. I had this issue with my van, when I had finally found the correct position, the high beam was quite useless because it would not shine as high as halogen bulbs would. It's because of these issues I decided not to go HID with my Vios but instead invest in good halogen bulbs instead.
  17. I plan to buy one of these once my finances are out of the red. A lot of people in other automotive forums give high praise to it.
  18. Check the MAF, its probably misreading your airflow making your engine do weird things.
  19. @ Jami Ok let me explain our response. IF this same question was posed upon us by a complete n00b, or at least a non-smart ass, we would have glady pointed out the difference. Which is what happened to you in the Nissan forums, because they don't know you like we do. But since we do know you, drawing from our past experience with you, we decided this was the best route to take.
  20. Being a minimalist, I would say without. Anyone will (should) know it's a Triumph simply by looking at it. And as for the video, youtube is blocked at work, so for some reason I assumed it was of the project car. I dream of twin cam MGAs.
  21. The resto is done? Or is this one of your other TRs?
  22. I'd rather pay 2 laks more and get an A33 Cefiro instead.
  23. Definitely stay away from the "kutta kapapu" tires.. I've been to the Arpidac facility where they retread tires, and followed the process from start to end. The first step is actually shaving off the existing tread down to the core. They do however cut tread sometimes for massive specialty tires, those tires come out of the oven basically as slicks, with a full layer of rubber.
  24. This reminds me of fiasco between the two Danny McBrides; For the longest time I was under the impression the guy from The Foot Fist Way also wrote the Underworld series. But this is just inexcusable. Jami, you are no longer fit to give advice on this forum.
