maithri
Everything posted by maithri
  1. True, till you try a S4! Maithri
  2. Just to join the discussion, I feel the market is determined by parts cost,ease of repair, and the I am better than you culture in most cases in Sri Lanka. How ever the lack of exposure to european models in SL creates a warped market where Dealer(Agents as you know them) and the availability of common service parts etc. distorts the issue. D*MO seems to come out favourably whilst Car mart does not seem to judging by the comments posted here. How ever just remember, Audi A4 VW passat Skoda superb share similar platforms and have the same engines and gear boxes as well as brakes etc. The Audi front suspension is made from Aluminium Alloy whilst the other two has the same shape part made from steel. The new A4 has different rear suspension. So a lot of parts are the same i.e. engine, clutches, brakes, steering drive shafts etc are the same. The body panels and the interior is where most differences lie. The diagnostics for all these models use the same software and the electronic parts are common to all the range, Golf's Bora's Octavia's which have the same engine codes share the same parts mainly. So things are easily available freely here in the UK and we can enjoy the car of our choice depending on our needs and the means. I personally do not like the 3 series BMW in my opinion it is not as well built as the A4 and no where nearly as reliable. Try the 5 series it really is Fabulous,the 3 series is for the wannabie's all show no substance. Maithri.
  3. This theory of obtaining hydrogen from water is being explored here too(in the UK). I am still waiting to see one of my mates who is a brain box mechanic to convert his latest car and let me test it's exhaust emmisions and performance. I heard about our SL guy when I was back home in August. I would have loved to have met him and see his invention. Keep us all posted, and I will up date from this end if I get to see the car here. Maithri.
  4. Hi, Just a different line of thought, is your engine really over heating or is your temp guage reading wrong? As you seem to have done all the other obvious checks and replacements I suggest you check the real temperature of your water(coolant) I have a hand held IR temp sensor for this I am sure there are other ways to check it. Just a thought Maithri.
  5. Hi, I will not comment on rip off's as you appear to be comparing labour charges in SL to the ones in the UK. Top line dealers in the UK around London charge in excess of £120.00. Where I am in the East Midlands the BMW MERC AUDI dealers etc charge around £110.00. Us independant Garages range from £35.00 to £50.00.mostly. How ever the time we spend looking at cars giving advice and estimating cost as well as chasing the parts from suppliers which we can't charge for make it very good value for money! Any way your problem is almost certainly caused by a worn bush or a universal joint in the gear linkage. Mitsubishi's are not very common here so parts may have to be sourced from the dealers at quite high prices. In addition their srock levels are poor and it may take several days even for them to get the parts. So as suggested above get a local garage to inspect it, and give you an estimate,any body that says it wants a new gear box is probably on the wrong trac. I can be got on 01933 676788 during the day if you want further help or if you live anywhere near Wellingborough in Northamptonshire where my garage is based. Maithri.
  6. Try Milindu Not only do you want a car it also needs to be reliable and presentable. Maithri
  7. Hi Guys, Strange but I came across a similar problem in a Mitsubishi, turned out to be a small air leak from the front oil seal of the injector pump, try pumping the priming plunger on the fuel filter before trying to stary the engine. If it starts easily the problem is almost certainly between the filter and the injector pump or the pump itself. We just replaced the seal on the pump and the car is fine now. Maithri
  8. Hi guys, I am in SL and having a great time. I brought with me a Brand new code reader that will work on Japanese cars and EOBD enabled cars. This will check and re set your engine fault light, ABS fault light, Air Bag fault light. Any of you guys in the trade if interested please email me on [email protected] for further detail. Moderating team I hope I have not broken any rules, if I have please delete. Thanks Maithri
  9. maithri replied to dinosh's topic in BMW
    Hi, Be ware what gear oil you use here, I seem to remember some models using ATF and some using even engine oil!Check on the web-Comma, Valvoline, Etc have on line specifications for oil. The noise from the rear can be anything from a wheel bearing to a drive shaft joint to the rear diff itself which is a weak point on these cars, oil leak from the front penion seal will lower the oil level sufficiently to run the front penion beaing dry,causing rapid wear. Some here resort to over filling the rear axle oil level so if a leak started you might notice it before desaster strikes! Maithri
  10. I was not being un patriotic, far from it,I still speak very good Sinhalese 25 years after leaving SL, carry a Sri Lankan passport and know all the words to the (extended) national anthem, un like some of our expats I meet here who forgot their language after a very short time and attempt to answer my Sinhalese chat with broken English! I cringe with embarressment when when I talk about the driving standards in SL though! Have no fear I am about to experience it first hand very shortly when I come there. A little bit of order and following the rules when driving gets everybody to the journey's end faster and with less stress and damage to the car as well! Pointing out a flaw or a short coming is patriotic duty, not being able to accept critism?????????.... As for the clowns? If the cap fits wear it! No offence meant! Maithri.
  11. Sorry all you guys and any girls for the delay in replying, AND GT AM I was not comparing the Pug with the Alfa, 2 different cars from different sectors of the UK market place. Alfa's do not sell well in the UK due to their quirky nature. The dealers are pretty useless and residual values after a few years are very low. We do not see enough of them to really develop our skills so we stick to basic work as much as possible. Some garage's will refuse to work on them. Still a passionate band of followers will buy and run them and enjoy the lovely ride. Having owned a fair few Pug's from 404's,504's,to 205 GTI, the 205 was the outstanding one and the closest car I drove from the peugeot stable was a 306 GTI6! since. I thought Mazda's had good suspensions, compared to many other Jap cars! My garage is in the Midlands In Wellingborough 01933 676788. I would love to see some nice Pug 203's Give me a contact to call or email I will be in SL on the 2nd of August. Hope I answered all of you, apologies if I missed any. Maithri.
  12. Different Manufacturers list different intervals for filter changes, check and stick to it or change sooner in adverse conditions. Maithri
  13. Common Rail is electronically controlled Fuel injectors fed from a high pressure fuel pipe (the common rail). The pipe supply fuel to all the injectors at around 200bar pressure and the injection duration and quantity of the fuel is controlled by the ECU. The pressure is created by a high pressure pump driven by the cam belt or the cam directly and is not sequential like the conventional fuel pump. These engines are very efficient and smooth running and very reliable. The fuel filter is a very much higher efficiency unit than on a conventional diesel and must be changed regularly as any loss of pressure will result in poor starting and running problems. Just a basic explanation. Maithri.
  14. Guys, Anything happening in August? I am in SL during August would love to see some of your pride and joy's ! Maithri
  15. Hi GTam, I have a 156 Twin Spark in my workshop right now. I am sorry but it is a pain to work on and the parts are hard to come by if not common to Fiat as well! I can't say I like it at all, but an aqquired taste it may be. This car is 1996 with ABS etc. I am struggling to get exited by it! At the same time I have a Peugeot 206 1.6HDI Quicksilver and man it is proper pocket rocket, Can wheel spin on 1st, 2nd and 3rd! And it is a Diesel-55+ MPG with pretty good handling and parts not too expensive. A nice little car! A very limited edition I fancy buying it off the current ownner if he is selling. Once I had a 205 GTI 1.6 which was also a pure dream to drive and was a far better handling car than my current Golf GTI MK3. Know anyone with a decent Peugeot 203 for me to have a drive in when I am next in SL. I used to drive my fathers in the late 70's and early 80's and still hanker for another drive in one. I am in SL during August, so let me know! Maithri.
  16. Makes a kind of Sri Lankan sense! Why teach you something which we havent decided on yet! Clowns. Maithri
  17. I presume you all have a driving licence! Dont you need to know the speed limits to pass the test? No wonder here in the UK Sri Lanka is one of a very few countries whose licence cannot be exchanged for a British one! You have to take lessons and pass the theory and practical test before you get a licence, no I havent heard of a bribe to a driving examiner! Even a licence from Barbados which have very few cars and traffic can be exchanged for a British one! I can imagine a former 3 wheeler driver having his first drive here, it'll be worth filming for top gear which incidentally I am watching as I type this! Maithri.
  18. Hi Guys, I have personal experience on these. I once fitted a hi flow cat made in the USA to a car which had been foolishly de catted by its previous owner. The car would not pass the emmisions at the annual mot test so I was asked to help. The manufacturers replacement was £ 470.00+vat(17.5%) plus my charges for fitting! I obtained a hi pergormance replacement at £65.00 cut off the pipe that replaced the original and had my welder collegue weld the new one in place. The car was then scanned and chec ked for any further fault codes by me and tested for the Mot. It passed easily. The owner reported no power loss at all and was extremely great ful the his bill was less than half what it could have been. I test a fair few Subaru's and I know that the performance specialist offers their customers the option of a hi flow performance cats all the time. They have a rolling road and do a lot of ecu mapping on these cars. They say that there is only a negligeble or no power loss from a performance cat once the ecu map is properly set up. You also get the added benifit of not polluting the enviorenment. I think a cat in Sri Lanka will be very good for reducing pollution unlike in the UK where the cat reaches operating temperature a very long time after setting off on a journey, as a result of the colder climate. I test enough cars during the Mot where nearly 40 minutes of running during the Mot test still does not ignite the cat sufficiently to meet the emmision level parameters. We end up having to rev these cars for extended periods for the cat to ignite so it does not fail the test needlessly. Maithri.
  19. Hi all, Timing belts were light weight and quiter and worked well as long as you changed it on time. Recently we see some increase in chain drives on engines of Jap and european cars. They are starting to give trouble at around 40 to 50k miles. Un fortunately they cost a lot more in labour as well as parts cost to replace. Nissans's (primera 1.6 and 1.8) engines are known for stretching chains causing the engine to misfire as well as switching on the engine warning lamp, cost approx £800 to fix. GM Vauxhall 3 and 4 cylinder engines suffer from noisy chains at around 50k miles, cost around £350 to replace, compared to a belt driven system on a average car where the replacement cost of the belt tensioners and guide rollers is around £180 to £300 I would currently prefer the belt over the chain! The only trouble free chains are the cars that use 1960's style double row chain technology like the Mercedes Benz and BMW etc. The new viz kids trying to re invent the wheel keeps making it square! Maithri.
  20. Hi mates, Do you suffer much from blocked fuel injectors in SL? Or are you suffering from carbon deposits in the intake system? It is highly unlikely that removing and cleaning injectors on the outside cleans the important spray nozzle of the injector itself, removing and cleaning the injector using ultrasound etc if available in SL will help as this cleans the injector inside, or a specialist can sometimes dismantle the injector and then clean the working parts in a cleaning solution. The cheapest way to internally clean the injector even in the UK is to add a fuel system cleaner to the tank and take the car for a good long drive once operating tempetarture is reached. I use Wurth additives in my garage to very good effect. We have cured many emmision related MOT failures by the above method as the additive cleans the whole system all the way through the catalytic converter as well and restores lost power and efficiency to the system. We clean throttle body's etc. using Wurth air intake cleaner. I have been told by a few mechanics that they have fed the treatment using a vaccum pipe attached to the inlet manifold to clean the soft carbon deposits from around the intake, injectots, egr ports and the valves etc, but never tried it yet myself. I have several customers who buy the stuff from me and use it regularly on their cars and say they are impressed-generally these are the high milage lot, I have one customer who does nearly 500 miles per day 5 days a week, services the vehicle absolutely on the dot at 10,000 miles(16000Km) and has very little trouble from his car. The above is only my openion, I am sure Wynns, Redex, STP etc also sell similar products that do a good job, so this is not promoting one product over the other! Maithri.
  21. I m glad it is fixed now. I thought it was a drastic solution to replace everything. Here in the UK we use non genuine brakes all the time. We buy fron the original brake manufacturers like ATE, BOSCH,BENDIX,MINTEX,FERODO etc.etc. There is good and bad in all, how ever when it comes to Japanese cars we still use non Original pads etc made by the above well known manufacturers. Remember, Nissan Toyota etc. do not make braking systems normally, the specialist brake manufacturers make it for them. Wery often we find that the replacement that the agents sell is not even made by the original brake maker! So it is very much down to the quality of the stuff you use rather than the place you buy it from, for brakes you can't beat quality parts. Maithri
  22. Guys, I only know the UK models, so may not apply in SL, I find the suspension wear excessive on the c class as well as the 3 series BMW,s, C class breaks springs both front and back, the 3 Series wears out ball joints and breaks back springs, The A4 lasts almost for ever on the suspension front and has the best Diesel engine of the 3 similar cars. By the way the A4 aand the VW passat as well as the similar Skoda share the same floor pan engines, suspension,gearboxes and back axles, so mechanical reliability on all 3 are fantastic, the C class diesel with the common rail engine is superb but not so reliable with injector leaks etc letting it down. Only my opinion mind! I know in SL it also matters what your neighbours think of you whem you drive that benz! Maithri.
  23. maithri replied to seeker's topic in General
    May be the tooth paste in uk is more suitable for cleaning head lamps than the tooth paste in SL! gunat I will email you very soon. Maithri
  24. maithri replied to seeker's topic in General
    Hello Guys, I am sure I have said this before, but just last week I cleaned the plastic lenses of a Japanese car using tooth paste. The results were good. Tooth paste on a damp cloth rub in a circular motion and wipe off with another damp cloth. I have also used a polishing compound called Ferecla G3 available in the UK for polishing new water based paints used in most european cars. It is very mild and barely abrasive. I would not dare use any wet and dry paper to clean lights for fear of damaging the lenses beyond repair. Maithri P.S. I had to clean these lenses to get the car to meet the minimum MOT requirements of UK. I failed the cars originally for no beam pattern visible during test.
  25. Guys, If everything is working satisfactorily leave the engine well alone. If you are starting to burn a lot of oil with bluish smoke from the exhaust and poor prformance from the engine start with a compression test and carry out a cylinder leak test if you know some on who has the equipment-I know tht there has to be some one with one as I gave it to him a few years ago, to identify the exact area of the loss of pressure. If you are then set on removing the engine and dismantling it inspect all the moving parts and replace the following at the least All the Bearings All the gaskets and oil seals All the piston rings, if not replacing the pistons themselves Oil pump, Water pump and timing belt and the tensioner and idler pulleys Any worn valves, valve seats, guides and all the valve stem oil seals Also have your machine shop do at least the following, Measure cylinder bores, re bore and hone or if well within usable tolerances just hone the bores Re cut valve seats and re face valves and lap them in(grind) Check out the cam shaft and followers as well as any rockers buckets and replace as needed Check and replace if possible any hydraulic lifters Re-face cylinder head and re fit using new head bolts if recomended by the engine maker onto cleaned and lightly lubricated threads in the block. If possible have your injectors tested and cleaned-specially if it is a Diesel-then have the pump re sealed and caliberated. Remember an engine is the sum of it's parts so be thorough-dont need to be wasteful how ever. Maithri.
