nish1 Posted January 12, 2012 Posted January 12, 2012 Where I can Replace my car door bedding??Need to replace new Coz it sounds bad when closing Quote
CARBON B4 Posted January 12, 2012 Posted January 12, 2012 Darley road should be the place, but will depend on what car it is.... Quote
nish1 Posted January 12, 2012 Author Posted January 12, 2012 (edited) when I close the other 3 doors it sounds German & beautiful. When I close the driver's door it sounds like old car that's the problem..it vitz 2006 Edited January 12, 2012 by nish1 Quote
MrCat Posted January 12, 2012 Posted January 12, 2012 Your Vitz speaks German? Japanese cross breeding..!! Quote
Kavvz Posted January 12, 2012 Posted January 12, 2012 Your Vitz speaks German? Exactly what I was thinking... Quote
Ralph Posted January 12, 2012 Posted January 12, 2012 (edited) Why d u think it is beedings ? Have u cheked ur door pins ? Edited January 12, 2012 by Ralph Quote
kalana Posted January 13, 2012 Posted January 13, 2012 Your Vitz speaks German? Japanese cross breeding..!! i think what he has mentioned is other 3 doors sounds nice when closing and the driver side door sounds bulky. btwn, i do have the same problem. :/ my one is a 2008 swift. Quote
VVTi Posted January 13, 2012 Posted January 13, 2012 First thing to check are the door pins. THen check the beadings. But then since both cars are fairly new, will need to check more closely. This is what happens when Japanese cars try to behave like Germans.... Quote
The Don Posted January 13, 2012 Posted January 13, 2012 when I close the other 3 doors it sounds German & beautiful. When I close the driver's door it sounds like old car that's the problem..it vitz 2006 Your door needs to be adjusted or the door pins need to be replaced. Basically your door has come down a bit now hitting on the latch a bit hence the noise. Also the door locks become a bit noisier over time with wear and tear. Maybe a bit of WD40 might help. Why in the world do you think its the beading ? You should never replace an original beading unless you have no other choice because the replacements are never as good! Quote
